Should Deck Posts Sunk In Concrete Or Above Ground?
Old 04-17-2010, 01:24 PM   #1
Vince10's Avatar
Trade: Tool Rental Shop
What is a better way to go. I have to fix a friends 8x8 porch that is about has moved about two inches from the house. The 4"x4" posts supporting it are on a square slab of concrete maybe a foot deep into the ground. I believe the porch moves slightly up when the ground freezes and back down when it is warm. Thus, the cause of the problem. The freeze line where I live is 42". I know I have to dig down that far and fill it with concrete. My question is, is it better to sink the new 4"x4"s into the concrete below the ground or is it better to use a Red Head bolt into the concrete, connecting a galvanized bracket that holds the 4"x4" say 4" above the ground
Vince10 is offline
Old 04-17-2010, 03:13 PM   #2
Don
rotarex's Avatar
Trade: Renovator/ Builder
Rewards Points: 508
Re: Should Deck Posts Sunk In Concrete Or Above Ground?
Do you live in Yukon, to have 42" frost line?
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline
Old 04-17-2010, 03:16 PM   #3
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
Above. Wood in concrete = ROT.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 04-17-2010, 03:40 PM   #4
Carpenter/Finisher
john5mt's Avatar
Rewards Points: 1,404
Its dang near that here
1st Gen tradesman
My summer job in college became my profession
john5mt is offline
Old 04-17-2010, 03:41 PM   #5
JonM's Avatar
Rewards Points: 1,216
I'm in Connecticut and its 42 inches here
JonM is online now
Old 04-17-2010, 03:44 PM   #6
Working
Cole82's Avatar
Rewards Points: 2,276
Send a message via AIM to Cole82
Yep here in IA it's 42" as well. I would put them on top exactly as JonM's pic.
Cole
The boss of awesome
Cole82 is offline
Old 04-17-2010, 03:47 PM   #7
D.Foster's Avatar
Trade: Carpentry & Remodeling
Yea 42" here too. Or pinned to rock ledge.
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 04-17-2010, 03:47 PM   #8
AustinDB's Avatar
Rewards Points: 590
the connector in JonM's post or dig down, pour concrete pad at bottom of hole, then set post and fill/tamp-works in my area, may not be appropiate for you area.
AustinDB is offline
Old 04-17-2010, 03:52 PM   #9
mikec's Avatar
Trade: Boss
Rewards Points: 510
Here in Connecticut its 42" as well.
You want to put the posts on top like Johns pic. If you sink them in the concrete eventually water will get down between the post and concrete, the when it freezes and the ice expands it will break apart the concrete. I have seen this failure more than once.
mikec is offline
Old 04-17-2010, 05:21 PM   #10
Kent Whitten's Avatar
Rewards Points: 2,040
Ours is 48".
Above ground BTW
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 04-17-2010, 05:37 PM   #11
Rewards Points: 2,000
(http://www.toronto.ca/water/supply/s...watermains.htm)
"Water main pipes are buried in public streets, about 1.5 m deep, just below the area where frost ends or 'the frost line'.
1.5 m is about 5 feet."
neolitic is offline
Old 04-17-2010, 06:03 PM   #12
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 8,373
42" in CT also. If you put them in the concrete the inspector will make you do it over. Use the Simpson Hurricane brackets will make things easier.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 04-17-2010, 06:31 PM   #13
Deck Designer/Builder
DecksEtc's Avatar
Rewards Points: 1,000
That's what it is here in Toronto.
That's why code for deck footings is 48".
What did you think it was?
I am the liquor - Jim Lahey, Trailer Park Supervisor
DecksEtc is offline
Old 04-17-2010, 06:40 PM   #14
The Deck Guy
Greg Di's Avatar
Set on post bases above ground for us.
However, I know several reputable deck builders that do embed the post in the ground--not necessarily in concrete, but on a buried concrete footing and then fill around the post.
Greg Di is offline
Old 04-17-2010, 07:51 PM   #15
TDG's Avatar
Trade: deck builder
Rewards Points: 75
Send a message via Yahoo to TDG
At 48" you might find Perma frost LOL. We did once in PA. It was May and we dug about 48 and i saw ice Of course it was fill dirt.
TDG is offline
Old 04-17-2010, 07:56 PM   #16
Don
rotarex's Avatar
Rewards Points: 508
I thaught it's 6" above ground, I use spikes for all my decks, and 6" above ground only makes sence, don't you see all the homeless people sleeping around, that's because under 6" it's tropical
Custom Decks
Renovation
rotarex is offline
Old 04-17-2010, 07:58 PM   #17
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
are you talking about the bigfoots or regular footings?
how long have they been doing it that way. Sounds strong, but around 10 years or so would have problems. Almost sounds like a good fence contractor.
But I'm no deck expert, only built 2 of them.
William James is offline
Old 04-17-2010, 08:01 PM   #18
Last year I refinished one we did
like that 25 years ago.
neolitic is offline
Old 04-17-2010, 08:15 PM   #19
Rewards Points: 538
I stand corrected. Just footing on bottom and post set. Back filled with dirt?
Old 04-17-2010, 09:31 PM   #20
DecksEtc's Avatar
That makes absolutely no sense whatsoever.
DecksEtc is offline
The Following 4 Users Say Thank You to DecksEtc For This Useful Post:
curapa (04-18-2010), D.Foster (04-18-2010), Gary1 (04-24-2010), neolitic (04-17-2010)
Wood 'footing' on ground at bottom of steps up to deck ??? akm Decks & Fencing 7 07-05-2009 01:56 PM
Deck posts in standing water.. bujaly Carpentry 8 06-20-2008 11:23 AM
How To - Finding New Posts Nathan Contractor Talk Tutorials - How To Use This Site 12 05-08-2008 11:59 PM
advice needed on deck posts in pond smitty58 Decks & Fencing 7 09-29-2007 06:54 PM
