A Question For The Pro's
Old 04-04-2008, 02:24 PM   #1
bjg5240's Avatar
With the hidden fastener system on a deck, I need to install the facia board over the decking boards to cover the ends. Can someone share with me the best way to cut the deck boards prior to installing the facia? The deck is 21', so it is difficult to find anything long & straight enough to use as a guide. Thanks for any suggestions.
Quality Isn't Expensive, It's Priceless
bjg5240 is offline
Old 04-04-2008, 02:40 PM   #2
GARRETT RENOVATIONS LLC
Garrett's Avatar
Trade: GC,Builder,Custom Renovations
Re: A Question For The Pro's
The way i have done it is let the boards that you can run long, use a blue chaulk line(wont stain) and snap a strait line and cut once, othe ideas i have heard were to cap the ends of each board and let the decking hang over and butt the wrap under the decking
Garrett is offline
Old 04-04-2008, 02:46 PM   #3
bjg5240's Avatar
My biggest issue with using a chalk line is I'm concerned about the wavyness of the cut. Once the facia board is put on, any deviation will stand out like crazy.
bjg5240 is offline
Old 04-04-2008, 02:51 PM   #4
Garrett's Avatar
maybe snap a line use some2x4 and screw through the gaps into anohter 2x and use that as a straight edge? im outta ideas good luck!
Garrett is offline
Old 04-04-2008, 03:06 PM   #5
BuiltByMAC's Avatar
Trade: Construction
Board next to house - Cut ends to length
All other decking run wild
Pop line 1" away from actual cut line
Set foot plate of saw so cut depth is thickness of board plus 1/8"
Position saw blade 1" in from popped chalk line (at actual cut line)
Pull blade guard back and hold it open (so there's less chance of the "thunk" of the guard hitting each piece screwing your cut up)
Cut slow and steady while using saw's footplate inch guide to "sight" along popped line...
Mac
BuiltByMAC is offline
Old 04-04-2008, 03:13 PM   #6
Charitable animal
Bone Saw's Avatar
Trade: decks
router with 5/8" solid carbide spiral downcut or compression cut with bearing, flawless everytime
Bone Saw is offline
Old 04-04-2008, 03:19 PM   #7
Garrett's Avatar
bone, i like that idea but have you ever hit a knot or a bad spot in the edge of the framing and messed up the decking or are you very aware of that because its how you do it
Garrett is offline
Old 04-04-2008, 03:24 PM   #8
bjg5240's Avatar
Will it work with TT composite??
bjg5240 is offline
Old 04-04-2008, 03:28 PM   #9
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
Then maybe you should hire someone that can run a circular saw
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 04-04-2008, 03:32 PM   #10
Garrett's Avatar
before hidden fasteners or decks that get screwed throught the face i would snap a line and cut the decking then push the outermost joist in and out and then screw the deck boards down made for a pefectly straight edge and railing
Garrett is offline
Old 04-04-2008, 03:33 PM   #11
deckman22's Avatar
Trade: Deck Builder
I'm working on a Amerdeck re-skin job now that had a couple of curved facia boards & I did exactly that, worked like a champ. Otherwise I would agree with Jason for straight lines.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 04-04-2008, 04:03 PM   #12
Charitable animal
Bone Saw's Avatar
Trade: decks
it will work with any meterial, even ipe, slow and steady, nice straight as an arrow or perfectly uniform gaps, obviously you'd work from right to left and it helps to be cutting ends that are in excess of the bits diameter so as not to have blow outs on the left edge of every piece, but if I'm capping end cut, router all the way baby
Bone Saw is offline
Old 04-04-2008, 04:11 PM   #13
Charitable animal
Bone Saw's Avatar
Trade: decks
Will it work with TT compsite??
ceartainly will, word of caution regarding routers, composite router shavings and "edge" work. I'd like to consider myself having ninja like reflexes, however this combination is a dangerously slippery mix (bannana peels come to mind), trust me. take your time and be mindfull of your surroundings and your footing and weight shifting, or you will go down to chinatown
Bone Saw is offline
Old 04-04-2008, 05:02 PM   #14
The Deck Guy
Greg Di's Avatar
How do you work around posts with a router?
Greg Di is offline
Old 04-04-2008, 05:05 PM   #15
Charitable animal
Bone Saw's Avatar
Trade: decks
I don't
how do you work around posts with a saw
Bone Saw is offline
Old 04-04-2008, 05:14 PM   #16
bjg5240's Avatar
Bone,
How much material to you leave before starting your router cuts??
Also, which bit do you prefer & where can I get it.
bjg5240 is offline
Old 04-04-2008, 05:38 PM   #17
Stone Mountain's Avatar
Trade: Outdoor contracting: fences and decks
At the risk of insulting you, if your hand isn't steady enough to cut a straight line when using chalk, and if you don't know what to do with the posts, then maybe you should reconsider your vocation.
I can identify my best carpenters this way. Most of them can cut a straight edge so perfectly that the bullnose fits on without any gaps anywhere. A few of them simply can't get it perfect. Those are the ones who do just the basic builders decks and such for me.
We used to have a guy who was incredible. Not only was he impressively fast, but he had an eye and a hand that could cut perfect lines without chalk lines or pencils. You couldn't fit a piece of newspaper between his mitres. Unfortunately, he had a drug problem.
Bone's idea with the router is a great one. I'll have to mention it to my carpenters.
Residential Deck Specialist: Vist our Website
www.fenceanddeck.ca
Stone Mountain is offline
Old 04-04-2008, 06:02 PM   #18
bjg5240's Avatar
No insult taken. I dont have a super steady hand (which is why I gave up brain surgery), so thats why I'm here asking for advice.
The snapping a chalk line was a given, I was just looking for a trick of the trade (Bone Saw's post) that might make my edge turn out better. Typically when I have done decks in the past, I have left a slight overhang of the boards. This deck is composite, which is my first, and don't want to butcher it.
bjg5240 is offline
Old 04-04-2008, 07:56 PM   #19
The Deck Guy
Greg Di's Avatar
I don't
My posts are always set inside the rim, thus giving me at least 1.5" from the edge of the rim. The saw plate fits in fine. I've always wanted to use a router, but the post issue left me guessing.
Greg Di is offline
Old 04-04-2008, 09:12 PM   #20
Charitable animal
Bone Saw's Avatar
Trade: decks
i read you now, i always put mine in after decking is down weather they're innies or outties
Bone Saw is offline
question for the pros dutchlegacy Drywall 12 03-22-2008 09:35 PM
FORD Superduty PROs - A question wallmaxx Vehicles 19 02-10-2008 07:41 PM
question for the pros, amcline Painting & Finish Work 18 01-05-2008 08:00 PM
A question for the pros... JPF HVAC 7 07-26-2007 09:25 PM
Crawlspace ducting question for the pros ctbuilder HVAC 6 07-26-2007 09:14 PM
