Durable Deck Stain
Old 10-05-2012, 01:50 PM   #1
TopFloor's Avatar
Trade: Floorist
Rewards Points: 154
Durable Deck Stain
A friend has his cedar deck stripped and re-stained every 2 years. He asked me if I could find a dark stain that is more durable than whatever he has been buying at Home Depot. Where could I find the best stain for the job?
The deck is in San Diego and is subject mostly to bright sunlight and occassional rain.
Thanks.
TopFloor is offline
Old 10-05-2012, 01:59 PM   #2
ADKRemodeling's Avatar
Rewards Points: 25
Re: Durable Deck Stain
I think sikkens is the best, and if he goes with a solid stain it will last longer that semi-transparent and clear stains. A good quality solid stain should last between 4 and 5 years.
ADKRemodeling is offline
The Following User Says Thank You to ADKRemodeling For This Useful Post:
TopFloor (10-07-2012)
Old 10-05-2012, 02:39 PM   #3
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 476
A solid stain is closer to paint then stain. If he no longer cares to see the grain in his deck, use a solid stain.
We generally use Penofin or Superdeck, primarily because they are readily available and I haven't found anything better.
You still can't expect much more then 2 years with any transparent stain. Semi transparent might give you another year and solid stains, a couple of more years.
I will say that I have seen solid stains peel, which is the worst situation you want a deck in.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
The Following User Says Thank You to redwood For This Useful Post:
Old 10-05-2012, 04:42 PM   #4
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Pergolas & Pavilions
Rewards Points: 1,480
^^^^x2.
Cole is online now
The Following User Says Thank You to Cole For This Useful Post:
Old 10-05-2012, 07:58 PM   #5
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
Anybody who puts a color on the floor of a deck should be shot at sunrise. thats why there are lots of composites and cellular pvc with color. If they must use wood for the floor than a clear sealer is the only thing that makes sense.
Using a solid color stain on the railing,however, makes sense as it stays there, for at least 4 years and requjires little work to redo it. We have been doing the solid color on the rail for 15 years and it works great. Now that we make our own vinyl rail, I see little sense to a cedar rail as the real cost of vinyl, from the manufacturing side, is close to the cost of cedar.
killerdecks is offline
The Following User Says Thank You to killerdecks For This Useful Post:
Old 10-08-2012, 12:44 PM   #6
FenceGirl's Avatar
Trade: Fence & Gate Installation & Repair
Our company uses Cabots (http://www.cabotstain.com/) on our fences.
For example see:
http://townandcountryfences.blogspot...post_8901.html
We applied Cabot’s Wood Toned Deck & Siding Stain – Clear & Translucent - Natural to the inside and the outside. Application methods used were by spraying, rolling and brushing in the stain. We only use Cabot's products, which can be found at Lowes. The product lasts 4 years whereas other brands need to be applied every year.
FenceGirl is offline
The Following User Says Thank You to FenceGirl For This Useful Post:
TopFloor (10-19-2012)
Old 10-08-2012, 01:13 PM   #7
Greg from K/W's Avatar
Rewards Points: 530
Floodco offers a 5 year warranty on their solid hide stain for decks and 7 for siding. Best I have ever seen.
Greg from K/W is offline
The Following User Says Thank You to Greg from K/W For This Useful Post:
Ipe deck Clemens Decks & Fencing 64 06-21-2017 12:13 AM
Why is wood rotting ? SKC Construction 44 07-23-2012 03:06 AM
deck stain bluebird5 Painting & Finish Work 2 07-06-2012 10:22 PM
Behr Deck stain gary lee Painting & Finish Work 14 06-20-2011 12:49 AM
what do I stain my deck with? jimb317 Painting & Finish Work 21 06-26-2007 11:31 AM
