Rubber Membrane Behind Ledger On Stucco?
I was reading in the last issue of Deck Magazine about flashing a ledger on a stucco house. One contractor said sometimes instead of cutting away the stucco, he'll just put a rubber membrane directly on the stucco and attach the ledger over that. I'm thinking long term this method may actually have less chance of water pentration than the traditional methods. Has anyone ever tried this?
I have a deck I'm about to start on a stucco home with about 70' of ledger, I'm thinking of trying this "new" method. If I do, I'm planning on taking a belt sander and knocking down the high spots and sharp edges of the stucco so the membrane would adhere better. I'd obviously still run a generous bead of sealant on the top and edges of the ledger. What do you think, and any suggestions as to what type/brand of membrane to use? |
cdac
Guest
Posts: n/a
Re: Rubber Membrane Behind Ledger On Stucco?
Is this a 2nd story deck or ground level?
#4 | |
Re: Rubber Membrane Behind Ledger On Stucco?Quote:
Chris, Thanks for input, I think you explained that to Kevin here once before, but it didn't click until now. Question: is that York flashing you use self-adhesive? Thanks again for the help--I'll buy you a drink at the Expo in two weeks. I'll PM you later with my cell #. |
#5 | |
Seventy feet of deck has the potential to hold a LOT of people which in turn is a LOT of weight. |
Cut the stucco and remove where ledger will attach. Put 'grace' ice and water shield along area that stucco was removed.Slip metal flashing ( z flashing style ) behind stucco ( hard but possible. ) then over wood ledger Lag bolt/ lag screw the ledger into the building. This is the way I did my home, although not stucco.
On the bottom one could always put the same type of flashing as on top, on the bottom as well. ( behind the wood ledger then over the stucco ) If this makes any sense. |
#7 | |
Good thought--a collapse is a deck builder's worst fear. Although I do have 70' of ledger, about 40' of that is related to walkways, not large decks. I have access to the basement, so I'll be bolting the ledger to the house band. The house band is 1 1/8" timberstrand, which I'm not a huge fan of, but I'll be adding additional support from the inside. Thanks for all the comments. |
| 1 coat vs. 3 coat stucco finishing | janrickey | General Discussion | 12 | 07-17-2011 11:22 AM |
| Ledger board on stucco house - cut or drill? | Kevin | Decks & Fencing | 11 | 05-02-2010 08:09 PM |
| deck over rubber roof | smokepole | Decks & Fencing | 20 | 04-03-2009 02:48 PM |
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Some questions about painting outside stucco?? | Zeebo | Painting & Finish Work | 10 | 09-20-2006 08:09 AM |
