Ohio Frostline -footers
Old 10-21-2008, 02:58 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,222
Building a simple enclosure for propane tanks, (similiar to trash enclosure, but better vented) I am digging out footers for concrete. A manual post digger.
About 20" down, this is nearly an impossible dig. 4 to 5" within the ext siding, in to severly compacted clay with heavy stone mix. Too close to the home for (1) man gas auger or similar; dingo, etc.
Recently I heard the frostline in OH is 30" +.
Is this right?
Years back I recall approx 24 " to prevent heaving.
Tha arms on the post-hole digger won't go far below 20" for sure. They won't swing to collect the excavated soil at bottom.
When or why was the frostline so taken to the extreme?
artinall is offline
Old 10-21-2008, 03:04 PM   #2
Professional Instigator
rbsremodeling's Avatar
Rewards Points: 2,000
Re: Ohio Frostline -footers
I have no clue on ohio but in maryland where we get minimal snow its 30" everything I read on line for ohio says 36"
rbsremodeling is offline
Old 10-21-2008, 03:42 PM   #3
hailey's Avatar
Trade: vinyl decks and fence
Rewards Points: 150
I am in northern indiana and it has been 36" here for a long time.The frost rarely gets deeper than 20" or so....they just have to blanket the codes for the worst case scenario.
Good Luck on your dig
hailey is offline
Old 10-21-2008, 05:45 PM   #4
andy builds's Avatar
Trade: Finish Carpentry and Remodeling
Rewards Points: 25
typically 36 clears most vicinities... a check with your local inspector could tell you better... in regards to the dig invest in a pair of leather gloves and a heavy digging bar, it will break it up then pull it out with shovel/diggers.
andy builds is offline
Old 10-21-2008, 07:51 PM   #5
artinall's Avatar
Did earlier today. Large rocks deeper still are going to mean pouring a lot of rock for the new posts!
artinall is offline
Old 10-21-2008, 08:00 PM   #6
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,560
I have to go down 54" 6" stone or cookie, then have a clear 48". Thats what they tell me to do!!!
WarnerConstInc. is online now
Old 10-22-2008, 09:19 PM   #7
buckeyeso2's Avatar
Trade: carpentry
Rewards Points: 75
In auburn?? Sounds like a real pain !!!!!
buckeyeso2 is offline
Old 10-22-2008, 11:34 PM   #8
I like Green things
uh-huh... 54" is what they want for pole barn posts, most slab footings and any other hole you have to have inspected.
Old 10-27-2008, 12:41 AM   #9
Robert H. Dougl's Avatar
Trade: Carpentry rehab 30 years
ohio is 30" for footing for decks so it may be the same for what you are doing
Robert H. Dougl is offline
Columbus, Ohio contractor. Need info. gtmstang General Discussion 5 01-19-2010 09:15 AM
Columbus Ohio Estimator mtpgoat Help Wanted or Looking For Work 1 10-27-2008 03:19 PM
Hello from Ohio wdestar New Member Introductions 5 08-30-2008 07:48 PM
Northeast Ohio House Painters Wanted welovepainting Help Wanted or Looking For Work 0 05-08-2008 07:28 AM
Ohio C.C.R. General Discussion 4 08-19-2007 08:47 PM
