Setting Posts For A Pergola
Old 04-20-2011, 10:33 PM   #1
TheKid's Avatar
Trade: Fencing and Decks
Post
Hi there, this is my first post. Honestly im 21, and a new comer to the contract industry. I have a small business me and an old buddy started up about a year ago building peoples fences and recently started on larger projects like decks and pergolas as things get more serious. between 2,000-6,000 range jobs.
I have sold our first pergola job and I have a few questions. Although it may seem naive; I rather have the work done right than compromising my businesses name. so I subscribed to CT after coming here many times for advice.
My question is on the setting of the post on a pergola. We are out of Austin Tx where the terrain of the Texas Hill country is enriched in limestone. so Its more rugged than you would think. I am wondering weather for this project if we should set the posts (6x6 western red cedar) in the ground about 3 feet deep like we do fence posts with just a bag of quickcrete and adding water. Or do we need to install concrete cyliner forms first and lag-bolt the posts to a level surface using a 6x6 anchor. Or maybe; just dig out a foot, level, and than place pre fabbed fottings? The pergola is going to be 14x8 and 8ft tall, and it is going to be inches away from the house between the fence and the side of the home (standard mega-neighborhood grid layout if your'e trying to picture it.)
any advice is welcome...
I never stole a horse from someone I didn't like. Did I like him? Hell no; I loved the son of a bitch. You asked me if I have scars? Yessir, I have my scars.
TheKid is offline
Old 04-20-2011, 10:42 PM   #2
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,112
Re: Setting Posts For A Pergola
Hi Kid and welcome to CT. You will get a lot of help and advice here, there are a lot of great professionals here.
The questions you asked are good ones but not quite the right ones, there are lots of different ways to install Pergolas "the right way" it just depends on what you are capable of and willing to do that will determine the right way to build one.
You can install the posts in concrete footings if you want but is it he best method? Doubtful, ask what others think is the best for the kind of money you will be building it for, might be a better question.
Many things will depend on the certain application of course.
Hope this helps in some way.
Andy
ScipioAfricanus is online now
Old 04-21-2011, 01:17 AM   #3
Calisota's Avatar
Trade: General Contractor. Design+Renovate+Remodel
Rewards Points: 150
Hi and welcome. I recently came out of the shadows around here, you are wise to do so I think. If this kind of resource was around when I was your age I would have eaten it up.
Anyhow, 8x14 pergola. I'm not a fan of burying wood for decks or overhead structures. I like it mechanically strapped, above grade, for structural components. I'm in earthquake country, so I like pouring my own piers (footings), sized based on site soil and structure load, concrete coped away from the base of the posts to shed water away minimizing moisture contact. You didn't provide a pic or description of the pergola style, so I have no idea of the load, but 8x14 is not very intimidating for a basic design. Why don't you post a sample pic of the style you're building so we can get an idea of how secure it should be. I may be less concerned with your footings, than your lateral support, if it's completely free standing. High winds? Twist-lean-fail? etc.
Calisota is offline
The Following User Says Thank You to Calisota For This Useful Post:
tazmanian (04-21-2011)
Old 04-21-2011, 06:01 AM   #4
Hmrepairs's Avatar
Trade: Remodeling contractor
Rewards Points: 250
Really not trying to be a dick here, but if you sold the job, how did YOU intend on setting the posts?
Hmrepairs is offline
Old 04-21-2011, 06:21 AM   #5
Deck Designer/Builder
DecksEtc's Avatar
Rewards Points: 1,000
I would set them 4 ft' below grade - 1' down for every 2' above grade.
I've built plenty of pergolas and always set the posts in the ground.
I am the liquor - Jim Lahey, Trailer Park Supervisor
DecksEtc is offline
Old 04-21-2011, 07:43 AM   #6
General Contractor
greg24k's Avatar
Rewards Points: 7,334
I would do a typical footing required for your area set the anchor bolt with a post base bracket and trim out the base or make a nice decorative base collar. Here is a quick sample.
greg24k is offline
ScipioAfricanus (04-21-2011)
Old 04-21-2011, 09:48 AM   #7
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Welcome A Borad !!!!
I build pretty much the same as Greg and recomend the post base fastened to the piers. Sometimes the job requires posts set in the pier so I use pt posts then wrap them with cedar,redwood or South American.
Welcome again to the wonderfull world of Contrator land.
John Hyatt www.deckmastersllc.com
John Hyatt is offline
Old 04-21-2011, 10:10 AM   #8
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 476
If you set your posts like Greg describes, you better have a plan for lateral stability, or in the next big wind, it will probably fall over.
I subscribe to Deck'sEct method. Use pressure treated posts, treated to ground contact specs. This will give you the lateral stability. Drain rock at the base of the poss, and slope the concrete at the top away. I wrap the posts as John suggests.
If you are concerned about post rot, you could wrap the posts with Vicor or similar, before pouring the concrete.
This is not a fence, mix the concrete before placing it into the hole.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
The Following 2 Users Say Thank You to redwood For This Useful Post:
detroit687 (04-25-2011), ScipioAfricanus (04-21-2011)
Old 04-21-2011, 11:03 AM   #9
Calisota's Avatar
Rewards Points: 150
I'd fall in line with these gents in this instance for you. You'll eliminate lateral concerns. Send them deep and moisture wrap at ground contact if not using PT.
Calisota is offline
Old 04-21-2011, 11:16 AM   #10
John Hyatt
John Hyatt's Avatar
I forgot to mention a couple things.
Copper Naphthenate. Re treating even ground contact mcq, thats all we can get over here local, with this stuff will stop rot and bugs all together. I put it on anything close to the ground.
Custom post brackets. A hot rod welder bud of mine makes up 16'' /24'' high brackets out of 3/8 / 12'' steel He bores all the holes and places gussets on two sides. Bolted into the piers and the posts these little girls stop the lateral movement. My price is around $50. Good thing to check into.
J.
Old 04-21-2011, 11:53 AM   #11
General Contractor
greg24k's Avatar
That was the only connector I had in my sketchup as a component just to give him an example...and that one will work in his or most cases. The Uplift loads for all post connectors have been increased to max to withstand wind or earthquake loads.
I don't believe in setting posts in the ground this is outdated practice this day and age...the post will fail over time, because no matter what you wrap around it, you will never protect it from moisture or other elements. It is quicker and cheaper way of doing it...but not for pergola or a deck.
There is a dozen more of anchors that are available to use for that application, he can also use Simpson CBSQ44 or here is another example of post connection on a pergola.
greg24k is offline
The Following 3 Users Say Thank You to greg24k For This Useful Post:
John Hyatt (04-21-2011), Randy Bush (05-09-2011), ScipioAfricanus (04-21-2011)
Old 04-21-2011, 12:11 PM   #12
redwood's Avatar
Rewards Points: 476
Anchors are fine, just have to brace, like Greg's pic or have a custom bracket like John describes.
I don't think that any store bought post anchors are designed to withstand lateral forces without help. The CBS's are the best, but you still have to brace.
Mark
Pioneer, CA
redwood is offline
Old 04-21-2011, 01:08 PM   #13
General Contractor
greg24k's Avatar
Mark,
I was at the builders convention a few weeks ago, and spoke to a few people from Simpson and USB manufacturers They said that all tie-down straps,post connectors,etc now made much stronger to meet new max standards for wind and earthquake loads.
That said,he should have a design for at least connection detail to make sure it will be stable and safe.
greg24k is offline
Old 04-21-2011, 04:45 PM   #14
John Hyatt
John Hyatt's Avatar
There is an advantage,for me anyway being a ol dumb okie, using brackets that dont install into the wet creet. That is fastening them to the set up piers.
Small mistakes in lay out can be adjusted where as small mistakes placing brackets in wet creet are there forever.
Really Greg,using the copper naphthenate will give planted pt posts a lifetime well beyond what we have to worry obout during ours.
J.
Old 04-21-2011, 05:26 PM   #15
General Contractor
greg24k's Avatar
J.
I don't know John,and I will not argue about this...Because I can't say how long anything will last underground, or what chances anyone will ever know how long something will last, because down the road we will never hear from people we did that job for,or another HO living in the house will call someone else if there is a problem. So I think its fair to say, maybe it will last, maybe it wont last...
But we can easily say maybe this post got better treatment then the next post did, because we know thats possible. If you wrap the post up with something that will last in the ground a lifetime,there is a possibility in that... but, has it been lifetime since the test was conducted on this items, I doubt it...can it protect something for a lifetime, I doubt it...especially being underground, water, moisture and other elements will get to the wood and destroy it over time.
As precise anchor placement goes...When you have a plan and a layout, is very simple to lay something out and be right on the money. I did so many jobs with anchors being embedded in concrete,i.e decks, footings for parking lot lights, foundations,etc I never had a problem. Yes, it takes time to lay everything out, but so is placing the posts in concrete. I have seen guys do deck footings and they miss the post locations, so if they would stuck a post in the hole and filled with concrete, they would still be off. You know what is out there, I don't have to tell you.
I just think that using anchors and keeping posts above the ground is a much better practice...especially this day and age when we have so many advanced anchoring systems and fasteners.
greg24k is offline
Old 04-21-2011, 05:35 PM   #16
John Hyatt
John Hyatt's Avatar
I total agree. if there is any other choice I never put the posts in the ground. Lay out is Everything.
Very good info. " in the mulitude of counsel there is Wisdom "
J.
The Following 2 Users Say Thank You to John Hyatt For This Useful Post:
carpentershane (05-09-2011), greg24k (04-21-2011)
Old 04-21-2011, 05:50 PM   #17
Fence's Avatar
Trade: Fences
Rewards Points: 75
FYI, copper napthenate is not effective against insects, only fungi. Even then some copper tolerant fungi can get by.
Deck Builder In Oakville
Fence is offline
Old 04-21-2011, 05:51 PM   #18
Fence's Avatar
Trade: Fences
Rewards Points: 75
I like the trim idea.
Fence is offline
The Following User Says Thank You to Fence For This Useful Post:
Old 04-21-2011, 05:55 PM   #19
Chris G's Avatar
Trade: Porch and Deck Builder
Rewards Points: 1,210
Soil and plant growth kind of organically speed up the rotting process, so concrete helps protect the wood as well as offering support.
Or, here's another method. Use a combination of crushed/pea gravel and sand. It acts as a barrier to soil, and drains well. Pack it as you fill, and after a few moons and rainy days, mother nature will embrace that post like it was one of her own. And you'll never have to worry about a concrete fracture that will let moisture in, but never let it out.
I used to skin cats for a living, so I learned that there's more than one way to do something.
I can not emphasize how stupid I really am
http://www.vicporch.ca
Chris G is offline
The Following User Says Thank You to Chris G For This Useful Post:
Old 04-21-2011, 06:00 PM   #20
John Hyatt
John Hyatt's Avatar
Thanks for the info Fence..
I cant do it right now but I will check out that input and get back to Ya.
J.
Posts Being Closed. BamBamm5144 General Discussion 40 05-22-2010 11:26 AM
Fence posts lifting Emo Decks & Fencing 23 05-05-2010 12:57 PM
rotted deck posts jhcontracting Decks & Fencing 17 04-05-2010 06:08 PM
Pergola 20 ft span bbgcarpentry Carpentry 4 04-02-2010 10:54 PM
