Trade: Porch and Deck Builder
Screw Length For Fastening 2 X Ipe?
You 'mericans have get all the good hardware!
I need to face screw 2 x 6 and 2 x 8 Ipe for strair treads. Up here the longest colour matched stainless screw I can get is a 3" #7. I don't think that's going to hold very well in a pt stringer with only an inch and a half of bite. Do I glue and screw? Any suggestions?
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!" http://www.vicporch.ca Deck Fence Porch Builder Toronto |
John Hyatt
Re: Screw Length For Fastening 2 X Ipe?
Rule of thumb, the fasteners should go into the frame the same leangth of the decking. Sounds like those screws will do that. I always use coustrustion adhesive when puting down ipe decking for a lot of reasons. J.
#3 | |
Insert title
Trade: Doors-Windows-Decks
Re: Screw Length For Fastening 2 X Ipe?Quote:
What brand do you use?
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
John Hyatt
I use liqued nails 490. it is rated for frozen pt lumber.
Insert title
Thanks
Trade: Carpentry Contractor
The 3" length is fine, but normally the guage would be a #8 or #10 for that length screw.
i usually use some deckmaster cut to the length and fastened from below it worked well, but like the others i use pl also.
#8 | |
Trade: Deck Builder
Those screws you got are fine, like Mark said tho, a bigger diameter usually goes with that length. |
usually all, but the last isn't a big deal.
but i learned a trick - if you can reach under to mark the bottom of the tread where it touches the stringer. you can screw the top of the deckmaster into the tread. then screw to the side on the stringer if you have access from the riser. i don't recommend trying to squeeze under from the back of the stringers. ;-) trust me but like the others said - the 3" is probably fine as long as the lumber is not a true 2" thick. |
Uber-Member
Trade: Carpenter...Deck Guy
You could always countersink and plug the holes. That will gain you a 1/2 inch. Plus it's a cleaner look. I recommend buying Ipe plugs though.....your plug cutters will thank you
| Your favorite deck screw | Greg Di | Decks & Fencing | 13 | 02-05-2011 06:12 PM |
| Collated (automatic) Screw Guns | steve-in-kville | Drywall | 18 | 01-31-2009 09:41 PM |
| Auto feed screw guns vs. pneumatic screw nailers | sk8park | Tools & Equipment | 9 | 04-07-2008 11:41 PM |
| Starting another fix someone elses screw up | Frankawitz | Drywall | 6 | 02-19-2007 09:40 AM |
