#21 | |
Swanny
Trade: Pro Deck Builder
Re: Flashing Deck Ledger PicQuote:
If you don't want to worry about water sitting in the notch just tape up the notch with membrane before bolting the beam in. A run of membrane on top will keep water out of the lamination as well. Last edited by Swanny; 08-20-2009 at 12:32 AM. |
#22 |
Trade: Custom deck builder
For those who think sandwich beams are a good idea try this to prove a point.
1. Take 3 sawhorses and 1 12' 2x4. 2. Mark 12", 120" and 123 1/2" on the 2x4. 3. Set a sawhorse under each mark. 4. Apply a direct load to the center of the 2x4. 5. Watch as the 2x4 only rests on the 12" (end or ledger) and the 120" mark. Skipping the 123 1/2" sawhorse. This is of course more drastic than the real thing but the concept is the same. All joists are going to bow slightly in the center of its span when a load is applied. Plus nailing 2 members together is stronger than 2 members close together.
#23 | |
Trade: Inspector
Hi gentlemen,
Sorry to resurrect an old thread, but I came across this discussion while searching for a good deck flashing diagram. I am still searching for a good construction detail showing the termination at the ends of the galvanized sheet metal atop the ledger. What I am hoping to find is some type of detail that includes a sheet metal end dam, so that water can not run sideways and seep into the wall at the outside ends of the ledger. (such as you should see with a brick veneer detail). If anyone is interested, the American Forest and Paper Ass. has published a Quote:
#24 |
Trade: Masonry consultant
B. Whitmore -
The flashing and moisture durability problems will never go away. A ledger installation is always asking for problems down the road.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
#25 | |
Trade: Inspector
When specifying repairs, I like to provide diagrams showing best practice. |
#26 | |
Trade: Pretty much anything with wood
If the deck has no trim on it, you are sort of stuck to having a visible flashing. Why not just cap the end of the ledger with more ledger flashing?
#27 | |
Trade: Inspector
| deck ledger board? on fire code house | sponge racing | Decks & Fencing | 17 | 08-15-2009 03:13 AM |
| deck ledger flashing | Tom Struble | Windows, Siding and Doors | 10 | 07-30-2009 10:03 PM |
| Everflashing's / Ledger flashing | kornballs | General Discussion | 2 | 07-29-2009 11:01 PM |
| Deck ledger question | ArmstrCarpentry | Decks & Fencing | 10 | 04-22-2009 09:05 PM |
| attaching deck ledger to brick veneer house | eric at mrw | Decks & Fencing | 6 | 01-24-2008 10:56 PM |
