More Curves
Old 11-18-2009, 09:03 PM   #101
Dexpert's Avatar
Trade: Decks - Retail
Re: More Curves
That is REALLY nice. Amazing work Bone.
Dexpert is offline
Old 11-18-2009, 10:36 PM   #102
John Hyatt
John Hyatt's Avatar
Re: More Curves
Intersting that cabot finish stuck to the coating you put on those crafted 2 x 12s,,, Thanks Man. JonMon
John Hyatt is offline
Old 11-18-2009, 10:57 PM   #103
Quinn's Avatar
Trade: Deck builder /contractor
Re: More Curves
Nice work, Bone
Quinn is offline
Old 11-18-2009, 11:08 PM   #104
The Deck Guy
Greg Di's Avatar
Re: More Curves
Nice work!
How long did it take you to stain hat undercarriage?
I don't have the patience for that but it would be a nice upsell on the right deck
Greg Di is offline
Old 11-18-2009, 11:20 PM   #105
stp57's Avatar
Trade: carpenter/ handyman
Re: More Curves
how did you curve that one handrail?
Steve
stp57 is offline
Old 11-19-2009, 12:12 AM   #106
Charitable animal
Bone Saw's Avatar
Trade: decks
Re: More Curves
http://s692.photobucket.com/albums/v...view=slideshow
THANX guys, greg, 2 coated it before decking went down, half a day, beams and posts 2 coated last 2 days, no time with a foam roller.
Bone Saw is offline
Old 11-19-2009, 04:28 PM   #107
Charitable animal
Bone Saw's Avatar
Trade: decks
Re: More Curves
photobucket is crap, here is a good link
http://cid-65116d85be691b09.skydrive...spx/juli?ref=1
Bone Saw is offline
Old 11-19-2009, 07:17 PM   #108
John Hyatt
John Hyatt's Avatar
Re: More Curves
Geting strength with that inside cap/botom rail with no center post is pure genius. It looks like you used the little shoes and steel balusters over there. J.
Old 01-01-2010, 12:18 AM   #109
deckman's Avatar
Trade: deckbuilder
Re: More Curves
here is one we did
deckman is offline
Old 01-01-2010, 01:44 AM   #110
BuiltByMAC's Avatar
Trade: Construction
Re: More Curves
Though you've been a member for 2 years, I'll say welcome to the site, deckman... is this Barry or Barb?
Mac
BuiltByMAC is offline
Old 01-01-2010, 03:10 PM   #111
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Re: More Curves
I'll echo Mac- you've got some great pix on your site... howz about an intro?
~Matt
BreyerConstruct is offline
Old 01-01-2010, 07:04 PM   #112
redwood's Avatar
Trade: Carpentry Contractor
Re: More Curves
Another project that I would have to think three times about attempting. Good Job.
Is it me or the pix's, but something doesn't look quite right regarding the inside stair railing. It's probably the image perspective.
Mark
Los Gatos, CA
www.creative-redwood-designs.com
redwood is offline
Old 01-01-2010, 07:16 PM   #113
Charitable animal
Bone Saw's Avatar
Trade: decks
Re: More Curves
inner and outer are different pitch
Bone Saw is offline
Old 01-01-2010, 08:10 PM   #114
crovello's Avatar
Trade: General contractor
Re: More Curves
Originally Posted by deckman View Post
here is one we did
The underside looks like it is plywooded. What is on top for decking.
crovello is offline
Old 01-02-2010, 09:07 AM   #115
John Hyatt
John Hyatt's Avatar
Re: More Curves
I am thinking a roof of somekind is under the decking so the project drains to the outside. If so that post beam conection to the left of the warped stairway is exposed to the drain water, not good. J.
Old 01-02-2010, 03:29 PM   #116
redwood's Avatar
Re: More Curves
I'm hoping that it has one of those underdeck drain troughs, that drain into a gutter at the beam.
Mark
Los Gatos, CA
redwood is offline
Old 01-02-2010, 11:21 PM   #117
crovello's Avatar
Re: More Curves
I have seen those systems used but never covered with plywood.
I wonder why he has not posted since that one and only post.
crovello is offline
Old 01-04-2010, 05:21 PM   #118
deckman's Avatar
Trade: deckbuilder
Re: More Curves
I recently rediscovered this forum. I forgot I joined a couple of years ago.
we built this set of steps back in 08. We used Moisture Shield for the fascia and most railing parts. Fiberon tropics jatoba for the decking. we have been installing a dry in system we developed about 5 years ago that allows us to use whatever finished ceiling material is desired. We used a rough sawn plywood which is a very popular soffit material here. This projects ceiling has been stained all columns have been faced with rock veneer since this picture. And Mac this is Barry. John I can assure you the top of that dropped beam is not exposed to water. We live in Colorado ,at elevation, so moisture is almost non existent.
deckman is offline
Old 01-04-2010, 05:30 PM   #119
UpNorth's Avatar
Trade: Engineer & Ret. GC
Re: More Curves
The drain is evident in the picture.
UpNorth is offline
Old 01-04-2010, 07:36 PM   #120
John Hyatt
John Hyatt's Avatar
Re: More Curves
I do see what could be a drain pipe on a post. Intersting. J.
more curves Bone Saw Decks & Fencing 14 04-03-2008 12:19 PM
Cutting curves in vct Cook Flooring 2 08-24-2007 05:55 PM
Pictures of a hoodfan. JustaFramer Carpentry Picture Post 19 02-08-2007 04:29 PM
Flexible Foam Crown Molding pshammond Finish Carpentry 11 08-06-2006 11:53 PM
Curves! Kevin Decks & Fencing 3 09-15-2005 10:02 AM
