Porch Railing
Old 10-09-2008, 10:21 AM   #1
Brianasaurus's Avatar
Trade: Interior Remodeling and Home Repair
Porch Railing
Hi All,
I am gathering opinions on the best way to anchor 4x4 posts to a set of brick steps that I am building a railing for. Or I guess I should say, what is the preferred method for anchoring wood to brick?
Brianasaurus is offline
Old 10-09-2008, 10:46 AM   #3
Tom M's Avatar
Re: Porch Railing
Your better off drilling a long dowel into block below the brick then use a concrete setting mix to lock it in. You need to leave it sticking up to transfer that dowel into the post. Im sure Simpson has a similar connector that protects against unlift. I would not surface mount anything on a brick tread as it will break apart with one hit.
Tom M is offline
Old 10-09-2008, 07:43 PM   #4
Re: Porch Railing
I'm prettu much with Tom as far
as surface mounts on brick.
You are only anchored to the
brick.
Is there any chance you could
mount them to the side of
the steps? ,Lag and shield?
neolitic is offline
Trying to sell a porch with black railings WarnerConstInc. Carpentry 2 09-10-2008 12:09 PM
How to level out a concrete porch? ProVolley9 Masonry 17 08-27-2008 09:09 PM
Certainteed railing jeclarke Decks & Fencing 5 05-09-2007 06:20 PM
Cedar railing vulcan Decks & Fencing 2 09-22-2006 10:48 PM
How would you frame this porch rebuild? karma_carpentry Framing 10 04-08-2006 07:45 PM
