Lasers
Old 11-29-2017, 06:31 PM   #1
AlexADB's Avatar
Trade: Decks
Rewards Points: 32
Lasers
good evening. sometimes we build decks and their ends up being a lot of posts. i typically sink the posts in the ground, tack up joists and beams, make sure everything is level, then cut my posts for beams.
does anyone use lasers to get your post heights? This would seem to save a lot of time. or should i just eliminate posts by selling steel frame decks from here on out? wood sucks.
AlexADB is offline
Old 11-29-2017, 07:27 PM   #2
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 5,393
Re: Lasers
Just take jobs with flat yards.....
Try driving piles with a dragline and diesel piledriver....
Another proud public school Graduate?
Fouthgeneration is offline
Old 11-29-2017, 10:16 PM   #3
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,260
Re: Lasers
Yup, I'd use a laser most every time...
mstrat is offline
Old 11-29-2017, 10:22 PM   #4
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 1,674
Re: Lasers
just order the correct post lengths straight from the lumberyard
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is online now
Old 11-29-2017, 11:24 PM   #5
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,710
Re: Lasers
Really. In concrete? Just in dirt? Any footings?
Do steel-framed decks not have posts, or need to be leveled?? Maybe I should have gone into structural steel construction.
wood sucks.
Delta
I have an Edifice Complex.
Fouthgeneration (11-30-2017)
Old 11-30-2017, 07:40 AM   #6
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 1,135
Re: Lasers
Delta
Steel decks are self-leveling.
Big Johnson is online now
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
Bull Trout (12-01-2017), Seven-Delta-FortyOne (11-30-2017)
Old 11-30-2017, 10:22 AM   #7
VinylHanger's Avatar
Rewards Points: 6,920
Re: Lasers
I think he may be trying to sell something.
VinylHanger is offline
Old 11-30-2017, 04:28 PM   #8
AlexADB's Avatar
Trade: Decks
Rewards Points: 32
Re: Lasers
What is that supposed to mean?
AlexADB is offline
Old 11-30-2017, 04:45 PM   #9
AlexADB's Avatar
Trade: Decks
Rewards Points: 32
Re: Lasers
Delta
Delta, this thread was intended for deck builders. Steel frames allow longer beam and joist spans; thus, eliminating posts. How many posts? Nearly 50% on my current project. That's a lot less posts to set and level, yes?
Holes are 24" deep by 18" wide and must bear on solid ground. holes <5 from the house go down to the foundation. Oh, and our footers are 6" thick minimum.
We take our decks and business seriously in Northern Va. Steel is a superior product, in my professional opinion. Not sure if your clients can afford it; but, mine can.
Thanks,
NoVa
AlexADB is offline
Old 11-30-2017, 05:00 PM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,044
Re: Lasers
I use lasers for everything.
Inner10 is online now
Old 11-30-2017, 05:05 PM   #11
AlexADB's Avatar
Trade: Decks
Rewards Points: 32
Re: Lasers
Thanks. I think it's going to be a good thing
AlexADB is offline
Old 11-30-2017, 05:08 PM   #12
AlexADB's Avatar
Trade: Decks
Rewards Points: 32
Re: Lasers
i feel like lasers might be getting my money for nothing and the chicks for free by comparison.
AlexADB is offline
Old 11-30-2017, 07:43 PM   #13
Trade: Masonry
Re: Lasers
AlexADB: the Public school jab was a comment on your lower case 'i' for I....and your confusing/conflating leveling with plumbing columns....
If you'd use wider joist boards, fewer posts would be needed all other things being equal...
Have some explain how three span decking board conditions and Cantilevered overhangs could further reduce structural component sizes and number of pieces.
Old 11-30-2017, 08:06 PM   #14
AlexADB's Avatar
Trade: Decks
Rewards Points: 32
Re: Lasers
1) i'm looking for LEVEL CUT LINES FOR BEAMS. not looking to have a laser plumb my posts.
2) using wider joists and 3ply beams are typically not practical. again, this post was for actual builders. i don't need anyone to explain beam or joist span tables to me. i also don't need anyone to explain cantilevers or anything else of that nature.
3) this isn't an english class. i'm pretty sure everyone here understands my communication just fine.
4)went to private school.
5)graduated from business school. (no online bull****)
6)sold and built 12 decks this year. including one 2400sqft project.
furthermore, you have absolutely no idea what the conditions of my job site are. where are the utility lines? is there a big ****ing drainage ditch affecting post layout? etc.
insulting. and coming from a no think. you build with pt lumber. okay? i build with trex and steel. builders only. gtfo
Thanks,
NoVA
AlexADB is offline
The Following User Says Thank You to AlexADB For This Useful Post:
Fouthgeneration (12-01-2017)
Old 11-30-2017, 08:55 PM   #15
Trade: Builder/GC
Re: Lasers
Thanks,
NoVa
You're off to a great start. My money is on you getting banned before the night is out.
You ain't the hoss that gets to tell me what thread I post on, and which I don't. I do as I Damn Well Please.
Your opinion about steel is just that, your opinion.
And sinking deck posts in soil is a half-assed and dangerous way to build.
And you know nothing about my clients, what they can afford, or even what part of the country or world I live in.
And telling members to "get the F**K out" when you signed up here 2 days ago to ask a rookie question, is not the way to endear yourself to the forum.
Delta
Old 11-30-2017, 09:14 PM   #16
AlexADB's Avatar
Trade: Decks
Rewards Points: 32
Re: Lasers
Delta
Sinking deck posts in soil on a concrete footer is a perfectly legitimate way to build. Particularly if the deck is finished with rain escapes. Nothing I do is half-assed.
My opinion on steel being preferable for high-end decks is a professional one. It's also correct.
Asked a rookie questions about 7-8 months ago I think. Which, btw, was met with the same toxicity.
I think about building 24/7/365. There aren't anymore rookie deck building questions for me (no thanks to ct).
How about I tell you this. If you don't have anything nice to say and your first replies are insults-- GTFO
Or go cry to an admin. It's pathetic.
Like I said. Stick with PT. You'll end up getting yourselves into trouble otherwise.
NoVA
AlexADB is offline
Old 11-30-2017, 10:23 PM   #17
Trade: Builder/GC
Re: Lasers
Yeah, not gonna happen. Keyboard warrior.
Delta
Old 11-30-2017, 10:35 PM   #18
Re: Lasers
Wow. You are the one who came in here and talked about wood decks and wondered if you needed a laser.
Maybe you use a water level, or like was suggested steel posts self align with each other or some such nonsense.
What is your hate for lasers? Jeez, 150 bucks gets you decent one, 400 bucks gets you a great one, and it saves you hours of fiddling around. I don't even know of a more accurate way to do it.
Oh, and by the way, 12 decks in a year isn't that many. You better step up your game unless you want it to keep being a hobby.
Old 11-30-2017, 11:46 PM   #19
Dirtywhiteboy's Avatar
Rewards Points: 7,584
Re: Lasers
Sinking deck posts in soil on a concrete footer is a perfectly legitimate way to build.If you think so??? Particularly if the deck is finished with rain escapes. Nothing I do is half-assed.It's illegal here!
My opinion on steel being preferable for high-end decks is a professional one. It's also correct.Steel rust out in 3 years here cowboy!! It's all PT
NoVA
Is this guy real or just trolling
Dirtywhiteboy is online now
Seven-Delta-FortyOne (12-01-2017)
Old 12-01-2017, 06:52 AM   #20
AlexADB's Avatar
Trade: Decks
Rewards Points: 32
Re: Lasers
Delta
keyboard warrior. that's really funny since you're the one who came in here and started throwing around insults. what else can i expect from a pfp such as yours. smh. dry old men please step aside.
AlexADB is offline
Upgrading lasers platinumLLC Tools & Equipment 31 03-25-2015 10:46 PM
looking at lasers bigz Tools & Equipment 26 08-12-2013 09:21 AM
Lasers Upchuck Excavation & Site Work 10 01-02-2012 08:32 AM
Tile Lasers Mike- Tiling 74 12-22-2011 01:27 PM
Point lasers KennMacMoragh Tools & Equipment 41 08-31-2009 07:34 PM
