I builds'em
Trade: Renovations & Decks
Picket Fence, Rail Mortise, Router Template
Well,
I really wanted to have the rails of my picket fence into the posts. So, making a template for my router w/ guide. However, I noticed my router bit is not centered inside the template guide. Anyone know why and how to fix this? You can see a picture, some test pieces and that it almost fits (need some fine-tuning) but the fact that the bit/guide are not centered is throwing me off a bit. Anyone?
Ryan |
I builds'em
Re: Picket Fence, Rail Mortise, Router Template
Also, here is a pic of the job. We had to do the posts right away so the landscape could do the walkway and grass. I didn't want to go dig the holes in new sod.
So I can't have them too snug or I'll never get the rails in, also have to make them pretty much all the way through.
Ryan |
Sorry, Winchester, - - maybe I'm tired and brain-dead right now, - - I'm just not getting anything out of that picture of your router, - - no matter how long I stare at it.
What kind of template??, What kind of guide?? |
Sean
I have to agree with Tom - it looks fine to me, you did account for the guide thickness & clearance with your template right?
Have you thought of just buying a mortiser? |
Winchester, - - it looks like it's a bushing guide, - - it's just really hard to tell, because the picture is so '2-d' looking, - - but if it is off, -- just turn your router 90 degrees with each turn, allowing you to be using the same point of your guide along each edge.
I hope/think that made some sense. Last edited by Tom R; 04-28-2009 at 11:27 PM. |
| The Following User Says Thank You to Tom R For This Useful Post: | tommytwo (04-29-2009) |
I builds'em
Sorry I was trying too hard to center it to show that its off and didn't go further
You can get an idea of looking at the gap NE of the bit compared to SW It is a bushing guide so I traced out the 2x3 and added 1/8 to each side to account for bushing size. However it isn't centered so it was messing me up. Yeah, I was hoping for a more elegant solution but that is the best idea so far. Works good though quick and practical I think the problem is its one of those routers tht you can change the base off. I've got a freud 3.25 plunge that would do a better job but I don't want to take it off the table
Ryan Last edited by Winchester; 04-28-2009 at 11:45 PM. |
Don't know how your router works.
On mine, I loosen the base plate a tad, bring it all the way up and let the end of the collet snug into the guide bushing til it centers, then tighten the base plate. Easier to do than say. ![]() Hope that's what you mean.
The only other thing I can think of (if I'm thinking of the right kind of set-up) is if you were to spin the base to a different position on the screws?? (maybe it only lines up perfectly in one of it's positions).
Another option might be to slightly enlarge the screw holes on the base, giving you some lateral adjustment on the base itself, - - or even drill three completely new holes, with better centering this time. |
Re: Picket Fence, Rail Mortise, Router Template |
Also, - - the 'elegant' fix, - - is buy at least a Porter-Cable . . .
That's why I only know how to
center it up on a Porter-Cable.
Moderator
You can also just recut your template to remove the slop on the one side. Just be sure to line it all up the same with each cut.
Have you tried a different bushing to see if that is the problem?
#13 | |||||
I builds'em
Re: Picket Fence, Rail Mortise, Router TemplateQuote:
![]() At the time I bought the thing (Hitachi) they were fairly new I think (somewhere about 5-6 years ago) and were getting some decent reviews. I "thought" it was the best bang for the buck... Quote:
![]() Quote:
Does festool make a router? Quote:
Ryan Last edited by Winchester; 04-29-2009 at 12:51 AM. |
I builds'em
Do they make portable ones with adjustable templates? I've tried to look some up but all I could really find were just mortise/tenon jigs or benchtop set-ups.
Unfortunately, my posts are already set because I wanted them in before the landscaper did his stuff. Now the work needs to be done on-site.
Ryan |
#15 | |
Trade: carpentry
Usually when that happens you know it because its dang near impossible to insert the bit into the collet, dang dangerous too. |
#16 | |
Sean
http://grizzly.amazonwebstore.com/Grizzly-G0645-12-HP-BenchTop-Mortising/M/B0017IDWNQ.htm http://performancetoolcenter.com/708580.html Cha Ching, chain mortisers http://www.timberwolftools.com/tools/kind/mortisers.html - maybe not a good option unless you do a lot of these fences I wonder if you could use a door mortising jig? |
Maker of fine kindling
When you spin the motor down into the base does the bit stay in the same spot or does it swirl in the bushing?
See where I'm going with that question? If it stays in the same quadrant then I would say the base plate is jacked up. Then I would drill out the mounting holes in the base plate and force it to center up the best I could. Side note; Are you planning on making the mortises loose enough to slip the rail in to one post then back it in to the other? In the future when you can install all the parts at the same time, you may consider putting a real tenon on the rails with a shoulder so the mortise can have a small amount of play and it will not show. You don't have that option this time though. Oh well |
#18 | |||||
I builds'em
![]() Quote:
I think it may just be time for a new router. For this job I think I will drill a hole through the post and use a jigsaw. (probably start it off with a chisel first, too. However, I'm worried about overcutting on the opposite side of the post. Quote:
Ryan Last edited by Winchester; 05-01-2009 at 02:15 AM. |
#19 |
I builds'em
This is kind of a new venture in one of the many ways I want to try to up our craftsmanship.
So, sorry if I end up trying to pick some of your brains for ideas ![]() Normally we'd just toenail or pocket screw the rails on something like this. has anyone cut something straight through like this without overcutting and screwing up the opposite side? Any tricks other than to watch both sides at the same time and go really slow and pray? Another idea, why not do the first 1/2" with a chisel and use a flush-trim router bit with the bearing at the top? huh? huh?
Ryan Last edited by Winchester; 05-01-2009 at 02:27 AM. |
#20 |
Trade: Railing
One way or another you need to center the base on the bit.
Guss suggested my first thought: "Then I would drill out the mounting holes in the base plate and force it to center up the best I could." It's most likely the router base that's the culprit, since everything else is just machined round. You might try some aluminum tape over one side of motor housing to get it centered. It won't take much. Given what your trying to do, I'd be inlined to use a big 3/4" plywood template, with a cutout equal to the size of router base, plus the mortise size, minus the bit size. The 6" router base fits inside the plywood cutout...no brass insert needed. 3/4" plywood cutout example for 2" x 3" mortise: 2" dim = 2" + 6" (router base) - 3/4" (router bit), 2+6-3/4 = 7 1/4" hole 3" dim = 3" + 6" - 3/4" = 8 1/4" hole So that's a 7 1/4 x 8 1/4 cutout. Now just add a 1x2 edge guide to plywood, & screw template to post. The router base will basically wobble around the cutout hole. Repeat process from opposite side. I would think this would give accurate enough results for a fence. Joe |
| Slit Rail Fence | thezig | Decks & Fencing | 16 | 08-27-2010 05:01 PM |
| Replacement fence for Porter Cable 698 router table | Panzer5 | Carpentry | 4 | 04-10-2009 11:47 AM |
| split rail fence | dlcj | Decks & Fencing | 6 | 02-02-2008 01:46 PM |
| Mortising doors, hinges - router template? | MHMConstruction | Finish Carpentry | 11 | 06-07-2007 11:16 AM |
| Fence Mortise and tenon | brentsid | Carpentry | 12 | 07-03-2006 12:21 AM |
