Raiing Code
Old 08-07-2008, 07:32 PM   #1
General Contractor
Laketahoedan's Avatar
Raiing Code
I know that railing now needs to be 42" to top of top cap.
What about railing going down stairs?
I suppose the grab rail still needs to be 34-38" but what about the top cap?
And is it ok if there is more than 4" from bottom of bottom rail to the inside corner of tread and riser?
ty
Laketahoedan is offline
Old 08-07-2008, 08:39 PM   #2
andy builds's Avatar
Trade: Finish Carpentry and Remodeling
Re: Raiing Code
Depends on your local code/inspector... your better off checking with them, some areas don't update for years depending on where your at...
andy builds is offline
Old 08-07-2008, 09:26 PM   #3
BuiltByMAC's Avatar
Trade: Construction
Re: Raiing Code
Based on my code requirements in OR,
handrail height on stairs shall be not less than 30" and not more than 38" from nose of tread -
Handrail is defined as a graspable rail (this is your grab bar)
Guardrails shall have a height of not less than 36" (these are the regular handrail sections that can't have more than a 4" opening)
Triangular opening formed by the riser, tread and bottom rail of a guard to be of a size where a 6" sphere cannot pass through.
Now that I've said all that, as andy stated above, what's code for Tahoe? A call, or visit, to your city's planning and development dept. will clear up those location specific code questions for you...
Mac
BuiltByMAC is offline
Old 08-07-2008, 10:43 PM   #4
mickeyco's Avatar
Trade: Squirrel Handler
Re: Raiing Code
Mac
Continuous?
mickeyco is offline
Old 08-07-2008, 10:59 PM   #5
redwood's Avatar
Trade: Carpentry Contractor
Re: Raiing Code
The requirements where I work in Ca. are the same as Mac's. Commercial railings need to be 42".
Mark
Los Gatos, CA
www.creative-redwood-designs.com
redwood is offline
Old 08-07-2008, 11:05 PM   #6
BuiltByMAC's Avatar
Trade: Construction
Re: Raiing Code
Originally Posted by mickeyco View Post
Continuous?
Yeah, I could go on and on and on..........
but I got bored and went to another thread!
Mac
Old 08-08-2008, 09:12 AM   #7
mt_42's Avatar
Re: Raiing Code
On a somewhat related note, has anyone every seen/built a railing without inner/corner posts? My neighbour just had a deck built around their pool and with the exception of the single posts on either side of the stairs, the rest of the railing (roughly 40 ft wrapping around 3 sides of the deck) is entirely supported by the 2x2 ballusters face nailed into the fascia boards/joists.
Mike
mt_42 is offline
Old 08-08-2008, 09:24 AM   #8
Thom
thom's Avatar
Re: Raiing Code
MT, I did one like that that looked really cool. It was just the stairs.
The stairs were "U" shaped stairs parallel to the balcony/deck, going up to a second story balcony., with 1-1/2" space between the upper and lower portions of the stair.
The 2X2's ran from 4" above grade to the top rail on the perimeter, from the lower stringer to the top rail on the center rail. There was a 2X4 screwed to the 2X2's at the ground level to keep them properly oriented.
It looked really nice, the owners loved it.
thom is online now
Old 08-09-2008, 11:16 PM   #9
orionkf's Avatar
Trade: Hardscape
Re: Raiing Code
Decks done by the builders around here seem to always be that way.
orionkf is offline
Old 08-10-2008, 03:16 PM   #10
orson's Avatar
Trade: Kitchen & Bath
Re: Raiing Code
I personaly consider that to be a substandard "builder grade" method of railing construction. There is no structural connection of the railing to the deck.
On a more practical note, how do you sweep the deck off?
orson is offline
Old 08-14-2008, 09:16 PM   #11
Low Voltage Contractor
ChillaWatt's Avatar
Trade: C-7
Re: Raiing Code
ty
Hey Dan, you do any work for Squaw Valley? Love it up there. If you have a hard time contacting a local inspector the lumberyards in your area will usually know the local codes.
ChillaWatt is offline
Old 08-14-2008, 09:21 PM   #12
deckman22's Avatar
Trade: Deck Builder
Re: Raiing Code
Yeah, I see them all the time on redo jobs. Crappy/cheap way to do a deck rail imo. Makes for an easy demo job tho, ha.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 08-14-2008, 09:27 PM   #13
Motorboatin' son of a ...
BKFranks's Avatar
Re: Raiing Code
http://www.arcways.com/pdfs/IRC2006.pdf
BKFranks is offline
Old 08-14-2008, 11:01 PM   #14
Deck Designer/Builder
DecksEtc's Avatar
Re: Raiing Code
That's what I refer to as "builder's railings". When doing consultations, I tell potential customers that I flat out refuse to build those type of poor excuse for railings. As long as the baluster spacing is min. 4", they pass code. I can't understand why, but they do. Aside from all that, I think they look like crap.
DecksEtc is offline
Did you Know CA Laws on License + Unlicensed Contractors eagleandbaby Contractor Licensing 65 03-27-2010 11:44 PM
2 questions - one code, one structural karma_carpentry Decks & Fencing 5 09-10-2006 02:55 PM
