Footing Pads
Old 02-23-2010, 09:07 AM   #1
Quinn's Avatar
Trade: Deck builder /contractor
Rewards Points: 150
Footing Pads
Anyone using these? WWW.FOOTINGPAD.COM Something just doesnt jive with me.
Quinn is offline
Old 02-23-2010, 09:18 AM   #2
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
Re: Footing Pads
The link didn't work but I went on their site.
They're kidding, right?
We don't put posts below grade. That's what concrete piers or technoposts are for.
The frost is gonna grab that post and dirt will get in between the "pad " and the bottom of the post and heave that deck out of level.
But go for it and let us know how that works out.
Sorry...that was uncalled for....
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 02-23-2010, 09:31 AM   #3
JonM's Avatar
Rewards Points: 1,218
Re: Footing Pads
I don't know if I could get my inspector to stop laughing long enough to tell me no...
JonM is online now
Old 02-23-2010, 09:39 AM   #4
bb71's Avatar
Rewards Points: 75
Re: Footing Pads
I wonder if any of those testimonials were written after a freeze / thaw cycle.
bb71 is offline
Old 02-23-2010, 09:52 AM   #5
mics_54's Avatar
Trade: contractor
Re: Footing Pads
I've used similar pads and as long as they are used in conjunction with other installation methods and materials in projects with oppropriate conditions they work fine.
Frost can heave concrete also.
mics_54 is offline
Old 02-23-2010, 09:53 AM   #6
bb71's Avatar
Rewards Points: 75
Re: Footing Pads
Not when you do it right.
bb71 is offline
Old 02-23-2010, 10:01 AM   #7
mics_54's Avatar
Trade: contractor
Re: Footing Pads
mics_54 is offline
Old 02-23-2010, 10:04 AM   #8
bb71's Avatar
Rewards Points: 75
Re: Footing Pads
Don't like the posts below grade either. I would think you'd want to check with your local building codes before using these as they may not be acceptable.
bb71 is offline
Old 02-23-2010, 10:18 AM   #9
mics_54's Avatar
Trade: contractor
Re: Footing Pads
Budget constraints are as much a part of construction as methodology. Learn to fit the method to the requirements and experience cost effectivness.
Not all locations require the same construction techniques.
mics_54 is offline
Old 02-23-2010, 10:28 AM   #10
bb71's Avatar
Rewards Points: 75
Re: Footing Pads
I'm absolutely open to new ideas especially those that make a better product for a better price. I'm also very concerned about the longevity of what I'm producing for my customer.
bb71 is offline
Old 02-23-2010, 10:30 AM   #11
mics_54's Avatar
Trade: contractor
Re: Footing Pads
longevity is a factor in any cost benifit analysis...as is the labor, materials costs, logistics and performance.
mics_54 is offline
Old 02-23-2010, 10:42 AM   #12
bb71's Avatar
Rewards Points: 75
Re: Footing Pads
Obvious to most but maybe not all.
Do you believe these pads will meet your expectation (and your customers) of how long your work should last? I have not used them but that is why I would question them (don't like burying the posts) and also their ability to hold through freeze / thaw.
bb71 is offline
Old 02-23-2010, 11:09 AM   #13
mics_54's Avatar
Trade: contractor
Re: Footing Pads
That depends...As a contractor "my expectations" are always varied to the "customers expectations" How long I want the work to last is irrelevent. If the customer wants a project to be servicable for 10 years, thats what I want and that dictates the methods and therby the costs involved. But I wouldn't know his expectations if I didn't ask questions like... "how long do you want this to last" ..or.. "do you have a budget?"
Again....some people don't even know what a freeze/ thaw cycle is. Many places don't experience such conditions.
Also again.. the use of concrete isn't even possible sometimes. Logistics could be cost prohibitive. Not all ground material is frost suseptable. There are all kinds of criteria to consider and design a project around.
That's why you get paid the big bucks!
mics_54 is offline
Old 02-23-2010, 11:26 AM   #14
bb71's Avatar
Rewards Points: 75
Re: Footing Pads
Of course but you didn't really answer the question. Your customer wants his deck to last 10 years. Do you believe these will hold up considering freeze / thaw conditions and direct burial?
bb71 is offline
Old 02-23-2010, 11:39 AM   #15
Thom
thom's Avatar
Rewards Points: 4,748
Re: Footing Pads
This is only a partial hijack.
Do your utilities not bury poles directly in the earth up there in the frozen and wet north? If they do, is there a frost heave problem? How long do the poles last? It seems that once the exterior of the pole started rotting the pole would become unstable.
thom is offline
Old 02-23-2010, 11:47 AM   #16
mics_54's Avatar
Trade: contractor
Re: Footing Pads
I..nor you...probably can answer that except to reiterate what is asserted by the manufacturers or engineering community.
CCA treated timbers are garanteed for sub surface applications for 20 years. I can attest to this by experience.
As far as the pads I would have to rely on their certifications listed in their sales brochure.
As far as frost heaves if the post is back filled in non frost suseptable material and in ground that drains readily and the post is wrapped in poly below grade, it won't heave. I'm sure you are familiar with the fact that NFS material void of water doesn't heave.
On the other hand if you bury a post or concrete or steel piling in frost suseptable material with high moisture content...it won't stay there.
mics_54 is offline
Old 02-23-2010, 12:34 PM   #17
AustinDB's Avatar
Rewards Points: 656
Re: Footing Pads
reminds me of a commercial job I completed where the engineer required the 1st floor slab to be confirmed to be 4" thick, which in turn carried the weight of floor #2 and #3 above via a 3.5"x3.5" post. The slab was around 3.5" thick and the engineers solution was to use a 1/4" piece of steel 12" square, which dispersed the weight across an area of 144sq inches as compared to the 12.25sq inches.
AustinDB is offline
Old 02-23-2010, 01:53 PM   #18
tcleve4911's Avatar
Re: Footing Pads
The original poster (Quinn) is from PA and there IS frost in PA. His link directed us to a frisbee and a square post. That was why my initial reaction was
Sonotubes and technoposts are round for a reason. The way I understand it is the frost tends to slip by a curved surface and can't get a grip like it can on a square surface.
Please correct me.
Back in Maine
Dubbin' Around
Old 02-23-2010, 09:08 PM   #19
Deck Designer/Builder
DecksEtc's Avatar
Rewards Points: 1,000
Re: Footing Pads
What's to stop any yahoo from nailing a round piece of plastic to the bottom a post and using that?
Better yet, why not just drill some holes in the bottom of a Home Depot bucket, nail it to the bottom of your post and voila!
$5 a footing
Honestly, this is just a hair brained idea. As mentioned, I'd love to see the face of one of my building inspectors as I drop a post in a hole with one of those
I am the liquor - Jim Lahey, Trailer Park Supervisor
DecksEtc is offline
Old 02-23-2010, 10:02 PM   #20
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,914
Re: Footing Pads
If it is a ledger supported deck, it would be suicide the use any shallow post since the soil is what heaves up and may, but not always reside. This leads to a non-level deck and redistribution of loads at all connections and a shorter life, not considering the aesthetic and practical/appearance factors.
A proper free standing deck with concrete piers below the frost level is best and is they only thing approved in many areas. Sonotubes are usually, the most economical and practical, but different situations can offer other alternates. The posts are placed about 2' away from thr house and the above surface is cantilevered back to with 1/2" of the house siding. This eliminates all the possible flashing, moisture, rot and mold problems.
Dick
concretemasonry is offline
drain pipe through footing m1brown Concrete & Paving 4 02-01-2010 08:31 PM
ProKnee pads platinumLLC Tools & Equipment 14 02-22-2009 09:18 PM
Footing for Courtyard Wall fakie99 Masonry 14 11-19-2008 10:37 PM
Footing Details gladiatorxx Masonry 2 09-23-2008 06:50 PM
Footing Pads jclem Decks & Fencing 3 07-24-2008 10:54 AM
