LockDry Aluminum Decking
Old 04-22-2009, 07:35 PM   #1
decks-patios-remodeling
deckndave's Avatar
Trade: Deck, patios & remodeling
I have a prospect that wants his deck built using this product. It seems easy enough to work with but I have questions on how some of the accessory components are installed. I spoke to the rep today and he tried to answer my question about how the risers on the stairs work etc. (don't think he really understood the question). Does anyone have experience using this product and what did you use for the stair risers, tread nosing and what did you use to wrap the perimeter fasca with? Any and all thoughts from those in the know would be great. Thanks!
deckndave is offline
Old 04-22-2009, 09:31 PM   #2
deckndave's Avatar
Re: LockDry Aluminum Decking
Looks like I have stumped the deck gods. 16 views so far & no replies...
Old 04-23-2009, 06:58 AM   #3
General Contractor
greg24k's Avatar
I was in Vegas at the Deck show and was talking to a rep. Of course he will paint a perfect picture, but looking at it, I think it sucks. The only trim available it T-Molding and edge Trim. I don't like how the edge trim goes on and you see the screws. Trim will trap dirt on top and stairs and it be a bitch to keep it clean. I asked him about it and he started to change the subject. If I had a dock, maybe I would consider it, if I was to put in on my house, I wouldn't take if it, if someone gave it to me for nothing. It looks and feels like a fancy Mezzanine in the wear-house.
I guess its the matter or preference.
greg24k is offline
Old 04-23-2009, 09:06 AM   #4
deckman22's Avatar
Trade: Deck Builder
My supplier carried it for awhile, the stuff never sold so they gave me the display deck made with it. I put it on my buddies travel trailer down at the coast, looks exactly the same as it did several years ago. For looks I give it a 1 on a scale of 1-10, durability you have to give it a 10 tho. Oh yeah, it was slippery as heck when wet, busted my arse more than once on that darn deck. As far as working with it I don't have a clue.
Deckman
www.alscustomdecks.com
deckman22 is online now
Old 04-23-2009, 05:57 PM   #5
The Deck Guy
Greg Di's Avatar
If that doesn't answer ALL your questions, nothing will.
Greg Di is offline
Old 04-23-2009, 10:10 PM   #6
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
So... what should you charge to install it?
~Matt
BreyerConstruct is offline
Old 04-23-2009, 11:42 PM   #7
The Deck Guy
Greg Di's Avatar
~Matt
Duh. 59 cents a cubic foot. You are such a dummy.
Greg Di is offline
Old 04-26-2009, 10:29 AM   #8
katoman's Avatar
Trade: carpenter
Done this. Decking locks up great, no leaks, finished the rim boards in alluminum, used structural aluminum posts, aluminum spiral staircase ( it was second story deck ) This stuff installs as fast as decking. Only compaint from homeowner the next year was that it is hot on the feet.
katoman is offline
Old 04-27-2009, 01:38 AM   #9
deckndave's Avatar
Did you use aluminum coil stock for the rim or something else? And what about stair nosing and riser materials. I was thinking about using TT XLM to face the rim, stair stringers and risers.
Old 04-27-2009, 08:29 PM   #10
katoman's Avatar
Trade: carpenter
ok, a little more info - joists run out from house, strapped with 2x4, so decking will drain, requires very slight slope. They make a finishing strip for the exposed ends, and I used flat stock to make facia that went up under this strip. Same finish at the stair. We also finished the under side with vented soffit. Railings were aluminum with glass panels. He's a repeat customer, been about 5 yrs. now, no problems. Their requirement on the project was to have absolutely no maintanance. You'll need a good carbide blade for your chop saw, get one designed to cut aluminum. This stuff is expensive and I guess with the strapping out a little more work than decking, but it went pretty fast and no problems encountered. Oh, and the company did the take off from a simple drawing I sent them, and they spec'd and sent everything I needed. Can't remember their name right now but think they were in Georgia.
katoman is offline
Old 04-27-2009, 10:08 PM   #11
deckndave's Avatar
Katoman..you da man. I appreciate the info. But by strapping do you mean sleepers run perpendicular to the joists to get the proper fall??
Old 04-28-2009, 06:23 PM   #12
katoman's Avatar
Trade: carpenter
Correct. Decking runs away from home to accomodate fall. Watch your joint at the wall. We cut a slot in the mortar joint and installed flashing on a 1x4 tapconed to the wall.
katoman is offline
Old 08-26-2009, 10:33 PM   #13
21gun's Avatar
Trade: carpenter
i hate to post on an older thread like this but i want to get some more chat on this stuff.
I looked into the stuff today at a local distributor. the guy was very cool there and gave me a ton of samples. Sounds like really good stuff but high, oh my god, my cost is 6.40 a sq ft. thats more than composit at lowes by a touch.... composit never really did it for me anyway.
The customer i have needs a dry space below so i thought about the boat docks they use it on... seems to be a great system. They claim it is cooler on the feet than wood or cement, weighs only 2 # per sq foot. Goes on like butter. I dont see what's not to love except the price.
Sounds like they have put together a new powdercoat system for it, with a nice slipresistant finish. For the standard deck (wet below not a factor) they have a new deal for that too, somewhat cheaper too. fastens to joist between the boards with a stainless screw and some fancy locking clip that aligns the boards with proper spacing. Looks cool too, but why not just keep the water off the joist to begin with by using the lockdry system? installs eaiser too.
I'm lovin this right now, but havent installed it yet, might not get to at that price!!! MSRP is 8 bucks a sq ft. 20% contractor discount makes it 6.40 a foot.
Would love to see some trim work on the outer bands on some decks. Aluminum coil isnt recommended on treated wood tho i'm told it will eat it up, but have done it many times myself. Always used to put up coil on the house before laggin up the ledger board.
Would love to hear some more thoughts on this stuff, i've done all the homework i can... now i need to hear it from the installers.
Thanks in advance guys.
carpet? no, we dont do carpet.
No sir... that spells CARPENTER.
21gun is offline
Scrap aluminum prices vs. aluminum soffit prices Jer Windows, Siding and Doors 8 01-20-2010 07:33 AM
Aluminum Fascia eglanc Windows, Siding and Doors 38 05-02-2009 11:41 PM
Preference in the Way your Decking Boards Turn jcalvin Decks & Fencing 25 03-12-2009 02:01 PM
How much decking... ruskent Pool Construction & Enclosures 2 03-08-2007 08:38 AM
