Overhead Composite Decking
Old 05-09-2009, 08:57 PM   #1
coupe33's Avatar
Trade: finish and trim
I have to build a deck that is 10 ft off the ground and covers a 14x24 patio, of a walk out basement. the upper deck will have roof covering it. These are my questions? 1. is their a composite decking company that sells a decking that the decking can be mated side by side or that is tounge and groove for the specific purpose of being water proof or water tight. the bottom of this deck will be sopheted and have can lights i n it for the patio below as will the roof over the composite decking. I keep reading about moisture content and air space etc,etc. I know i am not the first person to run into this senario when building an upper deck for a walk out on a new home. Any brands or insight from some one who has done this. Also I am pretty sure exposed fastners is out of the question, but the deck will have a picture framing around it and if i have to I can put treated 2x2 stabbers along each joist to srew from the bottom up if needed. I talked with one individual that tried this with geo deck and said never f@#$ again. I believe they are now out of buisness do to problems.
coupe33 is offline
Old 05-09-2009, 09:10 PM   #2
PA woodbutcher's Avatar
Re: Overhead Composite Decking
Timbertech and Correct deck both have their own waterproof soffit...never used it myself, but if you search drysnap or something similar it has been discussed.
I did a couple of decks in Geo deck and it was garbage. No complaints from the customers, but I didn't like the looks of it on my yearly followups.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 05-09-2009, 09:57 PM   #3
Composite Decking Mfr
MartyCD's Avatar
Trade: Manufacturer of Composite Decking, LEED AP
It is true we at CorrectDeck partner with Rain Escape, which would work for what you want to do. The only system I'm aware of where the decking is actually waterproof is Last Deck, which is interlocking aluminum decking.
MartyCD is offline
Old 05-10-2009, 08:48 AM   #4
John Hyatt
John Hyatt's Avatar
I got some info/samples from these guys> www.wahoodecks.com they are seling ariddek alum decking,dryjoist,alum rail even a little ipe. Its hard to say how good it is but its a lot more $ than a torchdown/stringers. J.
John Hyatt is offline
Old 05-10-2009, 10:45 PM   #5
buckeyeso2's Avatar
Trade: carpentry
if you want cans below, you almost have to catch the water topside, instead of on the bottom. we used dek drain and it seemed to work real well with cans and ceiling fans.
i tried putting cans with the underdeck system and it was a real pain.
buckeyeso2 is offline
Use for composite decking scraps loneframer Decks & Fencing 40 02-22-2009 06:08 PM
Cost of composite decking & vinyl hand rail??? SWAY79 Decks & Fencing 66 12-09-2008 06:18 PM
leftover composite decking scraps-what to do with them? harpdog Decks & Fencing 29 11-25-2008 11:54 AM
Moisture Content of Composite Decking ghhartmann Decks & Fencing 4 09-18-2008 12:23 PM
Powerwashing composite decking??? dougchips Pressure Washing 3 02-12-2007 12:58 PM
