Footing Size
Old 10-01-2010, 05:04 PM   #1
mpmaint's Avatar
Trade: MP Property Maintenance
Rewards Points: 27
Footing Size
Hey guys, quick question.
I need to build a handicaped ramp for one of my customers. The door is about 22" above grade and I need to build a small deck from the door to the ramp. I need to go down 48" for my footings. My question:
Will 8" dia footings be sufficient?
mpmaint is offline
Old 10-01-2010, 05:09 PM   #2
Concrete Mike
CONCRETE MIKE's Avatar
Trade: concrete
Rewards Points: 250
Re: Footing Size
Yep, good to go. If you are pulling a permit check with the city spec.
CONCRETE MIKE is offline
The Following User Says Thank You to CONCRETE MIKE For This Useful Post:
mpmaint (10-03-2010)
Old 10-01-2010, 05:24 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 478
Re: Footing Size
Better check on the dimensions for the deck & your door clearance.
griz is online now
Old 10-01-2010, 05:26 PM   #4
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Re: Footing Size
Mp, how about posting an intro in the introduction section and tell us about you and what you do.
Hint: adding your location to your profile will help a lot in getting good info for footing requirements in your area.
"Industry without art is brutality"
shanekw1 is offline
The Following User Says Thank You to shanekw1 For This Useful Post:
Old 10-01-2010, 05:55 PM   #5
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: Footing Size
Well to me a small deck is 100 sq ft, and 8" footings might not be enough depending upon soil bearing capacity
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
Old 10-01-2010, 05:58 PM   #6
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,890
Re: Footing Size
If you have any idea of the quality, it will be easy to find out the area required. If the deck is an unpreferred ledger attachment, you should go below the frost levels for any footing. If they are not deep enough, a frost heave would slope the deck back toward the house.
Dick
concretemasonry is online now
The Following User Says Thank You to concretemasonry For This Useful Post:
Old 10-01-2010, 06:42 PM   #7
Uber-Member
jeffaah's Avatar
Trade: Carpenter...Deck Guy
Rewards Points: 250
Re: Footing Size
I stopped guessing a long time ago. I generally use 12' for every poured footing I do. It's not that much more labor to dig and another couple 80lb bags of concrete are not a big deal.
jeffaah is offline
The Following 3 Users Say Thank You to jeffaah For This Useful Post:
CONCRETE MIKE (10-01-2010), mpmaint (10-03-2010), WarriorWithWood (10-02-2010)
Old 10-01-2010, 06:44 PM   #8
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Re: Footing Size
I'm not even allowed to use an 8" sono tube, let alone an 8" footing.
shanekw1 is offline
Old 10-01-2010, 08:39 PM   #9
Concrete Mike
Trade: concrete
Rewards Points: 250
Re: Footing Size
IT is a 48"depth footing, with a 8"diameter. This is not rocket science, ok I agree a 8" diameter maybee small so go 10". I think he is not building a bridge that needs a spread footer. Or I think he does not need to drill a pilion footer because the ground is sand or built over a swamp. He is probably using 4x4 treated lumber for his posts. And to top it off if he is asking this question he is a diy, not a carpenter or a contractor.
Old 10-02-2010, 08:54 AM   #10
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 166
Re: Footing Size
I'm in the same jurisdiction as Shane, so the 8" tube is not available.
Also, we would need a footing pad at the bottom of the sono tube.
Make one from 2 x 8's or scroll to the bottom of this page to see a prebuilt version: http://www.anchsand.com/default.aspx?tabid=186
jlhaslip is offline
The Following User Says Thank You to jlhaslip For This Useful Post:
Old 10-02-2010, 10:44 AM   #11
deckman22's Avatar
Trade: Deck Builder
Rewards Points: 5,594
Re: Footing Size
Probably is a DIY'er & this ain't a diy'er site, best to send them there.
On a side note, any inspector here who saw an 8" footing would be laughing, all the way back to his truck to pick up a red tag.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 10-02-2010, 10:58 AM   #12
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Re: Footing Size
No one said it was rocket science.
An 8" sonotube would get chucked by my inspector. 10" min.
An 8" footing would get what deckman said. 28" bigfoot min.
Although, as a side, a deck under 24" off the ground needs no permit or footings (not sure about wheelchair ramps and landings.) I could build that on pier blocks.
My first reply sort of implied that I thought he was a DIY anyway.
shanekw1 is offline
Old 10-02-2010, 01:00 PM   #13
Concrete Mike
Trade: concrete
Rewards Points: 250
Re: Footing Size
28" diameter min? I think that is over kill, but i don't know the spec. in your area of the world. Here in cleveland ohio the spec. for a attached or detatch deck with 4x4 posts is 36"-48" depth footer 8" or 10" sono tube, and also here you don't need any sono tube. Attached structures also call for 36"-48" depth footer with a min 10" wide footer if using 8" block, 14" wide if using 12" block.
Old 10-02-2010, 04:54 PM   #14
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Re: Footing Size
I only said that because the 24" big foot won't accommodate a sono larger than 8".
I use big feet and sono tubes exclusively because they save time and headache.
4x4 posts don't fly here, either.
shanekw1 is offline
Old 10-02-2010, 05:26 PM   #15
RobertCDF's Avatar
Re: Footing Size
What about a landing on a staircase? you have 4 24" footings holding up a 4'x4' landing ???
redwood (10-03-2010)
Old 10-03-2010, 11:35 AM   #16
Concrete Mike
Trade: concrete
Rewards Points: 250
Re: Footing Size
I would just use a post hole digger, dig 48" in depth, and case the 4x4 post or 6x6 with concrete, plumb my post, and build the dam little deck. Collect my money and move to the next.
Old 10-03-2010, 07:24 PM   #17
mpmaint's Avatar
Rewards Points: 27
Re: Footing Size
Guys, Thanks for the replies. Sorry for the lack of info but the landing is 5'x5' and 22" above grade, and a ramp leading down to the driveway.
We have to go down 48" on footings and I used 10" sono tubes. I know, complete overkill for such a simple structure.
mpmaint is offline
What size and kind of service line? help !!! mebedave Plumbing 10 10-31-2010 02:41 PM
Stem wall footing size tyler durden Masonry 19 06-03-2010 06:32 AM
drain pipe through footing m1brown Concrete & Paving 4 02-01-2010 08:31 PM
footing size dproc Decks & Fencing 2 03-12-2006 11:38 AM
Footing size and depth dproc Construction 11 03-08-2006 05:25 AM
