Need Help On How To Attach Wood To Metal Posts
Old 05-06-2009, 09:39 PM   #1
What goes in this space?
FJRFencer's Avatar
Trade: Fence installations
I received an invitation to bid on a project that has me a little cornfuzzled.
there is no detail on how to attach a wooden slat (1x6) to a square metal poly coated 4x4 post. the slats are to overlap and form a wall similar to siding
something like this
but between the posts rather than on top of them. If it were a wooden post I could Dado a channel and slide the board in.
So far, the only idea I have had is to run a 2x2 strip on the inside of the metal post, attach it to the post and then screw the boards to it.
Thoughts?
http://www.jandkfencing.com
FJRFencer is offline
Old 05-06-2009, 09:50 PM   #2
John Hyatt
John Hyatt's Avatar
Re: Need Help On How To Attach Wood To Metal Posts
Nice Ride FJ. I am a Harley man but I really like watching Johnson racing he rides like a bird.
I tap con pt 2xs to the metal posts,fasten pt stringers to the 2xs, install the fencing to the stringers. Works great. J.
John Hyatt is offline
Old 05-06-2009, 10:08 PM   #3
FJRFencer's Avatar
Originally Posted by John Hyatt View Post
Nice Ride FJ. I am a Harley man but I really like watching Johnson racing he rides like a bird..
I have flown like a penguin when the back tire broke loose
I am gonna give a call to the contractor in the morn. From the drawings, it looks like both sides are to be "clean" minus the slats. so if I understand what you are suggesting, I don't believe this would be acceptable.
Old 05-06-2009, 10:28 PM   #4
John Hyatt
John Hyatt's Avatar
Its all with the rear tire,shocks adjustment,and a little fun with the gas!!!
Good looking on both sides with metal posts= wrapping the posts after pt on both sides,install the stringers inbetween, fasten the fenceing detail in the middle on both sides. This is a real money maker with the right Wallet. J.
Old 05-07-2009, 10:52 PM   #5
FJRFencer's Avatar
Well, John, It looks like you are the only one on this board that can help me brainstorm after 55 hits on the thread.
For that, Thanks.
After reading numerous threads over the last month, I am beginning to determine there is not a lot of help on this board.
I am glad the motorcycle community will reach out more than the contracting community.
Old 05-07-2009, 11:07 PM   #6
master of none's Avatar
Trade: carpenter
For that, Thanks.
You got the right answer right off the bat.....use self tapping screws to fasten a piece of 1x4(I would use 2x4) to the post. after that build it however you want....no problem....
master of none is offline
Old 05-08-2009, 02:06 AM   #7
BuiltByMAC's Avatar
Trade: Construction
hey, we live to serve.
Mac
BuiltByMAC is offline
Expanded Metal in Security Wall? RizzoMaryland Commercial Construction 17 03-03-2010 09:11 AM
metal track installation kamileoosh Construction Picture Post 6 05-04-2009 09:30 PM
metal track installation kamileoosh Framing 27 04-19-2009 10:41 AM
Metal roofing Help The Boys Roofing 9 08-22-2008 09:28 PM
