Exposed Deck W/EPDM On Concrete (no Pitch)
Old 09-22-2008, 09:03 PM   #1
kellry27's Avatar
Trade: Residential building and construction ( carpentry and masonry)
Question, What materials should or can be applied on a single layer of EDPM over a concrete exposed deck under 2-1/2" thick mortar setting bed under 1-1/2" thick flag stone. Water and moisture are getting thru under existing rubber membrane. We removed flagstone and setting bed and exposed the EPDM materials.I was thinking of using treated plywood over existing EDPM to elimanate some of the tickness of setting bed to ligthten the load. should I glue and screw down plywood into concrete deck and then use rigid foam panels on top for pitch? Theres no pitch. If someone could respond I would greatly appreciate your input. Thank You Gary
kellry27 is offline
Certainteed Boardwalk pitterpat Decks & Fencing 13 06-21-2008 10:04 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 05:18 PM
Deck Height Over Concrete Joeyyungrocks Decks & Fencing 11 04-19-2008 07:00 AM
Patching penetrations in concrete roof deck geecee Concrete & Paving 1 03-04-2008 03:34 PM
Concrete Deck Joseph Azar Roofing 10 07-18-2006 07:49 AM
