Railing Heights
Old 09-28-2009, 02:07 AM   #1
redwood's Avatar
Trade: Carpentry Contractor
Railing Heights
It has been mentioned to me twice in the last week that minimum railing heights for decks is now 42". I thought that it was 36" for residential and 42" for commercial.
Can anyone confirm or deny this? I know, ask your building Inspector.
I work in many municipalities, and they go by different codes, but most use the 2006 IRC.
Have later additions of the IRC increased the height requirements?
Thanks
Mark
Los Gatos, CA
www.creative-redwood-designs.com
redwood is offline
Old 09-28-2009, 07:31 AM   #2
Fine Deckbuilder
Clemens's Avatar
Trade: Deck business
Re: Railing Heights
This fall IRC 2009 is coming out. I haven't heard the increase in railing height yet. I will have to check it out.
Clemens
Clemens is offline
Old 09-28-2009, 09:59 AM   #3
deckman22's Avatar
Trade: Deck Builder
Re: Railing Heights
I just passed inspection on a 2nd story deck w/36" rails.
Deckman
www.alscustomdecks.com
deckman22 is online now
Old 09-28-2009, 11:07 AM   #4
mics_54's Avatar
Trade: contractor
Re: Railing Heights
36" minimum guards on a deck is code in 2006 irc
34-38 on stairs
why would commercial code be in the irc?
mics_54 is offline
Old 09-28-2009, 11:53 AM   #5
redwood's Avatar
Re: Railing Heights
We are working for a very nice, paranoid couple. The lady can't sleep at night, worrying about details.
The deck is done, except for the rails and balusters themselves. Posts are in, rails are cut with connectors installed for aluminum balusters. We had to hold off, because the owners decided they wanted a higher railing. Our posts were a few inches long, because we are adding post caps. I had to reorder longer balusters, to increase the height another 2 1/2", that we could squeeze under the post caps.
On the steps, there will be a metal graspable handrail. The iron contractor told me that he thought railings had to be 42". Then I get a call from the owner, last night, questioning the same thing. In 30+ years of building decks, I can only think of 1 or 2 times that we put up a railing of 42" on a residence.
Sorry to say, the owners did not want building permits. Long story, but not unusual, where I work. Think $ 6000+, for permits and engineering.
Mark
Los Gatos, CA
redwood is offline
Old 09-28-2009, 12:17 PM   #6
mics_54's Avatar
Trade: contractor
Re: Railing Heights
there is no maximum height on guard rails on an elevated platform except that dictated by the owners bank account. On stairs there is a maximum 38" height on the handrail. The minimum height on a platform guard rail is 36" and 34" on stair handrail.
mics_54 is offline
Old 09-28-2009, 07:03 PM   #7
I builds'em
Winchester's Avatar
Trade: Renovations & Decks
Re: Railing Heights
42" here
Winchester is offline
Old 09-28-2009, 07:40 PM   #8
SDC's Avatar
Re: Railing Heights
Don't take offense but you say a paranoid couple and worry about details then say they don't want a permit??? Can't be to worried about details....
David Cookman
SDC is offline
Old 09-28-2009, 07:49 PM   #9
Jeff
jkfox624's Avatar
Trade: master turd burglar
Re: Railing Heights
I hope to god not, 42" is gonna look like hell alot of times imo. Porch with a beam height at say 7' and half of the open space is railing is gonna be all out of proportion. Even 36" covers alot of windows on older houses and it looks bad.
jkfox624 is offline
Old 09-28-2009, 08:05 PM   #10
Sean
SLSTech's Avatar
Re: Railing Heights
Redwood - your thoughts are correct for most of the country (one caveat is multi family places are also 42")
The catch gets to be what your local Building department requires - personally on my decks I just spec & install 42" railings
SLSTech is offline
Old 09-28-2009, 09:43 PM   #11
deckman22's Avatar
Trade: Deck Builder
Re: Railing Heights
I think the steel guy was used to working on commercial jobs where 42" is required, must have said something to HO.
I have at times done rails @ 42", on the really tall ones.
Deckman
Old 09-28-2009, 09:48 PM   #12
redwood's Avatar
Re: Railing Heights
To a certain extent, the deck is probably over built. 4x12 PT fir joists on 16" centers, all covered with grace "deck protector". 6x10 PT beams, spanning 6'. Footings are 8' deep (no frost line here), ect.
We are in earthquake areas. The building departments are scared, so they require everyone to have their decks engineered (soils and structural). I had one client spend $ 9000 before any work was done and the county wanted more. He pulled the plug on the project.
People in my area are fed up with the red tape and hoops that the planning and building departments make you go through. As you may or may not know, a permit does nothing for assuring quality, all it does is set minimum standards for construction spans and now adds a lot of hardware.
Mark
Los Gatos, CA
redwood is offline
Old 09-28-2009, 10:00 PM   #13
deckman22's Avatar
Trade: Deck Builder
Re: Railing Heights
Why does it cost so much for engineering? The one I just got my final on required engineer's letter for stucture & foundation, cause I used existing concrete patio instead of footings, & permits & engineer's letter was less than 400.
With those kinds of extra cost no wonder folks are trying to evade the permit man.
Deckman
Old 09-28-2009, 10:17 PM   #14
mics_54's Avatar
Trade: contractor
Re: Railing Heights
He's on the left coast...nanny gubmint country.
mics_54 is offline
Old 09-28-2009, 11:17 PM   #15
redwood's Avatar
Re: Railing Heights
The soils engineering requires a crew to come out and drill for soil samples. Then off to the lab for analysis. The engineer then specifies 20' deep footings (to get past the ancient slide area). The structural engineer then designs the deck with every item available from the Simpson Catalog.
I primarily work in a somewhat hilly/mountainous area, with known earthquake faults nearby (San Andreas). Everyone is scared of the liability of failure. Perhaps, rightfully so. There are a lot of lawyers in the area.
Mark
Los Gatos, CA
redwood is offline
Old 09-28-2009, 11:31 PM   #16
mics_54's Avatar
Trade: contractor
Re: Railing Heights
No wonder a refrigerator box is a million dollars in SoCal
mics_54 is offline
Old 09-29-2009, 06:36 AM   #17
Charitable animal
Bone Saw's Avatar
Trade: decks
Re: Railing Heights
along those same lines, seepage beds and stormwater management tables for decks is for the birds
Bone Saw is offline
Vinyl fencing as railing PA woodbutcher Decks & Fencing 10 05-22-2009 12:47 PM
header heights coupe33 Framing 14 03-29-2009 01:17 AM
low maintenance railing Hotrodhall Construction 0 12-23-2008 03:40 PM
off topic --Roller coasters-afraid of heights davinci Off Topic (Non Trade) 16 10-27-2008 07:42 PM
Hiring Painters Northeast Ohio welovepainting Help Wanted or Looking For Work 0 03-04-2008 05:53 PM
