OOPS!!! I Messed Up!!!
Old 02-23-2009, 02:50 PM   #1
jcalvin's Avatar
i built a deck and screwed up the 6x6 posts. when i build a deck i get 6x6s's long enough to extend above the deck to carry the handrails. i hate a wobbly handrail and this is as tight as you can get it. i also run the posts about 4" above the handrail so i can break the top rail and fight the typical warping top rails that look horrible. before i do this, i set my saw at a 45degree angle and make a cut all the way aroung the post 1" down from the top. here is the problem. all was going well until i made a cut and realized that my saw table wasn't locked and cut one at 52degrees. i stopped before cutting all the way through and was able to recut it correctly at 45degrees, but, there is a notch about 2" deep at 52degrees. how can i fix this notch? the ho doesn't mind but it just bugs me. it is going to be near impossible to change the entire post since it is notched for the bands and the deck boards and they are about 16' long. any ideas would be greatly appreciated. if i can't come up with anything else, i am going to mix some glue with some pt sawdust and work into the notch.
Cal
You hired WHO
jcalvin is offline
Old 02-23-2009, 02:58 PM   #2
BuiltByMAC's Avatar
Trade: Construction
Re: OOPS!!! I Messed Up!!!
Cut all post tops flat 3" above cap rail and drop post caps on 'em...spendy proposition, I know.
Cut all post tops flat 3" above cap rail and run a router around the top to round off the edges.
Cut that one post off at height halfway through the cap rail and fab a fakie post top. Cap rail will hide seam.
Unless I'm completely missing what you are looking at - got a pic?
Mac
BuiltByMAC is offline
Old 02-23-2009, 02:59 PM   #3
Tom M's Avatar
Notch or Saw cut? Sure do the glue and saw dust plus a treated wedge then sand smooth after it dries.
Tom M is offline
Old 02-23-2009, 03:07 PM   #4
jcalvin's Avatar
getcha a pic this afternoon
Cal
You hired WHO
jcalvin is offline
Old 02-23-2009, 05:14 PM   #5
reveivl's Avatar
Trade: Renovations
Mac
What Mac said, or can you cut them all at 52 degrees?
reveivl is offline
Old 02-23-2009, 06:55 PM   #6
RobertCDF's Avatar
Trade: Custom deck builder
I vote for the router option.
RobertCDF is online now
Old 02-23-2009, 07:54 PM   #7
Sean
SLSTech's Avatar
Epoxy instead of glue, or go with Option #2 by Mac would be my choice
SLSTech is online now
Old 02-23-2009, 08:06 PM   #8
jcalvin's Avatar
sorry if the picture isn't clear enough, i forgot the camera and the phone was all i had.
Cal
You hired WHO
jcalvin is offline
Old 02-23-2009, 08:24 PM   #9
redwood's Avatar
Trade: Carpentry Contractor
Pic does not show up for me.
Mark
Los Gatos, CA
www.creative-redwood-designs.com
redwood is online now
Old 02-23-2009, 08:33 PM   #10
jcalvin's Avatar
pics didn't show up fpr me for a long time, then i realized i had the security on my puter set too high
Cal
You hired WHO
jcalvin is offline
Old 02-23-2009, 08:39 PM   #11
Meetre's Avatar
your pic isn't showing up for me, and I always see them here.
Meetre is offline
Old 02-23-2009, 09:02 PM   #12
jcalvin's Avatar
beginning to think that you guys can't read, always have to have a picture. when i go back, i will take another picture with the camera and try a different way of posting it.
Cal
You hired WHO
jcalvin is offline
Old 02-23-2009, 09:12 PM   #13
Poolman's Avatar
Trade: Swimming Pool & Excavating Contractor
What about swapping a new post in it's place and using that one on a future deck where it doesn't need to be so long?
Scott
Is this going to be expensive?
It's all relative.
Poolman is offline
Old 02-23-2009, 09:16 PM   #14
Quinn's Avatar
Trade: Deck builder /contractor
just because you tape a pic to your screen doesn't mean we can see it. Ha,Just kidding!
Quinn is offline
Old 02-23-2009, 09:16 PM   #15
Sean
SLSTech's Avatar
Save the pic locally & then attach it (paperclick symbol) - we can't see the pic inside your mailbox unless you wish to give everyone your username & password
Old 02-23-2009, 10:04 PM   #16
jcalvin's Avatar
does this work? i hope the tape i used to put it on my screen didn't blur the pic.
Cal
You hired WHO
jcalvin is offline
Old 02-23-2009, 10:10 PM   #17
The Red's Avatar
Trade: Site for business owners of all trades
If you can put all the post at 52. Thats what i would do. Then you just lose the time.
The Red is offline
Old 02-23-2009, 10:22 PM   #18
curapa's Avatar
Trade: Carpentry / Fencing / Decks
Cut 52's on all of them, and start predrilling your screw holes.
Also, if you brad nailed those 2x2's on your gonna have problems. The 2x's will begin to warp and eventually separate from the rails, drunken people falling can easily bust through them when they are only connected with brads, upgrade to screws or at minimum some ring shanked nails.
I am also curious as to why one spindle is right next to the post and the opposite is 1 1/2" away.
www.ParkerFenceandDeck.com
curapa is offline
Old 02-23-2009, 10:33 PM   #19
Morning Wood's Avatar
Trade: Pretty much anything with wood
I would cut your post down and run a chamfer around the top with a router. Then do it to all the other posts too. I would also fix the split top rail on the left side of your pic.
Morning Wood is offline
Old 02-23-2009, 10:36 PM   #20
JBMagi's Avatar
Epoxy all day. If the deck is going to get a solid body stain no worries. If not try like the marble guys do and mix some of your saw dust into a clear epoxy.
JBMagi is offline
oops!!!!! lynchy Excavation & Site Work Picture Post 6 12-30-2008 07:04 PM
Messed with the 3" head CrazyTaper Drywall 12 03-16-2008 01:57 PM
OOPS Framing - Pictures of framing gone bad wallmaxx Carpentry Picture Post 16 11-16-2007 08:57 PM
I messed up. ModernStyle Painting & Finish Work 10 07-22-2007 08:45 AM
Oops! Atricaudatus Off Topic (Non Trade) 2 03-02-2006 03:43 PM
