Ez-stairs
Old 08-17-2005, 03:35 PM   #1
Kevin's Avatar
Trade: misc
Ez-stairs
http://ez-stairs.com/
Aside from the cheesy representative:
http://ez-stairs.com/info_s/images/stair_anim.swf
What do you all think of these brackets for building stairs? They appeal to me for two reasons:
1) They appear to be much faster than building a stringer.
B) I prefer the look of a closed stringer, but that is my personal preference.
Any thoughts? Anyone used them?
Kevin is offline
Old 08-20-2005, 04:26 AM   #2
Deck Designer/Builder
DecksEtc's Avatar
Re: Ez-stairs
They may be fine if your using 2x6 treads and the stairs aren't very wide. For me, I recommend 4' wide stairs (minimum) for all my customers, so those things wouldn't work for me. Also, I do a lot of box frame steps - much more stable and better to skirt, etc.
DecksEtc is offline
Old 08-21-2005, 01:47 AM   #3
orionkf's Avatar
Trade: Hardscape
Re: Ez-stairs
What do you mean by box frame steps? I might know, but I'm not sure.
Also, I read on the website that you could do stairs up to 9 ft wide, but not sure how that's possible.
orionkf is offline
Old 08-21-2005, 01:59 AM   #4
reveivl's Avatar
Trade: Renovations
Re: Ez-stairs
Ya gotta step over the exposed stringer ever' three feet. LOL.
reveivl is offline
Old 02-05-2009, 05:01 PM   #5
Deckman100's Avatar
Trade: Deck builder
Re: Ez-stairs
I've used the brackets on three projects. Once you get use to the system they are definitely faster, especially if you can pre-assemble the stair and then lift it into position and attach. One aspect that I liked was that you can build wide stairs using only the two outside stringers. According to the brochure, you can go up to 7' wide on exterior stairs but you have to use 2x risers. The brackets are approved as joist hangers and the 2x risers span across the stair like floor joists and that is what gives the strength. The stairs I built were two exterior and one finished interior. However if I had a a tight situation between two walls with limited access, it would probably be faster to cut stringers. The system worked well for me.
Deckman100 is offline
Old 02-05-2009, 09:57 PM   #6
BuiltByMAC's Avatar
Trade: Construction
Re: Ez-stairs
BuiltByMAC is offline
Old 02-05-2009, 10:18 PM   #7
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Re: Ez-stairs
I have built many stairways, I understand that a 2X riser makes the thread solid, but I don't see the city of Mpls letting us build that way. But it looks good to me. The only thing I question is, if you have built a lot of steps, laying out the stringers goes pretty fast with a framing square, so I don't see the savings.
silvertree is offline
Old 02-06-2009, 08:10 AM   #8
Pro Deck Builder
AutumnWood Inc.'s Avatar
Trade: Deck Builder
Re: Ez-stairs
Originally Posted by BuiltByMAC View Post
.......... The easy stair does seem a bit cheesy
AutumnWood Inc. is online now
Old 02-06-2009, 11:34 AM   #9
BuiltByMAC's Avatar
Trade: Construction
Re: Ez-stairs
I was just laughing because the thread's been dead since '05!
Mac
Old 02-06-2009, 01:00 PM   #10
Certified Remodeler
silvertree's Avatar
Re: Ez-stairs
And your point is what?
Old 02-08-2009, 02:13 PM   #11
VMFehr's Avatar
Re: Ez-stairs
Ditto
VMFehr is offline
Old 02-08-2009, 09:53 PM   #12
decks-patios-remodeling
deckndave's Avatar
Trade: Deck, patios & remodeling
Re: Ez-stairs
I've used them a few times. For composite stairs it can be very time consuming as you have to wrap your stringers first. But for natural wood they are great. Very sturdy, accurate and EZ for sure. I highly recomend them. I built a 5' wide composite stair last summer using them and it worked great. I can't emphasize enough how nice these are. Especially for nat wood. I've built a lot o steps and can frame them conventional style with the best of 'em. Ez stairs just make it a mulligan!
deckndave is offline
Old 02-08-2009, 10:00 PM   #13
deckndave's Avatar
Re: Ez-stairs
They make a bracket that you install every 16" that attaches from riser to riser and that is how you can build the wider stairs. As stated in previous post I built 5' wide set last summer using 1" composite. Rock solid.
Old 05-28-2009, 12:13 AM   #14
Deckman100's Avatar
Trade: Deck builder
Re: Ez-stairs
Originally Posted by VMFehr View Post
Ditto
Laying out the steps is the easy part and goes quick. Next you have to cut the first stringer and clean out each corner as you go. Once you have completed the first stringer, you lay the cut stringer over the uncut stringers and mark out for the next cuts and repeat the same process for as many stringers as you need.
If you are building a deck stair with composite treads, you will need a stringer every 12". For a 4" wide stair, that's 5 stringers. A 5 stringer stair with only 4 theads needs 50 careful cuts. EZ Stairs needs only two stringers, 6 cuts total and is engineered to be fast, and strong. I guess it all depends on how valuable your time is and if you like eating saw dust.
Old 05-28-2009, 07:09 PM   #15
Warren's Avatar
Trade: framing/remodeling
Re: Ez-stairs
Is it from the same makers that brought you "Easy Crown"?
I don't have a link but this stuff looked ridiculous. I think they had some infomercials a couple of years ago. I hve built hundreds of stairs throughout the years and have always laid them out one set at a time and customized them to the situation. Somebody posted earlier to just get a framing square and lay them out. I second that motion.
Warren is offline
Old 05-28-2009, 07:28 PM   #16
basswood's Avatar
Trade: trim carpenter
Re: Ez-stairs
You need this Makita saw. Then you can gang cut stair stringers 3 or 4 at a time:
basswood is offline
Old 05-28-2009, 07:39 PM   #17
Warren's Avatar
Re: Ez-stairs
Just checked out the ez stair video and website. It says it will be 4x faster. I once built a 14 rise set of notched out steps in 3 hours solo. Guess with ez stair I coulda been done in only 45 minutes. Give me a break. Did you check out the amount of screws you need? Not to mention there will certainly be a learning curve. The longer widths also require brackets. More screws!
Warren is offline
Old 05-28-2009, 08:17 PM   #18
Capra aegagrus
Tinstaafl's Avatar
Re: Ez-stairs
Rub it in, why don'tcha. I saw one of those on Craiglist a month ago for $200, and by the time I got done wavering, it was gone.
Tinstaafl is offline
Old 05-28-2009, 08:47 PM   #19
PA woodbutcher's Avatar
Re: Ez-stairs
I have a set of 14 riser 6' stair case to build next week.
Couple of years ago i cut 5 riser stringers for 60' set 16" OC. Took me all day to cut the jacks. The first 5 were sitting on an old crooked sidewalk that wasn't comin out and had to be cut individually. I used my old makita hyphoid to cut them. End of the day I had a blister in the palm of my hand from the start up twist.
I usually use a jigsaw with a stout 6" blade to finish my cuts.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 06-01-2009, 09:09 PM   #20
tat50's Avatar
Trade: TAT Contracting
Re: Ez-stairs
I have used EZ-stairs since 2006 and they meet every claim, expectation and more. The first time I used EZ-stairs, I built a 14-step turning stairway in my garage. I had two skeptical friends watch as it took me 45-minutes to assemble and install. This is the greatest invention in the trades in a long time. Additionally, you can span further with less materials, while creating a stronger stairs. They also have coated brackets for exterior applications including decks. tat
tat50 is offline
Complex Stairs wallmaxx Framing 4 07-09-2007 09:59 PM
ceramic tile on stairs? TaylorBuilding Ceramic & Stone Tile 6 11-26-2006 02:23 PM
Concrete stairs summertime Masonry 20 11-04-2006 01:35 PM
Are uncut stringers old fashioned for stairs? atari Finish Carpentry 2 05-30-2006 01:59 PM
How would you do these stairs? GreenEggs Framing 14 05-03-2006 07:23 AM
