Removing Decking Boards?
Old 01-25-2010, 07:01 AM   #1
AndersonsWworks's Avatar
Trade: Custom Cabinetry
Rewards Points: 75
This might be a dumb question and may have been answered before but.... is there a tool to pry up and remove 5/4 decking boards from the joists? I am talking about boards that have been air nailed in, not screwed obviously. I am considering taking my rather large deck apart and reconfiguring it and I don't want to do unnecessary work if I don't have to. Thanks for any info!
AndersonsWoodworks.com
AndersonsWworks is offline
Old 01-25-2010, 07:16 AM   #2
IHI's Avatar
Rewards Points: 1,040
Re: Removing Decking Boards?
Yep, they have crowbars where one end has 2 ends on it...looks like the letter U per say. You set the fulcrum point on the joist and the crow bar ends get under the decking boards on both sides of the joist, you push down, it lifts them up....works very well for stripping lathe off old studs too if your trying to keep the lathe into long, easy to pick up pieces.
Here's one style to get the point across, called a "Deck Wrecker"
IHI is offline
Old 01-25-2010, 07:18 AM   #3
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
What do plan to do with removed boards, garbage? If so cut boards into smaller pieces first
I cut in-between the bays every 32”, pry up your first row or two with a flat bar, then grab two 2x4’s, rest one 2x4 on the opened beams and use the other to pry up the boards.
You’re using the 2x4 across the open beams for a leverage point.
This method is now patented by me, so please send me 1k for rental usage
festerized is offline
Old 01-25-2010, 07:20 AM   #4
Rewards Points: 75
Thanks IHI, that's exactly what I was looking for! Someone told me there was such a tool but I did not know what it looked like or what it was called. Thanks again!
Old 01-25-2010, 07:23 AM   #5
Rewards Points: 75
Thanks Festerized, I will keep the "rental fee" in mind. I was planning on reusing as many of the boards as possible. This may not work out but we will see.
The Following User Says Thank You to AndersonsWworks For This Useful Post:
festerized (01-25-2010)
Old 01-25-2010, 07:52 AM   #6
hailey's Avatar
Trade: vinyl decks and fence
Rewards Points: 150
once you get the first board off , a long 2x4 on edge between the deck board and the prior joist works quicker than anything I know...and to most it's free.
hailey is offline
Old 01-25-2010, 07:57 AM   #7
Master-Pro-Plus
GregC's Avatar
Trade: Master Plumber/Pipefitter,General Contractor, Plus
Rewards Points: 75
Chain saw still the best! Thats if you are not trying to save them. Less stress, let the chain saw do the work. Now if you are trying to save the boards, then that bar works great. GregC
GregC, www.gjcicionegeneralconstruction.com
GregC is offline
Old 01-25-2010, 08:06 AM   #8
Joe Carola's Avatar
Rewards Points: 1,012
Take a couple rows off first and then take a 6' 2x4 and nail a 2' piece to flat to the 1-1/2" side of it about 1' in (looks like a t )and lay the 2' piece on the joist and stick the 1-1/2" edge of the 6' 2x4 under the deck board and pry up. It pops right up. I do this all the time and do this when ripping sheathing with shingles on off rafters.
Joe Carola
Joe Carola is offline
The Following User Says Thank You to Joe Carola For This Useful Post:
eXpatRioteX (01-25-2010)
Old 01-25-2010, 08:07 AM   #9
deckman22's Avatar
Trade: Deck Builder
Rewards Points: 5,594
That's what I do, sometimes a 2x6 tho for boards that are holding more.
If it's screwed, then cut it up into little pieces. Works faster than fooling around trying to unscrew boards.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 01-25-2010, 09:01 AM   #10
Rewards Points: 75
Thanks guys for all the super ideas!
Old 01-25-2010, 10:36 AM   #11
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
What are you going to do with the decking boards......?
Here's what I did. I needed to finish off the skirt on my deck. I ripped all the 5-1/2" to 2-1/2" and made a classic vertical skirting. Recycling at it's best!!
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 01-25-2010, 10:58 AM   #12
David Festa
festerized's Avatar
nice idea
The Following User Says Thank You to festerized For This Useful Post:
tcleve4911 (01-25-2010)
Old 05-15-2014, 11:43 AM   #13
bwhomeimprvmnts's Avatar
Trade: Construction/Remodeling
I have been looking for a deck removal tool. Any of you guys heard of a Demo-Dek? I saw some guy walking around the JLC live 2014 show. I lost his card but I think thats what it was called, it looked pretty badass.
bwhomeimprvmnts is offline
Old 05-15-2014, 07:14 PM   #14
Talking Head
EthanB's Avatar
Rewards Points: 24
Greg Di mentions a couple in this article. Which is awesome, btw.
http://www.toolsofthetrade.net/decks...ool-kit_1.aspx
Planer.....
EthanB is offline
Old 05-16-2014, 07:52 AM   #15
This was something new to the market and worked different than anything else. It was basically a giant lever you hooked on the board and ripped it out with one motion, it looked like you worked on and pulled towards the decked area.
I am super familiar with all those tools, we both know Gregs articles well
I want the newest nastiest toooools!!! Those others always left me feeling like something was to be desired. If anyone knows any more hook a brother up!!
Old 05-16-2014, 08:03 AM   #16
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
use your lull or lift you can do 32 inches at a time
pappagor is offline
Old 05-16-2014, 08:04 AM   #17
I went back through my JLC emails. this is what i saw:
http://www.deckmagazine.com/videos/d...mo-dek/2126097
Old 05-16-2014, 08:04 AM   #18
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
I think this what you're looking for, I don't have one yet but I hope to very soon.
http://www.greentektools.com
RobertCDF is offline
Old 05-23-2014, 12:31 AM   #19
GC/carpenter
Californiadecks's Avatar
Rewards Points: 6,050
I just ordered one. They are on sale for a hundred bucks. I will let you guys know how it works. I figure why not? 80% of all my jobs include demoing an old deck.
Sent from my SM-T520 using Tapatalk
Californiadecks is online now
Old 05-23-2014, 06:05 AM   #20
jb4211's Avatar
Rewards Points: 2,306
I have the deck wrecker and I think it's an awesome tool. Doesn't matter if the boards are nailed it screwed, this will pull the boards right up.
I did a deck which the boards were screwed, this tool pulled the boards up leaving the screws and the framing intact. I went back with as lazer blade and just cut 'em flush.
Duckbill Deck Wrecker
Jon
jb4211 is offline
Decking and Mosquitos Morning Wood Decks & Fencing 23 01-08-2010 11:31 PM
new tigerwood deck -- boards with fuzz, green-yellow tint? andywocky Decks & Fencing 32 08-20-2009 03:10 AM
Eon Decking Availability Buckeye1976 General Discussion 3 07-08-2009 12:49 PM
Preference in the Way your Decking Boards Turn jcalvin Decks & Fencing 25 03-12-2009 01:01 PM
Removing existing decking Oregon_Rob Decks & Fencing 13 04-15-2006 09:37 AM
