Rail Height
Old 12-18-2006, 08:46 PM   #1
bright star's Avatar
Trade: general/ 874135
Rail Height
what is the code for rail hight on a sceond story deck, this is a silly ? i should know but my brains not working, i'm in L.A. , thanks!
bright star is offline
Old 12-18-2006, 09:03 PM   #2
Teetorbilt's Avatar
Re: Rail Height
You have to know your LOCAL codes. There is probably someone on here from L.A. that can help you. Give it some time.
Albert Einstein
Teetorbilt is offline
Old 12-19-2006, 08:38 PM   #3
Deck Designer/Builder
DecksEtc's Avatar
Re: Rail Height
For my surrounding area it's 42" for a second level deck. But, like Teetor said, you should really check your local codes. A quick, anonymous phone call to your local building department should have someone tell you in about 30 sec. over the phone.
DecksEtc is offline
Old 12-19-2006, 08:54 PM   #4
Thom
thom's Avatar
Re: Rail Height
the IRC says 36". Obviously that's residential. Commercial (IBC) is 42". This assumes you use the I codes where you are.
thom is online now
Old 12-19-2006, 09:00 PM   #5
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Re: Rail Height
Funny thing about Cali is they are in love with the UBC. More than likely modified.
JustaFramer is offline
Old 12-20-2006, 01:20 AM   #6
Thom
thom's Avatar
Re: Rail Height
Don't know about California modifications to the UBC but prior to our being on the I codes we used the UBC here in NM. Same requirement, 36" residential, 42" commercial.
I believe the I codes were built on the UBC.
thom is online now
Old 12-20-2006, 08:37 AM   #7
Priced In
Re: Rail Height
ICC thought up the I codes. UBC was another council. However the I codes are thought up by a international council so as I have noticed nothing really changed between IRC and UBC except new seismic standards for building practice's.
And as far as I know they will not be revising the UBC. So Cali will have to do that on there own.
EasAlign rail bolt system ? karma_carpentry Finish Carpentry 10 03-10-2008 09:03 AM
Cut A radius in a top rail? ecooke21 Decks & Fencing 2 07-25-2007 10:10 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
water pump section height ? Vermonster Plumbing 1 06-23-2006 07:29 AM
California Building Codes for Chimney Height vawn Construction 5 05-22-2006 08:49 AM
