Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Decks & Fencing
Old 09-08-2009, 01:40 PM   #1
rotarex's Avatar
Gaf elk warp
Well I did a elk deck last November and appearently 1 month facia board started twisting but got really bad in July, and only my facia board, all trim and decking is perfect, so I came to the conclusion that the chemical in the PT is making it twist, any take on this fellas ?
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline   Reply With Quote
Old 09-08-2009, 02:18 PM   #2
You have probably come up
with the least likely theory.
Fasteners/fastening would be
a first suspect.
Pix might help.
neolitic is online now   Reply With Quote
Old 09-08-2009, 04:49 PM   #3
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
Its not related to the PT, might just be the Elk/Gaf boards. You need to put a few screws in those things.
Originally Posted by Gus Dering View Post
It may be just a gateway tool to the hard stuff. Be careful
WarnerConstInc. is online now   Reply With Quote
Old 09-08-2009, 05:56 PM   #4
John Hyatt
John Hyatt's Avatar
Trade: out door areas, decks,spa room additions,fire pits,custom design
It a every day pratice/mistake to install the decking flush with the frame no overhang,run the facia/skirting up flush with the decking . There is no way water is not going to get inbetween the facia and the frame. If you did this thats the problem not the chem in the pt.
If you do have an overhang of some sort It might be a good idea to use counstrustion adhesive,close fastening, and solid framing for the facia.
Riding a Harley is a whole lot like riding a good Horse,diferance is the rodents leave a pile of dirt so you can see the holes..The cages give no trace what they are going to do next. JonMon
John Hyatt is offline   Reply With Quote
The Following User Says Thank You to John Hyatt For This Useful Post:
AutumnWood Inc. (09-09-2009)
Old 09-08-2009, 06:01 PM   #5
Yeah, got to have a lip.
Old 09-08-2009, 09:01 PM   #6
Trade: Deck builder /contractor
How thick is Elk fascia board??Ive seen some that are 1/4". Screw it all you want, still doesnt look nice.
Quinn is offline   Reply With Quote
Old 09-09-2009, 01:17 PM   #7
rotarex's Avatar
I did screws every 18", it's the 1/4" facia
, I'll tell ya this all the screws in the world wouldent work, I can't even kick these things straight, it's rock solid, the board is flush wit facia and deck board is flush with joist, so there is that gap for water buildup in there, but that's how I do all my facia, some of my post got pics
Custom Decks
Renovation
Old 09-12-2009, 08:50 AM   #8
Trade: GC Residential / Light Commercial
I've done two Elk / GAF decks.
Both needed rework. I've also fixed two more with the same materials.
I won't use Elk decking EVER again. If it's insisted upon, then a clause will be stated that I am NOT responsible for it's stability.
The stuff moves like crazy and yes, one of the decks I did had the same 1/4" skirt wrap on it. I have to fix / rework that one this month. Warped. One of my posts (the solid core expensive ones) split!
Didn't even survive one year.
I'll post pictures of it when I go back out to do the repair. Thankfully, it's on Elk's dollar as I followed manu's instructions to the T.
Stay the heck away from it!
I will build you whatever you want, just draw it on the back of a big enough check.
JamesKB2 is offline   Reply With Quote
Old 09-12-2009, 09:01 PM   #9
RobertCDF's Avatar
Trade: Custom deck builder
1/4" Fascia??? holy crap you would need to screw it every 6" and I bet it would make it.
RobertCDF is offline   Reply With Quote
Old 09-12-2009, 10:42 PM   #10
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Builder
Any fascia- you've gotta glue, screw, and trim nail!
~Matt
Custom Decks: www.BreyerConstruction.com
~Excellence in Everything~
BreyerConstruct is offline   Reply With Quote
Will i warp it? ausisoda Sandblasting 4 10-10-2009 10:28 PM
Cabinet Door Warpage scott805 Finish Carpentry 4 06-09-2008 08:36 PM
What Filler do you use? Paint and Stain LNG24 Finish Carpentry 20 01-23-2008 11:18 PM
