No More Digging Sono Tubes!!!!
Old 04-20-2008, 08:57 AM   #1
tcleve4911's Avatar
Trade: Remodeling contractor
Have you guys seen this technique??
We use it here in Maine & VT. It's -5 degrees out. You wind this into the frozen ground to an engineered depth & poof.....you're done.
No digging/backfilling, no concrete to mix, no waiting to cure. It even has a threaded nut on it for fine tuning your height.
$125 each. Changed the way we build decks & porches............
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 04-20-2008, 09:09 AM   #2
Joe Carola's Avatar
Trade: Framing Contractor
Re: No More Digging Sono Tubes!!!!
What's it called? How far down did you go? Why would you not need a footing?
Joe Carola
Joe Carola is offline
Old 04-20-2008, 09:11 AM   #3
Tom R's Avatar
I would imagine it's 'hold' is dictated by friction??
Tom R is offline
Old 04-20-2008, 09:13 AM   #4
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
Looks similar to the posts they build prefab sun rooms on.
So what if there's a rock 2' down?
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 04-20-2008, 09:15 AM   #5
tcleve4911's Avatar
That's exactly what it is...He has a gauge on the machine that's telling him how much "friction" the post is generating and matches that with precalculated load specs. Pretty cool.
The city & state has accepted them as substitutes for sono tubes.
Back in Maine
Dubbin' Around
Old 04-20-2008, 09:19 AM   #6
tcleve4911's Avatar
Otter Creek 3-Season Room Additions were the folks that turned us on to these.
I watched him hit a rock and he just tweaked the position a little and it worked it's way around it, then tweaked it back to the same spot coming out of the ground. He can hit a hole location within an inch every time.
Back in Maine
Dubbin' Around
Old 04-20-2008, 09:54 AM   #7
REG EC,CERT EI PLANS EXAM
cmec's Avatar
Trade: electrical
What About Rock ?
cmec is offline
Old 04-20-2008, 09:59 AM   #8
Tom R's Avatar
Definitely cool.
I'm gonna have to check further into this . . .
Tom R is offline
Old 04-20-2008, 09:59 AM   #9
Joe Carola's Avatar
What's this called? Do you have a link?
Joe Carola
Old 04-20-2008, 10:11 AM   #10
Restoration Crazy
Are you renting that machine from Otter Creek? They are the company I saw using those last year. Pretty slick!
Facebook | Twitter
Old 04-20-2008, 10:39 AM   #11
Heefs Home Impr's Avatar
Techno metal post
Heefs Home Impr is offline
Old 04-20-2008, 11:04 AM   #12
tcleve4911's Avatar
Techno Post is a franchise. You call 'em they set 'em
Back in Maine
Dubbin' Around
Old 04-20-2008, 11:05 AM   #13
tcleve4911's Avatar
Originally Posted by cmec View Post
What About Rock ?
What about it? It works it's way around rocks. Ledge is a different story. Not sure. But then - you're not gonna dig sono tubes thru rock are ya?
Back in Maine
Dubbin' Around
Old 04-20-2008, 11:15 AM   #14
Joe Carola's Avatar
Originally Posted by Heefs Home Impr View Post
Techno metal post
Thank You!
Joe Carola
Old 04-20-2008, 11:17 AM   #15
Joe Carola's Avatar
How about a big rock, lets say 16". If you're digging a hole for a sona tube, you can remove it. This thing isn't going to go around it. If it does, it will throw the center of the post off which would change things. Just an observation that's all. Sounds like a good thing either way you look at it.
Joe Carola
Old 04-20-2008, 01:08 PM   #16
deckman22's Avatar
Trade: Deck Builder
Wouldn't work around here, anywhere west of IH35 is solid rock. Last spa pad & concrete patio I poured required getting a drilling truck out who used a core bit, the auger bit just bounced around when it hit rock.
Nice machine if you have dirt.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 04-20-2008, 01:19 PM   #17
Al Smith
A W Smith's Avatar
Nothing in NJ yet, Nearest franchise is north of Schenectady NY. The technique is almost exactly the way utility pole guy wire anchors are installed. They are screwed into the ground by a polecat.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 04-20-2008, 02:21 PM   #18
RobertCDF's Avatar
Trade: Custom deck builder
whats the max loading you have seen? We have loadings on some of our piers in the 8,000#+ range.
RobertCDF is offline
Old 04-20-2008, 02:42 PM   #19
mickeyco's Avatar
Trade: Squirrel Handler
I'd like to know more about them, load ratings, etc, do they have an ICC evaluation report? Maybe a "hinge" situation depending on how far out of the ground they are and deck height. Sure would save a lot of wasted time and travel with inspections.
mickeyco is offline
Old 04-20-2008, 02:45 PM   #20
Joe Carola's Avatar
So far they can hold up a room with a roof load on top.
http://www.tmpo.ca/project/deck/deck.php?lang=en&pic=2
Joe Carola
Help on digging footings afg Excavation & Site Work 4 02-25-2008 07:58 PM
digging a basement in high water table 72chevy4x4 Excavation & Site Work 26 02-01-2008 02:36 PM
digging a pond tbone Excavation & Site Work 14 05-04-2007 12:41 AM
Digging footings-obstructions Greg Di Decks & Fencing 11 12-19-2006 07:11 PM
winter digging chrisherk Excavation & Site Work 9 01-03-2006 07:00 AM
