Home Improvement Contract
Trade: Handyman
Fence Gate On A Hill?
Hi all,
Anyone got input on installing a gate in a 6' privacy wood fence that is on fairly steep slope? The existing fence runs from the house to the property line; about 15'. and the grade drops about 2' to 3' in the 15' run. Client wanted a double gate and I point out the swing problem with the up hill hinged gate. He is considering a 40" single gate in the center. I've rebuild gates and installed a few too some on a slight grade, but I got concerns on this one. Any one do one like I have described? How did it go? Tia Mark |
Deck Designer/Builder
Re: Fence Gate On A Hill?
Put the hinges on the post on the low side and cut the bottom of the fence boards to conform to the slope, as close as possible anyway. Then, hang the gate about an inch off the ground and voila, problem solved.
Trade: Carpentry / Fencing / Decks
Re: Fence Gate On A Hill? |
Trade: Handyman
Thanks
Trade: Fencing
A guy thats done a ton more fence than me was telling me he builds his gates right in the fence leaving gaps in his boards for the opening. Puts his hinges on than cuts the runners and the gate swings open. Ive never seen it but would really like to. I cant seem to pin him down and get a closer look. He said its especially ideal when building a gate on a slope.
Anybody else ever seen it done? |
#6 | |
Re: Fence Gate On A Hill?Quote:
I'm curious to see how it's built to prevent sagging. BTW, I'm not knocking the method before I see it but I am curious. |
#7 | |
#8 | |
Trade: Fencing
LOL,, I hear ya. He looked at me like I was crazy for building them on the ground. ![]() He's been fencing 20 yrs. I believe him but I would need to try it in my own back yard. Thing I cant figure out is how does it NOT leave a chinzy little 1.5" block of runner hanging on the hinge and latch posts? You runners would have to run through the gate posts but only he installs the cross members in prior to the cutting he said...... so how does he nail those stringers up? Without dicing a little 1.5" chunk left hanging with 2 nails in it? |
#9 | |
I would think that once you cut the runners the gate would drop a bit no matter how well you ran your cross bracing, with the fence boards already on the frame it would look like crap. I build my gates on the ground and only install the first hinge side board. I install the gate then fill in the remainder of the boards according to my string line. I am all for learning new faster ways to do things but cutting the gate in seems like it will cost quality. |
#10 | |
#11 | |
It "might" be faster but I still fail to see how it would be a better longer lasting gate. Again, pictures of a finished one would be beneficial. |
#12 | |
Trade: Fencing
Your still dropping in your hinge and latch post though right? Of course. So what becomes of that little piece of "rail" thats left behind each fence board on each side of the gate opening? They just stay in there? Gap your boards 1/2' each side and cleanly trim off excess runner on the gate? Am I close? Sounds alot faster. If its not a shabby gate. Id like to at least experiment with it but never seem to have the time.
#13 | |
#14 | |
Are you talking about the 1 1/2" left from the table of the saw? If so I would imagine that you could cut from the front side and finish the cut with the sawzaw. I also miter the corners on my gates and screw them from the sides, along with toe-screws which would be hard to do using the cut in method. I do like the glue idea from genecarp, I would imagine I would have to use a good sub-floor adhesive for it to have any real effect on the twisting PT. I wonder if it would help to put glue on the fence boards also. |
#15 | |
ps. if i am building a custom section, with gate, i carefully hand pick my rail material...
#16 | |
Trade: Fencing
Cool. Ok typically in line i strap my rails half way through the posts from post to post butted up beside each other. However when i come to my gate opening I bring the rail over flush to the edge of the hing post. I fill the 2 (24") voids with scrap rail ,,, kinda like you do i guess. Than i start my rails flush again on the latch post and break back off on my 8' secs. So only way i see not leaving that little chunk of rail is to not even nail the runner (thats what i call em) on the hinge and latch post and just stretch thenm over and nail on the next line post. That way theres still not this little shabby chunk tucked back behind the board ,,, in between my scrapped in runner ? It would end up exactly like i typically build? Once i lagged in my hinges they would fasten the runners i never nailed. Does that make sense? Last edited by Seascape; 10-29-2008 at 09:31 PM. |
#17 | |
Trade: Fencing
Very intriguing! |
#18 | |
. i am still not seeing the little piece thing, but its late, im tired. if i have time i will swing by a job i have done and get a photo. have a great night, G
#19 |
Trade: Fencing
Cool,, i'll see what i can come up with 2. We may build differant and thats the confussion.
Id like to figure this out though...... |
#20 | |
| Vinyl fence gate posts | Danno6102 | Decks & Fencing | 6 | 10-20-2008 10:42 PM |
| Looking for deck and fence builder - Chicago west suburb | Green_2 | Help Wanted or Looking For Work | 0 | 09-07-2008 06:34 AM |
| painting pipe fence | diesel power | Painting & Finish Work | 14 | 09-06-2008 10:37 AM |
| fence requirement around dumpster | 72chevy4x4 | Decks & Fencing | 3 | 08-18-2008 10:30 PM |
| Anyone know about pipe fence | systematic1105 | Decks & Fencing | 2 | 03-21-2008 01:57 AM |
