Trade: Carpenter and Joiner
Low Lying Deck
I'm looking at building a deck 5" from soil to underneath of deck boards. Any ideas on construction method? Major concerns-not enough room to have bearers. It's not over concrete so can't baton it.
#2 | |
Re: Low Lying DeckQuote:
4X4 flush beams 4' on center, with piers 4' on center, and 2X4 joist 16"o.c. hung between the beams. I don't do metric, but 2X4 is 1½"X3½" here. Sounds like a mares nest, but doable.
Re: Low Lying Deck
why not take out enough dirt to get framing under the deck, put down some rock and landscaping fabric to keep out water and call it good?
Trade: Carpentry Contractor
Re: Low Lying Deck
You can do it as Neolitic describes or eliminate the 2x4's and use more 4x4's. Which method you use might be determined by the decking you use. If you use 5/4 ipe, you can probably span 32", thought we usually go 24".
I'm not a huge fan of the JH method because of squeeks and movement, especially with little 2x4 JH's. |
John Hyatt
Re: Low Lying Deck
One way I have done it>>>rip a 2x6, construstion adhesive, fasten the two 2 5/8'' into one, use them with a 6' span flush framing.
5'' is plenty of space to do this, provide cross ventalation when using ipe that low to the ground a couple of ways to do this>>> screen vents cut in the rim, floor vents cut into the decking, or for really low projects install black flex pipe coming from under the deck to the outside with china caps. J. |
Trade: Outdoor contracting: fences and decks
Re: Low Lying Deck
Several methods can be used
1] dig trenches and sink the footings to the bottom of the trench, then put the beam into the trench. Fill with gravel and filter cloth to minimize water problem 2] Put all the joists directly on 6x6 sleepers buried into the ground: no concrete footings as such 3] double up the header and use it as the beam, supported by footings. Then, at the point where you might need a second beam, again double up headers and put footings under that, then hang the joists from the header/beam. Any one of the 3 works fine. I have done hundreds of ground level decks. |
| 24x24 Deck | amanandhisvan | Decks & Fencing | 63 | 09-24-2008 11:59 PM |
| Looking for deck and fence builder - Chicago west suburb | Green_2 | Help Wanted or Looking For Work | 0 | 09-07-2008 06:34 AM |
| Used the new Correct Deck CX-personal review | IHI | Decks & Fencing | 22 | 07-27-2008 09:52 PM |
| Laying over old deck | Mike Finley | Decks & Fencing | 20 | 06-24-2008 12:37 AM |
| Waterproofing a deck - looking for ideas | Laketahoedan | Carpentry | 12 | 04-03-2008 06:54 PM |
