Remove Scuff Marks On Vinyl Railing
Old 05-24-2010, 08:14 AM   #1
dvatt's Avatar
Rewards Points: 380
Do you guys have any products that will remove marks on vinyl railing? Acetone?
dvatt is offline
Old 05-24-2010, 08:37 AM   #2
Railman's Avatar
Trade: Railing
Rewards Points: 459
Re: Remove Scuff Marks On Vinyl Railing
Acetone might be hot enough to melt vinyl. I'd start with Naptha (lighter fluid), alchohol, laquer thinner, in that order. Be very carefull with the laquer thinner though. It also melt some plastics.
Other options might be xylene, or toulene. Although not as hot, they evaporate slower, & give more time to loosen marks.
Always test on small inconspicuous area first.
Joe
Railman is offline
Old 05-24-2010, 09:45 AM   #3
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Rewards Points: 2,022
Clear PVC primer like the plumbers use.
PRACTICE on a sample wiping it on and off.....it cleans really quick and then it will eat the vinyl if you do not wipe it off.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 05-24-2010, 09:54 AM   #4
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,984
At the auto parts store / auto body: Polishing compound on a rag with some water. Rubbing compound is next choice. Its quite a bit more abrasive.
Also try Wesley's whitewall cleaner. This is what cleans up that OSI butyl caulk the window guys use.
We Fix Houses is offline
Old 05-24-2010, 08:10 PM   #5
Remodeling Professionals
buildenterprise's Avatar
Trade: New Construction and Remodeling Contractor
Rewards Points: 502
Forget all the above, and use Mr. Clean Magic Eraser. They don't call it magic for nothing. Works every time.
buildenterprise is offline
The Following 3 Users Say Thank You to buildenterprise For This Useful Post:
festerized (05-24-2010), griz (05-24-2010), ROVACON (07-12-2010)
Old 05-24-2010, 08:53 PM   #6
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,722
Yup, magic eraser.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 05-24-2010, 08:55 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 1,784
Originally Posted by WarnerConstInc. View Post
Yup, magic eraser.
WTF? Festool doesn't make a tool for this. You have to be kidding. You could have at least recommended using some green Koolaid with it.
griz is online now
Old 05-24-2010, 09:09 PM   #8
I like Green things
You can smoosh it into the pad on my rotex and use it that way.
I think they may, we just can't get it here.
Warner Mill Works
Facebook
YouTube
griz (05-24-2010)
Old 05-24-2010, 10:36 PM   #9
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
I use rubbing alcohol to clean acrylic. Xelene for scuffs, paint splatters, light scratches. But be careful, takes off the finish too. Use too much and you'll have to buff to get shine back.
Guilford, CT Remodeler and Carpenter Web-site Twitter@CraftsmanJay
Facebook
The great use of life is to spend it for something that will outlast it.
William James is offline
Old 07-12-2010, 09:53 AM   #10
Rewards Points: 2,000
I know this is an old thread but,
My go-to first choice is always
a white gum eraser.
Pretty good for pencil marks
on painted walls too.
neolitic is offline
Old 07-12-2010, 01:50 PM   #11
remster's Avatar
Trade: General Carpentry
Rewards Points: 25
Try detnatured alcohol, test in hidden spot first.
remster is offline
Old 07-12-2010, 06:14 PM   #12
Cjeff's Avatar
Trade: Renovations
I have found the magic eraser very abrasive. Will remove paint on a wall for example. I first use Vim with bleach. If that does not work, then a magic eraser.
Cjeff is offline
Old 07-12-2010, 08:20 PM   #13
Ashcon's Avatar
Trade: Renovation contractor, finish carpenter
jig*loo (ie. silicone spray)
Worked for us on some white vinyl siding with some shingle scuffs.
It all got cleaned up!
Ashcon is offline
vinyl siding and railing separated enforcer Windows, Siding and Doors 3 01-05-2010 07:55 PM
Vinyl fencing as railing PA woodbutcher Decks & Fencing 10 05-22-2009 11:47 AM
how to remove vinyl lettering on trucks marc Marketing & Sales 10 11-10-2008 12:28 AM
Fairway Vinyl Railing Kevin75 Decks & Fencing 7 06-26-2008 10:51 PM
Vinyl railing Mcdonoughman Decks & Fencing 2 03-16-2008 05:11 PM
