Originally Posted by CMFL
Hi, I am trying to erect a 5' chain-link fence on my property, in Miami-Dade County. I understand i have to submit two survey copies along with my ZIP application. This is where my questions start, where i can i pull an old survey of my property. Also, can i use the survey i had done when i purchased the house.
Thanks in Advance
Normally I don't like to answer HO/DIY'ers questions, but this one seems pretty harmless.
Use the survey from when you bought your property. Locate your steel pins for your corners, string line from there. Also the county clerks office should have all plat survey's recorded there.
