Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Decks & Fencing
Old 09-28-2009, 09:55 PM   #1
Trade: GC/Carpentry
Elastomeric Decking
Thoughts on this? I have a client that wants to do this over 3/4" CDX on a covered deck. I've never done this and wanted to know what you guys think about it and if you have any specific recommendations or product recommendations on this. I really can't afford to have this fall apart in a few years down the road, esp as this owner is family and I will hear about it forever if it becomes problematic. They have friends that have done it with mixed results from the same installer. Let me know what you think.
jakejorgenson is offline   Reply With Quote
Old 09-28-2009, 10:06 PM   #2
General Contractor
MacRoadie's Avatar
Trade: General Building Contractor
Two concerns:
  1. Elastomerics can be very fickle in cold climates. Some can be quite brittle and don't flex well under load in the cold. Urethane elastomerics products are well-suited to cold climates, but I'd check very carefully with local applicators to determine which ones really do perform.
  2. Elastomerics require re-coating, usually every three to four years. You need to accommodate for the cost of maintenance and recoating.
MacRoadie is offline   Reply With Quote
Non-slip finish for wet wood decking, or go composite ??? akm Decks & Fencing 0 07-05-2009 02:19 PM
overhead composite decking coupe33 Decks & Fencing 4 05-10-2009 09:45 PM
Preference in the Way your Decking Boards Turn jcalvin Decks & Fencing 25 03-12-2009 01:01 PM
How much decking... ruskent Pool Construction & Enclosures 2 03-08-2007 08:38 AM
Powerwashing composite decking??? dougchips Pressure Washing 3 02-12-2007 12:58 PM
