Help Sonotube Blowout
Old 06-27-2008, 09:20 PM   #1
lemoncoke's Avatar
Trade: decks and remodeling
Can you wrap plastic around sonotube footings that wont get poured for a few days so they dont blow out. New to sonotubes and had a couple of them blow out on me and cave in , and the weat5her was not even rainy. Any help would be great my concrete guy cant pour them for a week or so so should I just wait and then put them in or wrap with plastic .
lemoncoke is offline
Old 06-27-2008, 09:53 PM   #2
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 476
Re: Help Sonotube Blowout
I'm not sure that I have ever seen a real sonotube blow out. Are you using some cheaper knockoff?
Now I often use these paper thin cardboard forms 12" wide x 9" tall. They occaisionally blow out. Usually it's not a big deal. But if you are having the 1/4" thick sonotubes blowing out, you better find another supplier.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 06-27-2008, 11:17 PM   #3
nap's Avatar
Trade: sparky
the only time I have had trouble with a sono-tube i when they get wet. If your earth is amp, the tube will soak up enough moisture to wreck it.
there is a sono-tube that has a plastic coating on it to prevent absorbing moisture but the ends are still subject to soaking up moisture so you still need to deal with that.
I try to pour the same day I set the tubes, maybe the next day but I would never wait more than that.
nap is offline
Old 06-28-2008, 06:45 PM   #4
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
Yes. These sat in the ground for about a month before concrete was poured. The only real problem was the siding guys thought they would make a great staging area for their Hardiplank. A couple of the sonotubes got a little misshapen but didn't crush. The plastic over the top keeps crap from falling in the hole until you pour. If you're worried about little people falling in, duct tape plywood squares over the plastic.
Mac
BuiltByMAC is offline
Old 06-29-2008, 01:16 AM   #5
kapena's Avatar
Trade: General Building Contractor
Rewards Points: 332
You might try wrapping some shrink-wrap around the base a bunch of times and work the final layers up enough to use duct tape so that water doesn't get between the wrap and tube.
Also make sure the concrete guy does not put too much water in the mix when pouring. They sometimes do that to make it easy on themselves, but it ups the pressure a lot.
kapena is offline
Old 06-29-2008, 09:51 AM   #6
Rewards Points: 2,000
Don't use them all that often,
but the ones I get from the
lumber yard always have a
waxy coating on them, no?
neolitic is offline
Deck posts in standing water.. bujaly Carpentry 8 06-20-2008 11:23 AM
Tri-state area deck estimates HemiMan2500HD Decks & Fencing 9 07-22-2007 06:58 AM
Sonotube Removal jackster20 Masonry 4 04-01-2007 10:25 PM
