Post Holes In Rock
Old 06-09-2007, 04:14 PM   #1
Emo's Avatar
Trade: Fence
Post Holes In Rock
Whats the best way to get thru big rocks when digging post holes. I have a auger on wheels do the carbide cutters work?
Emo is offline
Old 06-09-2007, 05:04 PM   #2
ContractorTalk Flunkie
dayspring's Avatar
Re: Post Holes In Rock
DYNAMITE! or maybe a rotary hammer drill
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 06-09-2007, 05:07 PM   #3
mdshunk's Avatar
I know the fence companies around me tend to use a tow-behind jackhammer air compressor with a rotary rock drill.
mdshunk is offline
Old 06-09-2007, 06:35 PM   #4
Emo's Avatar
Trade: Fence
THANKS for the info I'll look into it.
Emo is offline
Old 06-10-2007, 03:31 PM   #5
RobertCDF's Avatar
Trade: Custom deck builder
I use a jackhammer and if that does not move the rock I will drill 3 holes with a hammer drill. I then insert rebar into the holes and epoxy them in. Then pour the pier as normal.
RobertCDF is offline
Old 06-10-2007, 06:18 PM   #6
747's Avatar
A controlled Detonation. Depending on how hard that rock is you could burn through several carbide bits. Its my understanding those bits aren't cheap. Plan b. Find a guy who has a bobcat or tractor with the hydralic jack hammer mounted on it.
Ps.....C4 or RDX
747 is offline
Old 06-10-2007, 07:53 PM   #7
Custom Builder
Glasshousebltr's Avatar
If it's pretty flat on top of the rock, and the rocks just to big to move, a wet core hole saw will do the trick.
Bob
Glasshousebltr is offline
Old 07-08-2007, 08:58 AM   #8
Sprinkler Guy since birth
sprinklerguy's Avatar
Trade: Lawn Sprinkler/Fence Contractor
I just installed 1000 feet of split rail fence....500 feet of which was solid granite.
We used a 220 cfm compressor at 10,000 feet in altitude and a 90 lb jackhammer...some holes too up to an hour to do. it sucked, but it got done and done right.......
Good luck, I feel for you.....
Tony Neumann
Lawn Sprinkler Repair and Irrigation Installation
Colorado Springs, Colorado
http://www.sprinklersolutions.com
sprinklerguy is offline
Time saver for post holes AndyJones Decks & Fencing 48 05-18-2011 10:47 AM
what is code for filling in post holes 72chevy4x4 Decks & Fencing 11 03-26-2007 09:37 PM
Post holes omnibuilder Construction 7 12-12-2006 06:52 PM
