Fasten Base Of Lattice
Old 06-09-2009, 07:48 PM   #1
shovel's Avatar
Trade: carpentry
Okay now Im a newbie to site so take it easy. Skirting in existing deck with lattice. Deck is 12 x 10 six feet of ground. The posts for the beam are set in and customer wants lattice on outside edge (rim joist?) What would you recommend to hold the base of lattice where meets ground.
shovel is offline
Old 06-09-2009, 07:50 PM   #2
KemoSabe
loneframer's Avatar
Re: Fasten Base Of Lattice
Garden Gnomes
loneframer is offline
Old 06-09-2009, 07:51 PM   #3
solar guy
naptown CR's Avatar
Trade: solar contracting
either frame it in or dig a 6" deep trench and drop it in but at 6' tall you will need some sort of framing
naptown CR is offline
Old 06-09-2009, 07:52 PM   #4
KemoSabe
loneframer's Avatar
Originally Posted by loneframer View Post
Garden Gnomes
Or PT 2 bys
Old 06-09-2009, 08:01 PM   #5
I like Green things
WarnerConstInc.'s Avatar
Make individual frames for each section that you lay out.
It doesn't take too long once you get your sizes the same.
I always use 2x4 ripped down the middle and rabbet out an edge, attatch lattice to the back.
I usually make the panels removable for just in case.
Small stakes at the bottom, drove into the gound 12" should take care of any floppies.
WarnerConstInc. is offline
shovel (06-09-2009)
Old 06-09-2009, 08:01 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Or PT 2 bys
Ground contact rated garden gnomes.
Tinstaafl is offline
Old 06-09-2009, 08:03 PM   #7
shovel's Avatar
Trade: carpentry
I am goin to frame the lattice but thought maybe there was a professional way i hadnt thought about for attaching near the ground. thanks loneframer for my first response on site.
shovel is offline
Old 06-09-2009, 08:11 PM   #8
KemoSabe
loneframer's Avatar
You are very welcome. Can someone tell me what to charge for my advice?Now that the fun is over, we usually build a pressure treated frame, nail the lattice to it then frame it in Azek.with the square pattern, we try to hide the studs behind the vertical lattice members.
Old 06-09-2009, 09:52 PM   #9
Tom Struble's Avatar
Trade: siding
ooo get to show my lattice twice in one week
Tom Struble is offline
Old 06-09-2009, 09:57 PM   #10
KemoSabe
loneframer's Avatar
I like it when that happens.
The Following User Says Thank You to loneframer For This Useful Post:
Tom Struble (06-09-2009)
Need a good base molding solution soon! HandyHails Finish Carpentry 16 03-17-2009 07:46 PM
base trim on island KentWhitten Finish Carpentry 33 01-16-2009 10:19 AM
identification of base material 72chevy4x4 Excavation & Site Work 2 01-05-2009 09:15 PM
Old Floors - Water Base Sealer is down - Grain Raise JPlous Flooring 15 12-22-2008 10:00 PM
Latex over Oil base paint is peeling iceman61 Painting & Finish Work 19 10-16-2008 12:44 AM
