Mahogany Porch Flooring
Old 06-18-2013, 11:01 PM   #1
chapstick's Avatar
Trade: carpenter
Rewards Points: 25
I just landed a job rebuilding a 300 sq ft front porch on an old craftsman home. We will be using t&g mahogany 3/4" thick. The porch is covered and the handrails will be 36" tall knee walls with cedar shakes covering them. There shouldn't be too much rain water getting on it but I'm still going with 1/4" per foot pitch anyway. The boards will be perpendicular to the house.
So anyways, I have installed t&g mahogany a couple times and never had any problems but i have been reading horror stories about boards buckling and serious repairs having to be done on the contractors dime. I really don't want this to happen ! I'm not going to gap them at all but I'm also not going to slam them together super tight. I think I'm going to fasten them with screws toed through the grooves and into the joists.
I saw this new screw system called "Camo" and it uses pretty stout trim screws and that's what I want to use. I have read some guys also use adhesive in addition to the screws to prevent buckling. It seems like overkill to me. What do you guys think ?
chapstick is offline
Old 06-19-2013, 06:54 AM   #2
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 1,044
Re: Mahogany Porch Flooring
Camo = no good
grk #7 ss or stainless cleat nail.
PL premium
Airflow, airflow, airflow.
Make sure to have airflow on sides and if needed vents in places at the highest point of the decking.
Make sure decking can drain past wall.
Deckhead is offline
The Following 2 Users Say Thank You to Deckhead For This Useful Post:
greg24k (07-01-2013), Tom M (06-19-2013)
Old 06-19-2013, 08:52 AM   #3
Tom M's Avatar
Rewards Points: 4,738
And then theres board sealing. Never heard an answer I liked and the theory is all over the place. Sand off mill glaze on all sides then seall all sides has been recommended but is an insane process. I would just seall cuts, then sand and seal the top after installed my next time around.
Tom M is online now
Deckhead (06-19-2013)
Old 06-19-2013, 09:04 AM   #4
Deckhead's Avatar
Trade: Carpentry,
Never seal the whole thing on porch flooring as it would interfere with glue adhesion. Youre right sand/seal after installation and end cuts.
Deckhead is offline
The Following User Says Thank You to Deckhead For This Useful Post:
Tom M (06-19-2013)
Old 06-20-2013, 12:53 AM   #5
chapstick's Avatar
Trade: carpenter
Rewards Points: 25
I have used the stainless screws in the past and boy, when the heads strip it's an instant battle. I was liking the Camo screws because they look like they wouldn't strip nearly as easy and they are rust resistant. What is the downside to these screws ? Not the whole system obviously, but just the screws. I agree with if I was to finish the bottoms of the boards the pl wouldn't bond properly. In the past i actually sprayed the boards down with glycol to prevent mold down the road. I don't know if that's just An old wives tale but there has never been any mold. And after the install i finished it with cabbots Aussie oil and it worked out great. But this time i will definately be paying much more attention to venting and be gluing everything down as i go.
Old 06-20-2013, 12:56 AM   #6
chapstick's Avatar
Trade: carpenter
Rewards Points: 25
And speaking of the Camo system, have you tried it ? Clearly wouldn't work with PT due to gaps being way too big after drying out but it looks like it may work ok with PVC/composites. Much cheaper and faster than tiger claws i would think.
The Following User Says Thank You to chapstick For This Useful Post:
Deckhead (06-20-2013)
Old 06-20-2013, 06:47 AM   #7
Deckhead's Avatar
Trade: Carpentry,
It can't even come close to comparing to tigerclaw for speed, not much can if using the gun. And this is coming from an ipe clip fan.
The main reason ss screws strip is because user isn't in line with the screw with his drill tip. For #7 or 8 screws use a 9/64" drill bit to predrill and success will be yours.
Camo screws aren't ss, I don't like anything in the new pt or exotics that isn't ss.
Deckhead is offline
Old 06-20-2013, 11:41 PM   #8
Love What You Do !
livingsoulsdie's Avatar
Rewards Points: 150
I just repaired a mahogany t&g deck that was brand new. It buckled so bad that there was a hump that stuck out 1' up. Also the sides pushed out nearly an inch. I'm completely opposed to using any kind of t&g flooring outside, its just a disaster waiting to happen.
livingsoulsdie is offline
Old 06-22-2013, 07:05 PM   #9
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Late term post due to the mafia type requirement imposed having to use google chrome. Don't they have enough money/control already ?
Mahogany has become a generic term,what kind of wood are you actually using ?
JonMon www.deckmastersllc.com
John Hyatt is offline
Old 06-22-2013, 07:55 PM   #10
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Dont they call it "meranti decking"?
I dont like the stuff. Nor do i offer it. ive heard too many stories about buckling, severe checking and spliting.
To the op listen to the pros suggestions and you should be good.
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 06-22-2013, 08:16 PM   #11
Deckhead's Avatar
Trade: Carpentry,
red balau is another type they like to call mahogany. Funny thing is its about 12,000 miles from being real mahogany...
It comes from southeast Asia not south America and can be used successfully in the right scenarios but acts waaaay different. Doesn't do well in Florida at all.
Deckhead is offline
Old 06-22-2013, 09:58 PM   #12
Talking Head
EthanB's Avatar
Rewards Points: 14
They call meranti "mahogany" because calling it lauan would drastically lower the sales. It's actually shorea.
Red Balau is also shorea. There are almost 200 different species of shorea but a lot of them are endangered.
Planer.....
EthanB is offline
Old 06-23-2013, 08:13 AM   #13
John Hyatt
John Hyatt's Avatar
Philippine and Cuban mahogany were the Best. Really nice lumber.
Asia material not so much.
When I install SA T&G decking I order it with an extra 1/8'' in the G,cut a 1/2'' slot in the T every 3' or so, install thru the G with ss screws after a predrill. Done right the slot and screw don't show. This decking drains the same way as any other thru the 1/8'' gap.
Provide positive cross ventilation, use construction adhesive on the joists, don't jam the decking up.
I have projects out over 10 years done this way, one 8'' off the ground.
Old 06-23-2013, 08:25 AM   #14
Deckhead's Avatar
Trade: Carpentry,
You are really good, or really lucky, but you definitely have guts. Is the deck exposed w/no roof?
Deckhead is offline
Old 06-23-2013, 08:30 AM   #15
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
New Guy what about the picts.....
CITY DECKS INC is offline
Old 06-23-2013, 08:31 AM   #16
John Hyatt
John Hyatt's Avatar
Several jobs were exposed to the weather full bore. One is the floor of my spa room building.
This is not luck but the result of study, planing, tests, install.
J.
The Following User Says Thank You to John Hyatt For This Useful Post:
Deckhead (06-23-2013)
Old 06-23-2013, 10:41 AM   #17
deckman22's Avatar
Trade: Deck Builder
Rewards Points: 4,364
Did you have to install the mafia chrome to get up and running again? I have resisted installing chrome even tho I can't view some pages.
Deckman
www.alscustomdecks.com
deckman22 is online now
Old 06-23-2013, 12:19 PM   #18
John Hyatt
John Hyatt's Avatar
That is the only way I could do it Al.
Seems like the site has been released to google after the last maintenance session.
J.
Old 06-23-2013, 06:50 PM   #19
John Hyatt
John Hyatt's Avatar
I am not understand how a search engine, even one as big and money glutted as google, can control a web site like this one.
Old 06-23-2013, 07:01 PM   #20
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,292
It works on my phone, with FF, IE, safari, chrome, no issues what so ever.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Made in USA product list J.C. General Discussion 344 12-24-2017 11:54 AM
T&G Azek porch flooring Windwash Decks & Fencing 21 02-25-2013 07:34 PM
Deck and porch framed maleko Decks & Fencing 179 09-19-2012 10:16 PM
Whats the best hidden fastener system for mahogany? maleko Decks & Fencing 7 08-07-2012 03:51 PM
t&g porch flooring vs. deck boards phnola Carpentry 3 11-17-2011 07:03 PM
