Sag Free Gate On A Budget
Old 06-19-2009, 02:38 PM   #1
curapa's Avatar
Trade: Carpentry / Fencing / Decks
I figured I would post these instructions on how to build a sag free gate on a budget. I am tired of seeing crappy gates all over the place that are falling apart. The gate doesn't take very long at all to build and it is very inexpensive.
I start by mitering the the tops and sides and putting one screw in each corner to hold them in place, then I lay my first diagonal across and mark the cut. I always run the diagonals from the bottom side to the upper top.
I then lay another diagonal mirroring the one previously set into place. I mark both of the angles at the ends and the angles at the overlap on both boards.
Sag free gate on a budget-img00002-20090619-1042.jpg   Sag free gate on a budget-img00001-20090619-1042.jpg   Sag free gate on a budget-img00003-20090619-1042.jpg
www.ParkerFenceandDeck.com
curapa is offline
Old 06-19-2009, 02:40 PM   #2
curapa's Avatar
Re: Sag Free Gate On A Budget
I then notch the two diagonals to accept each other.
Sag free gate on a budget-img00005-20090619-1043.jpg   Sag free gate on a budget-img00007-20090619-1045.jpg   Sag free gate on a budget-img00008-20090619-1046.jpg
curapa is offline
Old 06-19-2009, 02:42 PM   #3
JonM's Avatar
Do we get to see how to build a birdhouse next?...........
JonM is offline
Old 06-19-2009, 02:44 PM   #4
curapa's Avatar
I set both diagonals back into place and start screwing the gate together. I put two toe-screws at each joint (on larger gates I add PL to the joints). Flip the gate over and repeat the screwing process.
Sag free gate on a budget-img00009-20090619-1059.jpg   Sag free gate on a budget-img00010-20090619-1101.jpg   Sag free gate on a budget-img00011-20090619-1108.jpg
curapa is offline
Old 06-19-2009, 02:45 PM   #5
curapa's Avatar
Finish the gate off using a good set of 8" strap hinges.
curapa is offline
Old 06-19-2009, 02:47 PM   #6
curapa's Avatar
It's really sad that this is actually something that many people need to see.
curapa is offline
The Following User Says Thank You to curapa For This Useful Post:
nj handyman (06-21-2009)
Old 06-19-2009, 02:47 PM   #7
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Is that one RHS or LHS?
willworkforbeer is offline
Old 06-19-2009, 02:52 PM   #8
Professional Instigator
rbsremodeling's Avatar
Stanley sells a kit for that
rbsremodeling is offline
Old 06-19-2009, 02:59 PM   #9
curapa's Avatar
Those things do not work and thay are not cheap.
curapa is offline
Old 06-19-2009, 03:08 PM   #10
JonM's Avatar
Shouldn't the ends of the cross members have double 45's so they catch both the horizontal and the vertical sides of the frame?...
JonM is offline
The Following User Says Thank You to JonM For This Useful Post:
Darwin (06-19-2009)
Old 06-19-2009, 04:46 PM   #11
TimelessQuality's Avatar
Trade: GC/Remodeling
looks like your guard is stuck on your saw
I've built a few like that...
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
Last edited by TimelessQuality; 06-19-2009 at 06:30 PM. Reason: spelled moor bedder
TimelessQuality is offline
Old 06-19-2009, 06:09 PM   #12
strat hd
strathd's Avatar
Trade: framing contractor , remodeler , GC occasionally
I'm sure some people will benefit from this thread Curapa. Cool post.
strathd is offline
Old 06-19-2009, 06:46 PM   #13
John Hyatt
John Hyatt's Avatar
I could not agree with you more,thanks man. I build them the same way with out the dap out. Con adhesive and ss screws its the x diagonal that makes it work along with roller bearing hindgs. I see those total crap gates all the time as well. Go Get Em!!! and thanks again. JonMon
John Hyatt is offline
Old 06-19-2009, 07:20 PM   #14
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Nice.
But personally, nothing beats one of those $60.00 date frame kits. Put one on my 48" wide cedar gate 9 years and go and the thing still closes absolutely true.
Mike Finley is offline
Old 06-19-2009, 09:05 PM   #15
Five Star's Avatar
I found these brackets to be the best, and you can make the gates any size you want!
The only thing is the screws that come with the kit are garbage,and should be replaced with deck screws! they cost about $40 for the kit and the hinges are welded on!
takes about 15 min to make a perfect sag free gate!
The Bitterness of Poor Quality Remains longer
Than The Sweetness Of A Low Price Is Forgotten
Five Star is offline
Old 06-19-2009, 11:52 PM   #16
Deck Designer/Builder
DecksEtc's Avatar
I might be easy but they look like a DIY'er did it AND they look like crap.
Sorry.
DecksEtc is offline
Old 06-20-2009, 01:43 AM   #17
BuiltByMAC's Avatar
Trade: Construction
nope. cranbrook2 took care of that...
http://www.contractortalk.com/f30/ex...ood-pics-5591/
only if the gate were a perfect square... otherwise, their angles would depend on the width/height of the gate.
seems like a decent way to solidify the joint to me...
Good thread, Curapa...
I would think, in addition to the toe screws, dropping 6" HeadLocks into predrilled holes (marked in red) would help prevent too much twisting in the pt material.
No offense to the bracket users but a deck pro can build 'em true and strong w/o metal brackets -
Mac
BuiltByMAC is offline
Old 06-20-2009, 07:55 AM   #18
JonM's Avatar
Mac
Nope...90 degrees is 90 degrees no matter square or rectangle....
JonM is offline
Old 06-20-2009, 08:06 AM   #19
Working
Cole82's Avatar
Send a message via AIM to Cole82
Sorry built by mack is right here.
If your gate was 4'x8' and you did the crass brace as you showed it would only go to the center 4' mark.
Cole82 is offline
Old 06-20-2009, 08:23 AM   #20
JonM's Avatar
Yep...my bad...
JonM is offline
FREE 30 Hour Osha Training Course Schedule, Sponsored By NRCA..... Ed the Roofer Health & Safety 2 04-17-2009 09:36 PM
