Radiance Rail Attachment To Column
Old 10-04-2009, 08:17 PM   #1
The Deck Guy
Greg Di's Avatar
Anyone ever attach Radiance to a 10" ROUND column?
I'm not so sure it will work straight out of the box with standard hardware but maybe I'm wrong.
Anyone?
Greg Di is offline
Old 10-04-2009, 09:20 PM   #2
John Hyatt
John Hyatt's Avatar
Re: Radiance Rail Attachment To Column
Not Radiance/ TT product but I did conect ipe 5/4 to a composite 12'' round colomn with a jig saw and a pattern for the cut. It involved a 3'' shop made plug I drilled thru taped the plug in clear into the hollow colomn with tightbond 111 pluged the holes with a standared ipe plug.
I held the damm things tight with a band clamp,like the ones the Bone uses, and it was a real Pain!! Not any real movement down the road the long plugs were at somewhat of a 90 into the colomns.
I cant see any hardware working for your thing unless you had it custom made but you could use a plug or something like it and cover the hole with one of those pound in composite plugs that seem to work ok. J.
John Hyatt is offline
Old 10-05-2009, 01:48 AM   #3
BuiltByMAC's Avatar
Trade: Construction
Hollow column? Can you get blocking inside it?
Maybe a toggle bolt set up would be a solution...haven't done it, just thinkin' out loud. Something to spread that load around the fiberglas w/o opening up the side too much.
Mac
BuiltByMAC is offline
Old 10-05-2009, 06:43 AM   #4
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
We've done it-
Cut it a bit long, then use a belt sander to chew out a bit of the rail, to compensate for the curve.
Use the hardware, and perhaps add some adhesive inside the H channel- and silicone along the cap rail/column line...
HTH,
~Matt
BreyerConstruct is offline
Old 10-05-2009, 04:14 PM   #5
Fine Deckbuilder
Clemens's Avatar
Trade: Deck business
Endurance railing makes a connector for in between the column (with a contour on one side for the column and a flat side on the other side for the attachment of the railing.
It is a little hard to see but if you look at the column/railing attachment you will see that piece in between.
Clemens
Clemens is offline
Old 10-05-2009, 04:24 PM   #6
Man you do some sweet stuff!
~Matt
Old 10-05-2009, 07:22 PM   #7
The Deck Guy
Greg Di's Avatar
We are attaching to a hollow aluminum column. I just can't see the stock hardware working on a curved surface.
It may just be easier to make some sort of mounting block as its just one column and one connection.
Greg Di is offline
Old 10-05-2009, 11:59 PM   #8
deckman22's Avatar
Trade: Deck Builder
Just had a thought looking at the fine work of Clemens.
Not trying to blame you for my dumbarse thought here.
You could put a regular post next to the column. Might look ok, might not.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 10-06-2009, 12:18 AM   #9
for making a mount: Get yourself a thick piece of Azek. Rout it out as much as needed, and glue it to the post, rounding the edges of your Azek block slightly.
Mount to that, replacing the railing screws with longer ones that will extend into the columns.
We did this model of install on some skewed rails that didn't have brackets that would work.
~Matt
Old 10-06-2009, 12:37 AM   #10
Martin Co's Avatar
Use the hardware that comes with the kit. Use the same principles attaching the railing to the column as you would to the post. Just as others said, cut it a half an inch long and belt sand the profile. It's a piece of cake..
Martin Co is offline
Old 10-06-2009, 08:55 AM   #11
here's one we did last year...
~Matt
Porch Column Repair mpt1123 Historical Restoration 5 01-11-2010 07:33 PM
Chunky Old "Beaded Bread Loaf" Rail basswood Finish Carpentry 18 08-16-2009 08:52 PM
TT radiance rail kit help curapa Decks & Fencing 10 08-19-2008 10:45 PM
Bench with Radiance Rail and XLM Greg Di Decks & Fencing 14 04-15-2008 08:28 AM
