Girder Or No Girder?
Old 04-20-2009, 06:53 PM   #1
kmyers's Avatar
Trade: Home Improvment
Im building a deck that is 28.5' long 17' of it will be 16' out and then 11.5' of it will be 20' out. Question is do i need a girder under 2x8 joist spanning 16 to 20' And if so what is the best cheapest way of doing it. Also what is the best way to scab 4' onto a 16' board to span 20'? Thanks in advance!
kmyers is offline
Old 04-20-2009, 07:10 PM   #2
KemoSabe
loneframer's Avatar
Re: Girder Or No Girder?
Nail a 20 footer to the side of it.
loneframer is offline
The Following 2 Users Say Thank You to loneframer For This Useful Post:
knucklehead (04-21-2009), ScipioAfricanus (04-20-2009)
Old 04-20-2009, 07:11 PM   #3
Deicide1's Avatar
Just use some silicone caulk on both ends of the board and hold it for like 10 seconds, should be strong and you don't even need to use nails.
Oh yeah, sounds like you're in over your head.
Deicide1 is offline
Old 04-20-2009, 07:12 PM   #4
Deicide1's Avatar
Look below you, just use silicone or any type of caulk on the endgrain of both boards.
Oh, I just read that's painters caulk is stronger, use that!
Deicide1 is offline
Old 04-20-2009, 07:15 PM   #5
KemoSabe
loneframer's Avatar
What about the girder? Silly string?
Old 04-20-2009, 07:49 PM   #6
Deicide1's Avatar
Actually, yes.
Deicide1 is offline
Old 04-20-2009, 07:52 PM   #7
KemoSabe
loneframer's Avatar
Actually, yes.
Great for locating trip wires also.
Old 04-20-2009, 08:07 PM   #8
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
I found my crystal ball.
I rubbed it real good and this is the image that came up.
Anybody have any idea what it means?
Gus Dering is offline
Old 04-20-2009, 08:09 PM   #9
Warren's Avatar
Trade: framing/remodeling
Gorilla Girder Glue
Warren is offline
Old 04-20-2009, 08:12 PM   #10
KemoSabe
loneframer's Avatar
Attachment 17936
Catastrophic failure?
Old 04-20-2009, 08:15 PM   #11
KemoSabe
loneframer's Avatar
Attachment 17936
I'm surprised those balcony decks with the knee braces are still there, WOWIE, what the FFG
Old 04-20-2009, 10:30 PM   #12
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extrordinaire
come on guys!Give the poor guy a break. He is obviously a professional who just needs a little info.
I would the Tico brand scab nails, about 8d should do it. then just toe nail the two ends together and voila! Instant 20' beam. I hope this helps.
Andy.
ScipioAfricanus is offline
Old 04-20-2009, 10:35 PM   #13
strat hd
strathd's Avatar
Trade: framing contractor , remodeler , GC occasionally
Attachment 17936
That was the place in Boston ? if I remember correctly.
strathd is offline
Old 04-20-2009, 10:35 PM   #14
KemoSabe
loneframer's Avatar
Andy.
Wouldn't you recomment Gorilla Butt Glue to compliment the Teco scab nails.
I would also mount to the rim with 44-D Hooter Clips
Old 04-20-2009, 11:52 PM   #15
Eater of sins.
Loneframer I think you way over build this stuff but better safe than sorry.
Andy.
Old 04-20-2009, 11:59 PM   #16
BuiltByMAC's Avatar
Trade: Construction
You've got a bigger problem than cantilevering 2x8 joists 4' over your beam (which is doable - not recommended, but doable)...
you're thinking of spanning 16' w/ 2x8s.
Even if you spaced them 12" oc, your max span is 14'-2 w/ SYP.
Mac
BuiltByMAC is offline
Old 04-21-2009, 12:14 AM   #17
Mac, where'd you get the calculator?
neolitic is offline
Old 04-21-2009, 12:23 AM   #18
hughjazz's Avatar
Trade: carpenter
I am gonna buy some gorilla butt glue first thing tommorrow.
What kind of tacos were you talking about?
hughjazz is online now
Old 04-21-2009, 12:27 AM   #19
hughjazz's Avatar
Trade: carpenter
x2.
Old 04-21-2009, 01:03 AM   #20
BuiltByMAC's Avatar
Trade: Construction
http://www.awc.org/calculators/span/...rcalcstyle.asp
Mac
The Following 10 Users Say Thank You to BuiltByMAC For This Useful Post:
Chris G (04-21-2009), DavidC (04-21-2009), genecarp (04-21-2009), HandyHails (04-22-2009), Martin Co (04-21-2009), mckellarman (04-21-2009), naptown CR (04-21-2009), neolitic (04-21-2009), ScipioAfricanus (04-21-2009), SLSTech (04-21-2009)
Termite damage on Girder in basement, ??? on fix Little Carpentry 3 03-28-2009 06:06 PM
Attaching 2x4 to steel girder Philly Dude Carpentry 20 12-29-2008 11:35 AM
Jacking Up A Main Girder cyberger Remodeling 7 07-13-2007 10:34 PM
girder & header sizing pesh Framing 5 10-09-2006 11:10 AM
girder hangers mjay Framing 6 02-24-2006 06:34 PM
