Need An Idea Of A Time Frame To Build A Fence.
Old 05-06-2015, 11:20 AM   #1
VinylHanger's Avatar
Rewards Points: 6,400
I had a customer ask me to bid a fence. I am not a fence guy so I have no idea how long it should take.
I need to remove 24 8 foot sections and all the posts on two sides of the house and then replace same. It is 1x6 that is on alternating sides and changes from 6 foot to 5 foot in parts.
The originals are a 7 inch board, can I get 7 inch boards?
Also any ideas to makes this go faster would be appreciated. It should be a fun project if I can sell it.
VinylHanger is offline
Old 05-06-2015, 01:02 PM   #2
mako1's Avatar
Rewards Points: 1,094
Re: Need An Idea Of A Time Frame To Build A Fence.
A lot has to do with what you have on hand to remove the old posts and if they will come out clean or break off.Setting posts in concrete?Can you just whack the old ones off and offset the new ones.?A 1x8 is 7.25" wide.A lot of variables to give you a definitive answer.Need more info to be of much help?
mako1 is offline
Old 05-06-2015, 01:30 PM   #3
GettingBy's Avatar
Rewards Points: 6,486
130' lg, 6' h, 3 guys, 8 hours, for our L shaped fence from scratch over uneven terrain, IIRC.
I'd think the post holes would take up the most time. 15, including a gate.
So, figuring manhours per posthole and manhours per foot would be a good start.
I'd get at least five samples from the Web to have some certainty in your bid.
GettingBy is offline
Old 05-06-2015, 01:33 PM   #4
mako1's Avatar
I usually stop in the evening after leaving another job and do the layout if setting post in concrete.I lay it out and then set the terminal posts.That way they are solid the next day to string a line and set the line post.
If you have a bobcat and a chain that will make quick work of pulling the old posts.I do not own one but have access to one.When I don't I pull the posts with an old railroad upright jack and a chain.
mako1 is offline
Old 05-06-2015, 02:21 PM   #5
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 1,986
I've also had several cases where the posts cannot be moved. For pulling posts, you can build an a frame from some of the posts that are easier to remove then use a chain and hoist. Or rent a post puller.
illbuildit.dd is offline
Old 05-06-2015, 03:53 PM   #6
No heavy equipment and it is just me. We discussed a week by myself, so it sounds like I am good on the time. Off setting may be the way to go. Rent an auger and go to town. It seems like a lot of effort to pull them for not much gain.
Old 05-06-2015, 04:11 PM   #7
GettingBy's Avatar
"MP-3 Manual Post Puller is meant to pull posts up to 4" x 4" wood posts or 4" x 6" H column beams. Do not over-
load the post puller. It is designed as a 3 ton puller. "
From a photo, the Harbor Freight model needs a lot more downward force on the handle [How much do you weigh? ] than the MP-3. And it has no ratchet.
With 3 tons force necessary, a comealong hooked to a nearby tree may not be strong enough to vertically pull some posts but a sideways force at the top of the post gives you some leverage and may weaken the post holding power. Or it will snap off the post.
Old 05-07-2015, 10:17 AM   #8
I think I have this worked out. My other question is what fasteners to use. If it was mine, I wouldn't worry too much and just use screws, but I am thinking they are too slow.
What do you fence guys use? I have a stick nailer and up til a year or so ago I had a coil siding gun, , but I can borrow one if needed. Or are ceramic coated screws the way to go?
Edit: Just talked to my fastener guy and 100 bucks for stainless seems like the way to go.
Old 05-07-2015, 10:40 AM   #9
mako1's Avatar
Not a fence guy but have built a hundred or so.Have never used screws on a fence.I won't detail what I use because it will probably cause some arguments.Just be aware of the lumber you are going to use and any reaction it may have with the fasteners.
Screws are not needed .Not because they are slower .They are just not necessary.
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
VinylHanger (05-07-2015)
Old 05-09-2015, 01:17 PM   #10
C2projects's Avatar
Trade: General Contracting
Rewards Points: 1,084
I used to screw every board in.. It was terrible and I hardly made any money on fences. Ive started to staple the pickets on and screw the 1x4 trim on which has been a real time saver
Proper Prior Planning Prevents Piss Poor Performance
C2projects is offline
Old 05-09-2015, 03:35 PM   #11
mako1's Avatar
I will not use staples on a fence.Have never found any that hold up well.
mako1 is offline
Old 05-15-2015, 08:03 AM   #12
mako1's Avatar
Think we've got a little spam going on here?
mako1 is offline
Old 05-15-2015, 10:16 AM   #13
I hate spam. Especially in my thread. I feel sorry for them though as they are idiots and don't even know it. Probably all the preservatives in that stuff.
Old 05-15-2015, 12:58 PM   #14
mako1's Avatar
Man ,I feel strange now,I was on here early this morning and there was a post #1 from some guy asking about a fence or something and had a link on his post going to some kind of "Buying gold thing".
Hence the spam post of mine.I feel a bit strange now seeing that it's gone and no reference to it.I know I didn't dream this chit up or was it just removed by the mods?
My post is still here and you guys are probably wondering what the hell is wrong with me?
mako1 is offline
Old 05-15-2015, 01:34 PM   #15
Nope. It was there. You're not hallucinating.
Old 05-15-2015, 01:37 PM   #16
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
What the hell is wrong with that Mako guy???
-Steve
TimelessQuality is offline
Old 05-15-2015, 01:59 PM   #17
mako1's Avatar
Thanks Vinyl.For a minute I thought I was back in the 70's
mako1 is offline
Old 05-15-2015, 03:42 PM   #18
RiverBG's Avatar
Trade: Home rehab specialist
Rewards Points: 764
What do you prefer to screws? I have built plenty of fences and have always used screws, but the only reason I have is that's the the way my dad used to do it.
RiverBG is offline
Old 05-15-2015, 03:50 PM   #19
mako1's Avatar
I use the appropriate nail for he job.I understand the staple argument and the people that say staple will hold better than nails but the staples they use always seem to be a much smaller diameter than the nails and will fail in less time.They also do not have the coating on them to hold up as the nails do.
mako1 is offline
Old 05-15-2015, 03:51 PM   #20
RiverBG's Avatar
Rewards Points: 764
Say for 1x6 pickets what's an appropriate nail? Ringshank galvy?
RiverBG is offline
Made in USA product list J.C. General Discussion 338 10-24-2017 12:02 AM
Kitchen remodel time frame jhcontracting Kitchens & Baths 56 06-26-2017 07:24 AM
Curious how you'd design & build this pinwheel Finish Carpentry 13 02-02-2014 02:42 PM
Veneering / Enertainment Unit Build J.C. Finish Carpentry 17 12-08-2012 09:52 PM
DW744 Fence Adjustments TBFGhost Tools & Equipment 3 05-30-2012 04:21 PM
