Trade: deck builder
How To Cut Off Deck Boards
I need some advice on cutting off my new deck boards (Procell) to the correct length. I have most of them installed and they need to be trimmed back 1-2". It wouldn't be an issue except I am using Certainteed railing and I have the post pipes already installed, so I can't run my circular saw with the motor resting on the deck. It needs to be mostly hanging in space.
What tool should I use to make nice straight cuts? thanks, |
Trade: Squirrel Handler
Re: How To Cut Off Deck Boards
Should have cut your boards before you installed the railings. Don't know how tight it is but maybe a smaller circular saw like the battery operated one or you could use a sawzall to cut it close to the final dimension and use a portable power planer with a wood straight edge guide to finish it to the final dimension.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Trade: Kitchen & Bath dealer/remodeler
Would you have the clearance to use a 3 1/4 hp router ? Possibly with a straight edge clamped above or below the decking and use a 1/2" shank bearing guide bit ?
"We are continually faced with great opportunities which are brilliantly disguised as unsolvable problems." Margaret Mead |
Young Gun
Trade: Smartass
Can you get a jig-saw on it? A nice jig-saw can handle that.
Trade: General Contractor, Remodeler
I usually do what I can with the worm-drive, cut the rest with a jig saw, then even things out with a belt sander.... first sand the ends straight, then lightly round the top of the cut. Makes a beautiful edge.
#6 | |
Carpenter/fencing
Re: How To Cut Off Deck BoardsQuote:
Learning without thought is labor lost; thought without learning is perilous. |
| Used the new Correct Deck CX-personal review | IHI | Decks & Fencing | 22 | 07-27-2008 09:52 PM |
| Correect Deck ?'s Robert and others | IHI | Decks & Fencing | 9 | 05-21-2008 10:45 PM |
| Remove Deck Boards Tool | Joe Wood | Decks & Fencing | 6 | 06-24-2007 11:55 AM |
| Deck board hidden fasteners | Tommy V | Decks & Fencing | 28 | 05-20-2007 10:15 AM |
| Screwing down deck boards | JPV123 | Carpentry | 32 | 10-24-2006 10:25 PM |
