Ipe Around A Pool?
Old 09-12-2007, 09:07 PM   #1
obxdeck's Avatar
Trade: Decking, Fencing and Remodeling
Ipe Around A Pool?
Is Ipe suited for around a pool. I have a pool deck to replace that runs along the concrete coping all the way around the pool. It's 4-5' above grade, so air shouldn't be a problem. My concerns are:
How slick it will be after staining?
Will chlorinated water harm the finish?
Is 3 times labor a safe bet?
What jig saw blade to use for the rounded cuts along the pool corners?
I am also planning on using 5/4x6 pre grooved with the IPE Clips....is there a better way?
I have read dozens of posts about Ipe, so I know to wax the ends, plug the screws in the end board etc. Any other advice would be great.
Thanks in advance
Jay
obxdeck is offline
Old 09-13-2007, 04:21 AM   #2
send_it_all's Avatar
Re: Ipe Around A Pool?
I don't technically know the answers to your questions about Ipe, but I spent two weeks in Kauai in July and at the house I stayed at, everything outdoors including the pool deck was Ipe. It was a multi million dollar home with a covered outdoor kitchen/entertaining area, all made of Ipe. Huge viking bbq/range hood combo...It was actually a vulgar display of money spending.
send_it_all is offline
Old 09-13-2007, 10:54 AM   #3
John Hyatt
John Hyatt's Avatar
Ipe is fine for a pool deck we have done several of them. I do not recomend using the clips at all. Normal wood working tools,carbide blade,high quality jig. John
John Hyatt is offline
Old 09-13-2007, 05:35 PM   #4
obxdeck's Avatar
Screw down and plug?
obxdeck is offline
Old 09-14-2007, 03:36 PM   #5
John Hyatt
John Hyatt's Avatar
Actually for the no fastener showing look I put down T&G Ipe. I plug the rial detail if The Wallet is in that kinda mood. J.
Old 09-14-2007, 04:49 PM   #6
obxdeck's Avatar
Thanks for the advice
Jay
obxdeck is offline
Ventilation problem with an indoor pool frostbitten1 Roofing 10 05-27-2009 09:16 PM
What causes pool pumps to blow their bearings? SuperiorBuilt Pool Construction & Enclosures 14 06-11-2007 06:29 PM
Liner pool install ruskent Pool Construction & Enclosures 8 06-04-2007 05:47 PM
All a pool guy needs! denick Pool Construction & Enclosures 14 02-24-2007 10:53 PM
Gunite Pool builder /Nor-Cal...cool site D-pool dude Introductions 2 03-14-2006 07:36 AM
