New Deck
Old 03-01-2005, 04:08 PM   #1
bountyhunter's Avatar
New Deck
I am in the process of building my own house and I will be soon be building the deck onto my new house and wondered about flashing behind the ledgeer board. Some say to do it with both ledger flashing and back flashing and some just use ledger flashing, and others nothing. Any advise to which I should do?
bountyhunter is offline
Old 03-01-2005, 05:52 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: New Deck
Is this ACQ? The old flashing that was always used isn't going to cut it now due to the extra corrosive properties of ACQ, a lot of guys are using copper for flashing, or standing off the ledger board by installing wood spacers between the ledger and the rim joist of the house.
Mike Finley is offline
Old 03-01-2005, 07:03 PM   #3
Re: New Deck
No, this is the old CCA treated pine. It looks like a top ledger flashing is standard practice, but not sure of the back flashing.
Old 03-10-2005, 01:48 PM   #4
HB Decks
HB Construction's Avatar
Re: New Deck
You have the advantage of not having to work with existing siding.
Use aluminum coil stock behind the ledger and then run a piece of Z flash on the top of the ledger board. Let the house wrap fall over the coil stock and the upper piece of the Z flash. Have the coil stock drop over the house wrap on the bottom.
Make certain it is CCA if you use aluminum.
Rod H.
HB Decks
HB Construction is offline
Old 03-14-2005, 06:43 PM   #5
Custom Builder
Glasshousebltr's Avatar
Re: New Deck
Looks like ya bent that with your teeth Chris.
Bob
Bob
Glasshousebltr is offline
Correect Deck ?'s Robert and others IHI Decks & Fencing 9 05-21-2008 10:45 PM
Deck Building Question brewsterb Decks & Fencing 2 06-21-2007 01:29 AM
Dry lower deck stuff frostyfrost Decks & Fencing 12 05-19-2007 07:59 AM
Cedar Deck Prep Problems Larman Painting & Finish Work 2 05-04-2007 05:31 PM
