SHED - Opinions Needed
I'm building a shed that is 12'x16'. The ground underneath slopes about 2' over the 16' length. I've dug 6 holes for the piers. The two front piers are 12" Sonotubes that will be flush with the ground and have then beam connector cemented in. The other 4 holes are 16" - and will hold 6x6 square pressure-treated posts that will sit on on 1' of concrete (in the hole) and be surrounded with compacted pea gravel. The posts will hold a 6" beam that will be made up of (4) 2x10's. The beam span will be 10 so the joists will over hand one-foot. The post-span will be 7' along the beam. The joists will be 2x8 and span 10 (because of the beam span). Walls will 8' high and the roof will be a gambrell barn style. Before I start framing, I just wanted some opinions. are the beams beefy enough? The spans all ok? Are the 6x6 posts enough to hold the weight, etc, etc... Any info would be greatly appreciated.
Thanks. |
Re: SHED - Opinions Needed
Unless your filling it with steel or bricks I think your ok with that setup.
Innovative Remodeling LLC Licensed and Insured |
Re: SHED - Opinions Needed |
Trailer park boy
Quad 2x10 beam with 7' spans... you could land helicopters on that...
2x8 joists on 10' span is ok by my code book
"Industry without art is brutality"
Thanks guys for the info. And those 6x6 PT posts sitting on 1' concrete footings will be sufficient as well?
Thom
The posts are overkill. 4X4 would be more than adequate. The piers are questionable, not because they seem inadequate but because no one here knows the soil conditions. If you are building on decomposed granite the piers are overkill, if you're building in a mud-bottomed swamp they probably won't do.
#7 | |
Re: SHED - Opinions NeededQuote:
#8 | |
Deck Designer/Builder
That would be the only problem I see with your design. The quad 2x10's is a little excessive - 3 would be plenty. |
Trailer park boy
Around here 4x4 are not accepted for anything other than fences and railings, anything structural requires 6x6 posts, at least thats what my inspectors are telling me. Also any accesory building under 600 SF does not require frost protected footings, that shed could be built on 16"x16"x2" reinforced pads set on the ground and cribbed up to elevation.
Having said that I would still use big foot footings and sono tubes poured to elevation in all the holes, eliminate the 6x6 all together. I like things built like a brick sh*t house.
I think we talked this shed in another thread. What do they want to spend on the damn thing. It's a shed.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan |
| Opinions on Northstar High-top or Columbia Fat Boy Boxes | tonyvlx | Drywall | 6 | 02-12-2009 12:44 AM |
| Considering Going Union..Opinions? | Mud Master | Business | 21 | 02-04-2009 06:47 PM |
| Website opinions please | Brandon1 | Technology | 7 | 12-18-2008 10:13 AM |
| I need professional plumber opinions | tgrib | Plumbing | 4 | 08-13-2008 09:19 PM |
| Shed..apply for variance or not? | jranaudo | General Discussion | 18 | 08-11-2006 12:00 PM |
