Trade: Squirrel Handler
Ledger Board Flashing, Inside Corner
What material do you use and how do you flash an inside corner where two ledger boards meet on ACQ?
Charitable animal
Trade: decks
Re: Ledger Board Flashing, Inside Corner
hej Mickey (no pun intended), when I flash "down and over" (z/c-5 copper edge, or roll for that matter) I do it much the same way as you would do an apron and a step flash coming together on a roof, then put a generous dab of acrylic elastomeric caulk over the "crook" . when flashing agains stucco, I go "between up and over" with york roll and leave the roll long past the end grain abbutting the wall , then pleate the upper exposed protion, the whole ledger would get bevel ripped and caulked with same caulk to make a fillet between ledger and wall.
Trade: REMODELING CONTRACTOR
Galv. flashing, cut the bottom leg & bend to create the inside corner. Seal the overlap made by the cut.
Steve. |
Thanks for the responses, I have a sub (should have done it myself, but didn't have the time) who used aluminum (the ledgers are treated CA-B, I thought it was ACQ), left big gaps and seems to think it's OK, "everyone does it that way". I use copper, stainless (if spec'd) or vinyl (pre-formed and bendable) with butyl rubber caulk, I have seamed and soldered copper on an inside corner before. I'm having them re-do it but was curious how others do it. I printed out your responses and showed them to him.
| Licensed & Insured | bjg5240 | Business | 34 | 06-09-2009 07:56 PM |
| Transitioning drywall with cement board | Lone Wrencher | Drywall | 19 | 03-02-2008 07:05 AM |
| Help with - Inside corner trim for vertical cedar siding | wallmaxx | Framing | 3 | 07-22-2007 06:47 PM |
| Corner beads, J-mould, etc... | theworx | Drywall | 4 | 01-27-2006 02:04 AM |
| Question about inside corners | Lone Wrencher | Drywall | 36 | 12-08-2005 07:37 PM |
