Questions About Framing A Ground Level Deck
Old 06-09-2010, 08:52 AM   #1
dvatt's Avatar
Rewards Points: 380
I need to frame a ground level deck. The sliding doors are 6.5" from the ground. Can I frame with 2x6? Is 2 x 6 against code?
dvatt is offline
Old 06-09-2010, 09:08 AM   #2
Tom M's Avatar
Rewards Points: 5,592
Re: Questions About Framing A Ground Level Deck
Frame with 4x6 sleepers laid over gravel and weed screen
Tom M is online now
Old 06-09-2010, 09:22 AM   #3
The Deck Guy
Greg Di's Avatar
Rewards Points: 2,000
Rot city.
Don't know your location, but a wood deck won't breath and won't have a long life.
Forget about composite because most are not rated for that kind of ground clearance. A synthetic board is really the best choice. Make sure whatever wood you put under it is at least .60 treated or better.
Greg Di is offline
Old 06-09-2010, 10:01 AM   #4
Civil / Structural PE
Tim Garrison PE's Avatar
Trade: Software and business coaching
Rewards Points: 75
What about a concrete "patio" instead?
I don't see any way to do wood unless you take out some dirt. I suppose you could use 4x4 PT deck joists at 24" OC, each one supported by piers at 6.5' (I calc'd that). But you're begging for rot trouble. You need more clearance to ensure that gophers and other critters don't pile dirt up against those joists.
Tim Garrison PE is offline
Old 06-09-2010, 10:34 AM   #5
dvatt's Avatar
Rewards Points: 380
Timbertech assured me that the reliaboard would be ok with this minimal clearance. Are 2 x6 against code?
dvatt is offline
Old 06-09-2010, 10:44 AM   #6
Tom M's Avatar
Its all about span for code compliance. In NJ we are allowed 600 sqft with out frost protection but a low deck that can twist with heave is better with beams and footings.
I have done 6x6 beams sunken beams over footings with 2x6 joist over the beam then earthwood planks with no issues. I did maintain a good gravel bed and allowed for vents in the fascias. That was the only way I could keep the platform low.
Tom M is online now
Old 06-09-2010, 12:00 PM   #7
Rewards Points: 75
No particular wood violates code as long as it calcs. You could use cedar poles for joists if you wanted so long as bending, shear, and deflection criteria are met. And also whatever you use must meet the "decay and rot" portions of code which are about adequate ground clearance and / or treatment with preservative.
Old 06-09-2010, 12:01 PM   #8
DavidC
DavidC's Avatar
Rewards Points: 2,006
Will (or have) they assure you in writing? They can suddenly develop amnesia with a warranty claim.
FWIW, my vote goes with Greg Di.
Of course, at home you can take chances. I have a 2x6 framed PT deck set directly on an old flagstone patio outside my back door. It's been a few years so far with no problems. But I wouldn't chance it with a client.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 06-09-2010, 01:35 PM   #9
The Deck Guy
Greg Di's Avatar
I am telling you it's NOT OK.
Here's what WILL happen. The deck will look good for a while. The homeowner will undoubtedly neglect the deck and not wash it enough. You will get mildew on the top. Meanwhile, even if you clean the mildew off the top of the boards, the bottom will be riddled with it. Eventually, there will be an issue.
If you must build the deck this low, use PVC, otherwise, don't do it.
Greg Di is offline
Old 06-09-2010, 01:36 PM   #10
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,476
I vote for stamped concrete.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 06-09-2010, 01:37 PM   #11
The Deck Guy
Greg Di's Avatar
Hell, pour a heavily pitched pad funneling water to a perimeter drain.
Use Bisons or tapered sleepers to keep the deck level.
Lack of air is a killer.
Greg Di is offline
Old 06-09-2010, 02:05 PM   #12
Chris G's Avatar
Trade: Porch and Deck Builder
Rewards Points: 1,210
Agree with Greg, pour a sloped pad and use Bisons. Use enough of them and you can go with 2 x 4 frame.
I can not emphasize how stupid I really am
http://www.vicporch.ca
Chris G is offline
Old 06-09-2010, 02:57 PM   #13
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 476
We might lose some jobs because of it, but it does not make sense to build a deck that low, unless there are circumstances that require it. It's probably much cheaper to go with almost any other paving material, and less worry.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 06-09-2010, 03:18 PM   #14
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,740
I would be leaning toward a patio. Stamped concrete is good, but you could use brick, flagstone, concrete pavers.... It will probably cost more initially, but it will last a lot longer, and maintenance will be minimal.
Synthetic decks still look a little Playschool to me. Even the "good" ones. But, that's not for me to decide.
Rustbucket is offline
Old 06-09-2010, 04:03 PM   #15
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
We pitched the ground elevation away from the house and added 2 of stone under the deck
festerized is offline
The Following User Says Thank You to festerized For This Useful Post:
stp57 (06-09-2010)
Old 06-09-2010, 04:56 PM   #16
The Deck Guy
Greg Di's Avatar
Right, but this guy's final deck height is on 6.5" off grade. Totally different situation. Looks to me like you might have been lucky enough to get a drop girder under that one. LOL
Greg Di is offline
Old 06-09-2010, 05:04 PM   #17
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Way to go David, I dont know what the big deal is with a low leval, we do them all that time. I do provide cross ventalation on a projcet like that and any other deck. J.
John Hyatt is offline
Old 06-09-2010, 05:36 PM   #18
redwood's Avatar
Rewards Points: 476
Fester
There is a big difference between 12-14" and 6 1/2" off of the ground, in my book.
Mark
Pioneer, CA
redwood is offline
The Following User Says Thank You to redwood For This Useful Post:
Greg Di (06-09-2010)
Old 06-09-2010, 06:41 PM   #19
David Festa
festerized's Avatar
The 2 x 12 girder was buried in the ground
Old 06-09-2010, 06:45 PM   #20
David Festa
festerized's Avatar
Same deal here, accept we have 4 of stone
Customer Questions - Azek or Correct deck? (3 children & 2 big dogs) Legan3rd Decks & Fencing 11 01-11-2011 09:40 PM
Should Deck Posts Sunk In Concrete or Above Ground? Vince10 Decks & Fencing 40 04-30-2010 08:43 PM
Deck Awning Demolition Questions jerome8283 General Discussion 4 08-01-2007 02:52 PM
Building a deck flush to the ground Kingflynn Decks & Fencing 6 06-15-2007 06:38 PM
2 questions regarding a deck, actually 3. daveincincy Decks & Fencing 26 02-17-2007 09:04 PM
