Sag Free Gate On A Budget - Page 2 - Decks & Fencing - Contractor Talk
Old 06-20-2009, 07:30 AM   #21
General Contractor
greg24k's Avatar
Rewards Points: 7,486
Re: Sag Free Gate On A Budget
These brackets are the best for Trex or heavy gates. Takes 10 minutes to make any size gate and it is sag free. Would never use anything else.
Originally Posted by Five Star View Post
I found these brackets to be the best, and you can make the gates any size you want!
The only thing is the screws that come with the kit are garbage,and should be replaced with deck screws! they cost about $40 for the kit and the hinges are welded on!
takes about 15 min to make a perfect sag free gate!
greg24k is online now
Old 06-20-2009, 12:01 PM   #22
Five Star's Avatar
Rewards Points: 1,010
Originally Posted by DecksEtc View Post
I might be easy but they look like a DIY'er did it AND they look like crap.
Sorry.
Show me your way, and let me see what you consider diy!
i think thats a sweet looking gate i present to my customers! it functions perfectly,looks attractive, and very sturdy, you cant see any unsightly fastners!! and for $40 i cant see doing it any better or faster!
So prove me wrong DECKS ETC. and lets see what your gates look like!
The Bitterness of Poor Quality Remains longer
Than The Sweetness Of A Low Price Is Forgotten
Five Star is offline
Old 06-20-2009, 02:23 PM   #23
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 476
My braces are usually like Jon's, I like to catch all 4 sides of the frame, with my braces.
I don't think that the metal braces look that bad, but it would be nicer if a way could be found to put the 2x2's within the frame.
Here are some gates without braces.
Sag free gate on a budget-bosco-gate-003_red.jpg   Sag free gate on a budget-gate1-red.jpg   Sag free gate on a budget-wind-dbl-gate-red.jpg
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 06-20-2009, 02:28 PM   #24
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
Very nice redwood
Winchester is offline
Old 06-20-2009, 03:43 PM   #25
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Straight up clean work Mark. I am thinking the black hidges on the first picture are decrotive only with daped in hindges swinging the door/gate.
JMO those bracket things are bush league. J.
John Hyatt is offline
Old 06-20-2009, 08:41 PM   #26
davitk's Avatar
Trade: Perfessional Contracter
Rewards Points: 502
I don't build many gates and am no engineer, but what purpose does the second diagonal brace, running bottom hinge to top latch, serve?
This gate is three years old and hasn't sagged a bit.
Please edumacate a bush league carpenter
Sag free gate on a budget-dscn3900.jpg   Sag free gate on a budget-dscn1876.jpg
davitk is offline
Old 06-20-2009, 09:13 PM   #27
John Hyatt
John Hyatt's Avatar
Things just naturaly work better out in the country. J.
The Following User Says Thank You to John Hyatt For This Useful Post:
fez-head (06-21-2009)
Old 06-20-2009, 10:14 PM   #28
I eat sawdust.
Winchester's Avatar
I don't usually put the second one either, but it never hurts to overbuild. Just makes it that much stronger.
Old 06-20-2009, 10:32 PM   #29
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
I love to build gates when I get the chance.
These still were waiting on the latches when I made it over for a snap shot.
Gus Dering is offline
Old 06-20-2009, 10:36 PM   #30
I eat sawdust.
Winchester's Avatar
Impressive!
Old 06-20-2009, 10:43 PM   #31
Tom M's Avatar
Rewards Points: 7,076
Im impressed as well. Nice work Mark & Gus
Tom M is offline
Old 06-20-2009, 11:01 PM   #32
Gus Dering's Avatar
Here is a fairly simple gate I built for our house. It's Halle Berry's window to the world. Sorry she was not available for the photo shoot.
The bottom and top rails are connected to the stiles by way of large "biscuits".
I set the table saw up with 1/4" dado head,8" diameter.
Clamped the part to the fence with the blade down all the way. Then cranked up the blade all the way into the part. Turned it around and did it again so I had 2 biscuits at each joint.
I made the biscuits with some 1/4" stock. Made them a bit small so they didn't screw me during assembly.
Glue and clamps. Pretty easy.
Old 06-20-2009, 11:15 PM   #33
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
Visual symmetry and increased stability for a 5 min. addition...
Mac
BuiltByMAC is offline
Old 06-21-2009, 12:34 AM   #34
Deck Designer/Builder
DecksEtc's Avatar
Rewards Points: 1,000
Ok, here you go...
Sorry you can't see the cross bracing because the gate looks the same on both sides and the cross bracing is inside the outer cedar T&G.
And, in case you're wondering, this project had two of those gates at $3,000 each.
But, you go ahead and keep building your little gates with those brackets - they look AWESOME
I am the liquor - Jim Lahey, Trailer Park Supervisor
DecksEtc is offline
Old 06-21-2009, 12:47 AM   #35
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
awesome work guys
Tom Struble is offline
Old 06-21-2009, 09:49 AM   #36
KemoSabe
loneframer's Avatar
Rewards Points: 12,214
Originally Posted by JonM View Post
Nope...90 degrees is 90 degrees no matter square or rectangle....
90 degrees is the constant. You can still center the crossbuck by altering the angles 53/37 for example, so that the buck contacts rail and stile equally, no matter the height/width differential
loneframer is offline
Old 06-21-2009, 10:00 AM   #37
Five Star's Avatar
Ok, here you go...
decks etc. although its a nice gate you built there for 3k. i was talking $40 brackets..LOL.
i think for stability and sturdiness, you cant go wrong with those brackets!
show me a little deck gate you built! so we can compare apples to apples
the gate i posted was a simple composite deck, the gate was thrown in as a favor ! so i think it looks and works well ,with out digging deep into my pockets!
if the customer asked me for a custom gate like yours, i would of been happy to oblige, and considered other hinge options!
Old 06-21-2009, 10:00 AM   #38
genecarp's Avatar
Ok, here you go...
I think you guys are comparing apples to oranges. 5star is talking about a quick $300 deck gate, while you are displaying $3000 gates. There are many jobs and many budgets, and a place for both systems. G
genecarp is offline
The Following User Says Thank You to genecarp For This Useful Post:
Five Star (06-21-2009)
Old 06-21-2009, 10:29 AM   #39
DecksEtc's Avatar
Perhaps, but he asked to see a picture of a gate I built so I obliged him.
This is boiling down to a difference is personal taste. I never said that those brackets don't work, I was just taught to never use them and I persoanlly think they look terrible.
We'll have to agree to disagree 5star.
BTW, those bracket kits are only $20 here in Canada.
DecksEtc is offline
Old 06-21-2009, 10:37 AM   #40
KemoSabe
loneframer's Avatar
Overkill maybe, but with the crossbuck design when weight is applied to the active side of gate, for example a child hanging/swinging on the gate, while the one brace is under tension, the other is in compression. If properly fastened, this gate is indestructable.
The Following User Says Thank You to loneframer For This Useful Post:
nj handyman (06-21-2009)
FREE 30 Hour Osha Training Course Schedule, Sponsored By NRCA..... Ed the Roofer Health & Safety 2 04-17-2009 08:36 PM
