Trade: Designer: Renovation Designs & Drawings
Flat Roof Deck Question
Hi:
I am designing a second storey roof deck in Toronto. The roof is flat and the new deck framing is 2 x 10 P.T. @ 16” o.c. spanning from one exterior wall to the other exterior wall. The framing will supported on 3 sides and lag bolted to house framing on the 4th side. My question is: I want to put something between the deck rim joist and the roof to allow for water drainage. I notice that some contractors use 1” rigid insulation. I have talked to the Building Inspector and he won’t commit himself. Any help or comments would be appreciated. |
Re: Flat Roof Deck Question
Slope the roof with strips towards the drain, plywood over that, tar it, torch it, flash where needed.
Build your deck over that. Put leveling blocks on the 4 corners, than do what ya gotta do to finish her up. -Bill
You laugh because I'm different........... I laugh cause I just farted! |
| The Following User Says Thank You to B.K For This Useful Post: | GordC (06-03-2009) |
#3 | |
Trade: Outdoor contracting: fences and decks
Re: Flat Roof Deck QuestionQuote:
I have been using 1" rigid foam on rooftop decks for 25 years. Not a code requirement, but it works well. Never had a problem. |
#4 | |
Trade: Framing
I typically use the roof structure as load bearing. Pitch it whichever way it needs to be pitched (mostly off the side of the building or in a scupper box.) Torch down and counter flash to the house and railing posts. Then I cut reverse tapers out of p.t. with 1-1/2" at the shallowest to give myself some meat to screw the decking down to. I frame up the p.t. reverse taper grid and block it around the rail posts to eliminate slide and movement. I make no penetration through the membrane anywhere this way. Reverse tapers allow me to build a level deck and keep railing level. The frieze/fascia board is also in this scenario. Decking goes down and ties everything together. Naturally, if you are pitching one way your deck tapers will run parallel to the pitch. If you're dumping to two or three sides you'd follow the pitch with the tapers. Going into a center drain is easy because your perimeter is level so the deck grid could be straight, and set up on rubber leveling pads tarred into the roofing. But basically this is what I try to accomplish when I come across these. Good luck. |
I builds'em
Trade: Renovations & Decks
Hey stone, do you use the foam between the sleepers and roof membrane? Does it matter which kind?
Ryan |
Trade: decking
Hi saw this on a website last week, maybe this will work for what you want.
http://www.dekdrain.com/products.php |
Trade: Deck Builder
What they don't tell you on that website is that you must once a year clear debris out. A major pita if HFS is used or otherwise imo. I did some last year & had GC sign off I wasn't responsible in anyway for that stuff. People won't do the proper maintenance & you will get leaks, imo. Who would want to, yearly?
Professional Instigator
Liquid nail Roof deck formula.
Home depot, isle 3, paint can caulking section,, 4th shelf from the top |
Capra aegagrus
Re: Flat Roof Deck Question |
I own a home depot.
So you just have to be the village idiot to own a home depot?
![]() ![]() Explains why its orange i guess.... Nice avatar by the way....
NO that what we call you customers after you leave, with 4 tubes of liquid nail deck formula
#13 | |
Hahahahaha! I always wondered what the chatter behind me was when i left the store. Now i know.
John Hyatt
Clems, is that that the Guy I know?? If so Good To See Ya Man!!
Anyway we build the same way. Torch down over plywood,stringers in the direction of the flow,screw the decking to the stringers Deftentley not past them into the roof. Old School ways like this have yet to be improved on. John Mon |
| Deck over a flat roof | Same Old | Construction | 10 | 12-07-2011 02:28 PM |
| How to put roof over existing deck | JohnHomeMatters | Decks & Fencing | 16 | 06-25-2009 04:23 AM |
| EPDM Roof Question, Re-stripping seams | Aggressive | Roofing | 14 | 03-12-2009 07:53 PM |
| Metal roof question | tc70518 | Roofing | 1 | 03-12-2009 07:15 PM |
| flat roof question | USER8493893 | Roofing | 6 | 10-02-2008 12:20 PM |
