Trade: Electician
How To Attach Railing To Rubber Roof?
What method do you guys use to attach the railings on a deck with a rubber roof and sleepers? I was also wondering if anyone had any pictures of a deck done this way. Thanks for any help.
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Rewards Points: 2,000
Re: How To Attach Railing To Rubber Roof?
assuming this roof was never meant to be a deck with railings, you do not have posts going through the roof. that is how you would have been getting your strenth and support for the rails. now all your strenth must come from surface mounted rail system. hopefully you have several points of contact to the home itself. the more solid you get the perimeter sleeper system, the better off you will be. there are some teco brand 4x4 surface mounted brackets available, there strenth is questionable, i did a similar application many years ago, i had custom brackets fabricated to accept the 4x4, i also had the flange run up the 4x4 about 8'', that made a big difference, if you rabbet out the base of the 4x4, and have the bracket made to fit tight, you can then dress the 4x4 without the bracket getting in the way. welcome to the site sparky
Trade: Electician
I was planning on bringing up the posts from underneith for the railings but I am not sure how to seal the rubber around the 6x6 post. Is the a boot available for a 6x6 similar to the boots that are used for a round pipe?
Rewards Points: 2,002
I just saw one they did this way the other day. The deck was a "cap" that sat over the whole rubber roof, and hung down over on three sides, since the deck was cantileavered out of the house. The posts were bolted to the sides of the "cap" where it hung down over. Don't know if I explained that accurately enough, but that's the best way I can say what I saw.
John Hyatt
Rewards Points: 3,910
I bolt the posts to the rim joist. For a little extra I dap out the 4x4 posts 1 1/2'' x the size of the rim, the post lands on the decking an 1 1/2''.
I have a pic on my site. www.deckmastersllc.com John Mon |
#6 | |
David
Trade: Remodeling/Repairs,Renovation
Rewards Points: 25
Re: How To Attach Railing To Rubber Roof?Quote:
To counterflash the uncured rubber, you can either kerf the post and counterflash using copper or aluminum, or box in your post, thereby covering the post and rubber. Although some say sealing tape can be used in place of uncured rubber, I've found in some cases where seaming tape was used, the rubber wasn't flexible enough and did not yield a good bond or seal. Uncured had to be used over the seaming tape. Good luck. |
#7 | |
John Hyatt
gene,this is an upstairs project with a torch down roof and there is no rim joists. I am thinking a new job at a fast food window for you. J.
Since I don't know what he's doing either
(deck-on-sleepers, deck-on-joist-on-sleepers?) I guess I qualify to comment as well! ![]() ![]() It seems like Greg Di or RobertCDF had a post with some surface mount rail-post hardware not too long ago.
Trade: Deck Builder
Rewards Points: 5,582
Well if it's a wood rail I would notch/bolt post to rim joist also, otherwise you could always use surface mounted iron railing.
#11 | |
John Hyatt
If you dont have a rim joists,what is holding up the building????
#13 | |
David
Rewards Points: 25
That's what it appears to be from my porch, anyway. |
#14 | |
John Hyatt
Ok I get it,,,do not put the posts in the roof for a lot of reasons, Idea>>> use steel rail system lag the steel posts into the decking and the stringers ( not into the roof )thru the bottom caps<<< I have a local steel guy make this stuff up for me Im sure there is a local in your area. They wiggle around a little but most of the time the permit store goes for it.
I woudent mind working for the burgerking..but they deleted the Western Burger so the deal is off!!!! ![]() |
Trade: general contracting
Rewards Points: 75
what method do you use not to step on tar on a hot day?
Looks like OP left the building, so we could
argue about what he might have meant or might want to do. ![]() Advertisement
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 22 | 01-05-2013 05:42 PM |
what to do before covering a rubber roof | builditright | Roofing | 8 | 04-28-2008 07:23 AM |
Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 10:09 AM |
Slippery (dry) rubber roof | ATH | Roofing | 3 | 11-01-2006 11:05 AM |
Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 01:46 AM |
Go to Page... |
