Fence Requirement Around Dumpster
Old 08-18-2008, 09:16 PM   #1
72chevy4x4's Avatar
I know the obvious, check w/ the city/county, but I'm dealing with a national maintenance company who oversees apartment complexes and looking to replace dumpster enclosures (no gate on front). Is the typical requirement 6'? Just off hand, is there a requirement for gated access when the container holds food refuse (as in the case of a restauarant)?
Has anyone built one with bollards (6x6 posts) set in concrete behind the dumpster to keep it from sliding back into the fence? My first thought was a 6x6 post even in concrete may not keep a 20klb garbage truck from advancing, but it was requested for that very purpose.
72chevy4x4 is offline
Old 08-18-2008, 09:28 PM   #2
genecarp's Avatar
Re: Fence Requirement Around Dumpster
I DONT KNOW about the gated access requirement, i do know that the 6x6 bollard will fail under the weight of a truck, which is ok, you must view the bollard as a sacraficial detail, it will most likely protect the fence, but will have to be repaired if contact is made.
genecarp is offline
Old 08-18-2008, 09:54 PM   #3
72chevy4x4's Avatar
sacrificial element-good term. ever hear/see of a sleeved insert to allow for future replacement of the bollard (6x6 in this case)? I could devise something by bending an aluminum skin (use a brake) and wrap the post before setting in concrete. There is the no aluminum in contact w/ PT wood issue, but don't know if it would matter in this case.
Old 08-18-2008, 10:30 PM   #4
Drawings always required a 6" iron pipe
filled with concrete.
Never had one request wood.
neolitic is offline
Fence Building School eddymn Decks & Fencing 15 08-22-2011 11:13 PM
Anyone know about pipe fence systematic1105 Decks & Fencing 2 03-21-2008 01:57 AM
split rail fence dlcj Decks & Fencing 6 02-02-2008 01:46 PM
Nailer for fence slats BrentV Decks & Fencing 16 03-30-2007 04:39 PM
Getting a fence installed on Monday!! Luke's Dad Decks & Fencing 4 02-20-2007 06:33 AM
