Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Decks & Fencing
Closed Thread
Old 09-28-2009, 02:13 PM   #1
Trade: wheelchair ramps
Need help with the bidding process (Wheelchair ramps)
I currently work for a DME company and build wheelchairs from the ground up. We do custom molding and such. I am in the process of starting a small construction company on the side. The only thing I am interested in building at this point, is wheelchair ramps. I have built wheelchair ramps before, but for family. My question is how the bidding process works. I know that home health care agencies usually take the lowest of three bidders. Aside from material costs, how much do I need to add to the bid? How much is too much? I am in the Mount Pleasant, East Texas area. Any advise is greatly appreciated.
user52810 is offline
Old 09-28-2009, 02:16 PM   #2
Starving Tile Artist
wizendwizard's Avatar
Trade: Carpentry, Flooring & (UGLY) Tile installs.
Send a message via Yahoo to wizendwizard
Please use the search button above search : Ramp-a-thon
"If you start the grout process over, you too could use sparkly grout!"
Columbia SC Tile Installer
http://www.adepthomerepair.com
Adept Home Repair Services
wizendwizard is offline
Old 09-28-2009, 03:46 PM   #3
Illusion of Perfection
CookeCarpentry's Avatar
Trade: Residential Remodeler/Custom Carpenter
One thread wasn't good enough, you had to start two?
How many are you going to start before you realize your answer will not be found on here - or at least an answer you like....
Mark
Wayne, PA
"It is what it is."
CookeCarpentry is offline
Old 09-29-2009, 10:35 AM   #4
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
All wheel chair ramps built for home health care facilities went to the by the pound bidding process back in 2006. You need to calculate the weights of your materials and then find the government medicade form that shows you area's factoring. Some of it is kind of tricky, like the concrete weighting factor since it will depend if you are using dry bags and then adding water or having concrete delivered pre-mixed, as they will only allow for the actual dry weight if dry bags are used. You might have to calculate it both ways. Once you have the wieght and your local factor just grab the calculator and you're done.
Mike Finley is offline
The Following 3 Users Say Thank You to Mike Finley For This Useful Post:
N.Schiffer (09-29-2009), redwood (09-29-2009), samccard (09-29-2009)
Old 09-29-2009, 12:26 PM   #5
N.Schiffer's Avatar
Trade: Custom Carpentry
Send a message via AIM to N.Schiffer
Mike has got it Don't forget to minus the weight of the dirt taken out.
Nick Schiffer
Specializing in Custom Sheds
Custom Carpentry
& General Construction
N.Schiffer is offline
Old 09-29-2009, 02:21 PM   #6
framer
steves's Avatar
Trade: framing
Mike,
I believe you are incorrect in the fact that medicade determins the factor multiplier.
If you were paying attention you would know that thru the passing of house resolution 745.54/97J the factor analysis was taken out of medicade's scope and put into Health and Human factoring adjustments of 2009, please know your info before posting!!
steves is online now
Old 09-29-2009, 05:29 PM   #7
John Hyatt
John Hyatt's Avatar
Trade: out door areas, decks,spa room additions,fire pits,custom design
I am all in favor of Human Factoring as well as adjustments in health. But I dont like steves tone. JonMon
Geting Major Yucks!!!!!!!!!!!!!
John Hyatt is online now
Old 09-29-2009, 06:13 PM   #8
samccard's Avatar
Trade: Builder/Remodeler
I would add one million dollars to the bid!
samccard is offline
Old 09-29-2009, 06:44 PM   #9
BLDG Inspector, G.C
Trade: BLDG Inspector, G.C
YOU GUYS ARE KILLING ME.
spdtrx is offline
Old 09-30-2009, 01:42 PM   #10
ChrWright's Avatar
Duplicate thread:
At the end of the day no one here can price a project sight unseen, for someone else's business, in someone else's market. Asking for an "average" or "ball park" cost is unproductive at best.
There's nothing wrong with being new, but take some time to search the forum on the subject of bidding and pricing. You'll find a number of good threads that will point you in the right direction.
This thread is now closed.
Christopher Wright, WrightWorks, LLC
www.WrightWorks.net - Facebook - Christopher Wright, Remodeling Info on Twitter
Indianapolis Remodeling Contractor - Remodeling Photos: Kitchens, Baths, Room Additions, Basements
"Form follows function - that has been misunderstood. Form and function should be one, joined in a spiritual union." -Frank Lloyd Wright
ChrWright is online now
Closed Thread
Question for GC'S about the sub bidding process kc brick layer Commercial Construction 27 10-06-2009 10:03 AM
ADA Wheelchair Ramps - Need Advice on Pricing Home Services Carpentry 12 05-06-2009 07:48 PM
please help new to the bidding process nfink Painting & Finish Work 8 08-18-2008 07:58 AM
Bidding Process -- How Detailed Are You? Dominion Commercial Construction 13 01-29-2008 09:33 PM
bidding process importer Business 3 09-21-2007 08:02 PM
